Watch of Today
mk3
6 hours ago, anilv said:
The date quickset is by the button at 3 o'clock. I believe this button is a replacement...from where I don't know as it doesn't look like any pusher I've seen before.
Anil
doh! how did i miss that one? i have one just like it.
that button looks like something you'd see on an older tissot - or a junghans.
10 hours ago, oldhippy said:
If I look at anymore like this I'm going to screaming out of my home. :D
Please Amigo , don't do that . I have more but the sanity of the members of this fine forum is more important to me . I'll keep them hidden ,...even my "Dukes of Hazard " watch that plays Dixie , and my mp3 watch with over 300 songs on it ....:jig:
Edited by ricardopalamino
Okay, here's one "you won't see coming or going" (that's an old expression used by one of the jewelry store owners I worked for way back when, to describe unique). It's a 12s, two tone Hampden 325. Just a 17j and pretty plain dial, single sunk and the octo case. Just some equal time for pwatch guys.:biggrin:DSCF0371.JPGDSCF0370.JPG
On 11/6/2016 at 2:29 PM, oldhippy said:
You will still need a jeweling tool to mount the jewel properly or a staking tool. So if you have one or the other or both you don't need the above tool.
This tool pushes them out and back in.  Just make sure you choose the correct size end so that the tool only contacts the setting, not the jewel itself.  No need for a jeweling tool or staking set for jewels in settings (chatons).
Dukes of Hazard...with Dixie ...now that did it... coffee is now sprayed on my monitor in hilarity.
Well done, Ricardo, game and set on that one ...:D
Here's another alarm watch with the same Poljot movement as the previous - this time a Signal. I'm not sure of the age, but it was very well taken care of by the original owner, as the dial and case are pristine. I had to do a bit of work on this one recently, as the minute hand was about seventeen minutes off. So while I had it open, I painted the alarm set hand red to match the second hand; originally it was the same gold tone as the hour and minute hands, and was a bit confusing when checking the time. Of all the watches in my collection (not that many, actually), this is one of my favorites.
Gryf
Edited by Gryf
    • I'm currently 3D printing a new basket and trays for my Pearl machine - I printed one last week in PETG material and it worked well at first. I had taken a calibration cube and soaked it in old cleaning fluid for 8 weeks and then measured it, and there was no discernable swelling or shrinkage and the cube seemed mechanically intact. All went well after the print and then onto the drying..... that's when things went awry. The heat was more than I was expecting and the basket and individual trays warped and deformed. I am now trying to print from nylon - which is extremely difficult to print with, my third attempt is chugging away now while I am at work - hopefully I don't go home to a ball of wool like last time!
    • It is possible to true the pearl basket to run better takes a good hour of filing though.
    • Yes, the general pat is this. On my diagram the points where the springs rises and levels are marked with red circles. This is only to show on all pictures (the ones that doesn't show this points as they are seen only from aside, not from above) where this points are. On You pictures, the pont where the spring rises is not marked. The point where it levels is marked with A. The point B is where the change in radius should start, but there is sharp bend there which should not be that sharp.
    • I agree, very minimalist dial,  but then the diamond. The 1973 R has a black dial and gold case and is similar in layout. But on the MyBulova site there really is nothing else like it...
    • This is such an odd Bulova. Off of the top of my head the only other mechanical Bulova that I can think of that has the 'Bulova' logo as an hour marker is the Golden Clipper 'J' (there must be others), one of my favorite dials. And then it has a solitary diamond, which is not unusual with Bulova, but paired with the 'Bulova' hour marker, that only leaves two quarter hour markers, and I can't think of another Bulova that has only two hour markers like that. You do you Bulova, no conformity here!
