Watch of Today
mk3
I'm feelin' Retro today... I think I'll do a Double Header..
     Starting off with a snazzy blast from the past with this water resistant Seiko  5 automatic 6119 - 5411 , ser. # 223055.
I must like this watch because I wear it a lot .
 Very comfortable on the wrist . It was pretty shabby looking when I first got it , so I serviced it , cleaned the case and bracelet , Re-finished the case and put a nice satin finish , extended the bracelet with a spring loaded expansion link , and installed a new Seiko crystal .
  For the second half of the Double Header , up to bat is this Seiko 5 automatic 6119 - 6023 , ser. # 022685  .
This one is a Sports Water70 Proof model .  It "Sports " an inner rotating bezel . I serviced it , polished the hardlex glass crystal , gave the case a light polish , and finished it off with a rubber two tone band . Black with a blue accent on the edges to compliment tne dial .
I had trouble loading a few pics ,...my bad... so here they are.
Edited by ricardopalamino
On October 16, 2016 at 7:49 PM, ricardopalamino said:
Hi svorkotter ,
I am reading a post today Oct. 16 that brought up your post of April 22 .  You posted links referring to the service and crystal polishing , but you mentioned that you overhauled the Jubilee bracelet also . What did you do to accomplish that ?
Basically, all I did was tighten up the links using a pair of flat-nosed pliers, and then put the bracelet in the dishwasher to get all the grime out.
15 minutes ago, ricardopalamino said:
Nice watch , and nice lume job . What type of lume  do you use ?  I have a cheapie that lights up OK , but the mixture is not smooth when it dries ,...kinda chalky .
I mix my own i use some lume powder i got of the bay thats keeps its charge well and i use clear nail polish as a binder.
    • Personally I would salvage the missing screws from some donor movement.  I also bought a random selection of screws "Assortment of Stainless Steel Watch Screws" for next to nothing.  As for using an Alum solution - I had great success with that removing a rusted stem from a stainless steel crown.  The best piece of advice I read on doing that was to keep the solution warm so that the reaction didn't take weeks!  I did it in a couple of hours with the solution in jam jar and the jam jar in a saucepan full of water which I left on an induction hob maintaining about 60C in the Alum solution.
    • I decided that it was time to tackle the piece that I'd set aside as my first project. The subject in question is a Gruen Veri-Thin pocket watch.  It winds and "runs".  On the time grapher, it has reasonable amplitude (240 or so depending on the position), but was loosing close to a minute a day.  The stem also has the annoying tendency to just come out when pulled, which makes it super hard to set the thing.  As with many things this one started sideways and just got more so.  I was able to overcome the mangled "tab" on the back case cover (a well placed, very sharp knife enabled me to get in when I couldn't get a purchase on the mangled tab with a case knife.)   I was then sort of shocked to find that one side of the dial was held down with some sort off tape or adhesive material as someone had broken the dial foot screw on that side and left the broken screw in the mail plate. The loose stem does in fact seem to have been a poorly tightened setting lever screw, but I'm afraid there may still be gremlins in the keyless works.  While I was able to get the stem to stay in by putting everything in the right place and tightening the setting lever screw (before I took it all apart for cleaning and inspection), it just didn't seem to all sit right. The final gremlin showed up when I was taking off the lower cap stones for the balance and escape wheel (yes the Gruen 380 seems to have a cape jewel on the escape wheel).  The balance stone came off fine (but that in fact is the smallest screw I've ever seen.  When I turned the movement around to get the one off the escape wheel setting, I found that the screw head had been mostly sheared off.  After some reading and looking at what I had, I decided to try and tease what was left of the screw out of the hole by nudging what was left with the corner of my smallest screwdriver.  After 20 minutes or so, I was able to get the remains of that screw out. The picture I'm including of the disassembled movement was taken before I got the second cap stone off, so in the picture, it's still attached to the main plate (for those looking carefully, you'll only see the one cap setting in the pic.) Now I'm left with: A broken dial screw inside the main plate that needs to come out A broken cap stone retention screw that I have in my parts tray, but that is strictly useless and needs to be replaced. The need to get another dial foot screw I'm contemplating solving the first problem by soaking the main plate in an alum solution.  I think the main plate is brass and shouldn't be affected, but I have not been able to confirm.  This seems like the easiest option as I can't really access both sides of the screw to use the pricey Bergeon tool (which I don't fancy buying unless I have to.) I have located a couple of donor movements and have questions out about whether or not the include the dial foot screw and prompting for pictures of the dial side so  evaluate the cap stone settings.  I've also found that a supplier in this country does have the cap stone settings, but isn't overly clear about whether the screws are included. Are these the types of things that one can scavenge out of assortments or is it best to just grab one of the donors assuming that they look like they have what I need?
    • I visited this place last year just before they closed their counter service - amazing shop (filled from floor to ceiling!) and the guy that was working there was really knowledgeable and helpful!. Their website isn't as good as Cousins but I understand that if you fill out the contact form they have stuff that isn't on the site. https://gleave.london/mineral-flat-bottom-domed/
    • As always in this game the answer is “it depends “ because the first one worked out ok doesn’t mean all will. A case could be made in a way that it would not really matter much, sounds like your first example. However a case could also be made so that only a tension armoured crystal could be used. Generally you replace like for like to maintain the integrity of the watch.   Tom
    • When can you use a standard crystal to replace one that had a tension ring? The first time I popped a crystal with a tension ring out of a watch I found that I had a suitable sized standard crystal and decided to try that.  It fit nicely and it was hard to see that anything was missing from the watch.  I understand that it probably reduced the water resistance of the watch but since it was an old dress watch it wasn't going for a swim anyway! I have since tried the same thing on another watch and found that the tension ring seemed to have an additional role of holding the dial in place.  With the standard crystal in there the dial and movement falls forward. This means it rattles in the case and falls forward and the hands fowl on the crystal (when the dial is down). Is there a trick I am missing here or does this watch require a special crystal?  I am reluctant to buy an expensive armoured crystal only to find I have the same problem.
