Watch of Today
mk3
1 hour ago, ro63rto said:
Thanks ,...I just got this one and I have 2 other non-runners . 1 of them just stopped working correctly . Both non-tunners will run , but not set properly , and you can't buy the circuit boards or get them repaired .
All three look good and the one in the Watch of Today post still has the plastic protecter on the back .
Nice Bimroy... where was this in Singapore?
I used to work in Singapore and there used to be all manner of Russian stuff to be had in 'Change Alley' opposite the Clifford Pier. More cameras than watches from what I remember!
Anil.
Something I'd like to wear but finding links is a bugger, I even called Seiko.:pulling-hair-out: Just wouldn't look right with a strap. Even though 24hour hand is missing, (I got it that way!?!?!?), overall this is in great shape and alarm reminds me of when "the boss" is due home, no matter where in the world I am!:startle:DSCF0303.JPG
Nice [emoji106]
What model is that?
Anil.
Hi,  I picked it up in the bugis area, there's all sorts of shops and business tucked away there.   I might take a wander to change alley today.
43 minutes ago, ricardopalamino said:
I've had this Grand Seiko 5641 - 7000 for about a year , but today is the first time I have worn it .
I gained a renewed appreciation for it after a couple of hours .
It's a GS high beat, what's not to like, I'm so jealous:thumbsu:
The 2209 is a bit unusual the below is an excerpt from a famous german movement reference site.
With an intermediate wheel between central minute pinion and a separate minute wheel the complete train is moved to the periphery. And due to the indirect sweep second, there is also no second wheel in the center. Thus neither balance nor barrel is overlapped by any wheel, and the complete height is avalaible for barrel and balance. The result is a rather low profile without reducing sturdiness or accuracy.
Looking at the movement picture I just realised that the hairspring seems to be a bit out of round..ie coils not centered. Keeping good time for the last 4 hours though.
One thing about russian watches is that even lower grades have a Breguet overcoil hairspring...but not on this watch however. Despite being targeted to the the higher end of the market, it has a normal (non-overcoil) stud. This is probably because the focus of the designers was to achieve a thin movement and an overcoil would have added more height.
Anil
8v22-7000, I may end up changing to strap, but because it's kind of unique, it deserves a proper band. Thanks for your approval!
A dark brown croc would pair well with that.
If you are feeling adventurous, have a look at green croc too. would go well with the gold.
I have the same issue with my 7t42. It could do with 1or2 extra links but cannot find any.
15 minutes ago, ricardopalamino said:
Screen shot 2016-08-30 at 5.49.02 AM.pngI use these . They were not available in the 16mm size for a long time . 16mm is what I have used on most of my Seiko deployment clasps . I just ordered 4 ea.
Good idea, thanks!
p.s. I find the green croc might look pretty special too.
That's just because they bought an American factory in consignment conditions that happened to make watches like that. If they were making e.g. pin pallets movement then the entire Russian population would have been kept awake by their lovely noise for some 60 years [emoji4]
George, hats off to you, those movements are a real pain to tackle, but you do it with quite an enthusiasm and your work is first class! Much impressed.
Cheers,
Bob
PS. Beautiful watch, to my taste watches with that movement tend to be quite appealing.
Cheers,
Bob
Thanks bobm12, I actually enjoy repairing these watches, and the 7T32-7F80 I last posted in particular was kind of a challenge, since it had a broken pin on the plastic baseplate, that prevented the movement to function correctly (among the other issues...). I posted pics on my new blog, if you want to see the status it was in (will not link it since it is also a shop). Since it was a family heirloom of a friend, I had to try and restore it to its formal glory. A picture of how it came to me is attached to this post. He did send a beaten working watch with the same movement, but unfortunately that one also had some issued, so from two watches, I made one. The other will still be repaired, though.
Edited by GeorgeClarkson
Nice strap and very appropriate, Ro63rto! I love the watch.
@GeorgeClarkson George, what paint did you use for the bezel? I'm curious since I have a couple watches that can use some of the same treatment. I was thinking about using Testors acrylic model paint...or even the (to me) more convenient Molotow paint "markers"....Thank you in advance.
Cheers,
Bob
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
    • Moved in. Now working out the best place to have things so moving around the room makes sense. The wooden movement testing rig may end up being suspended from the roof with some pulleys and ropes that I salvaged from some alfresco blinds that we replaced. I always seem to salvage things from things we scrap thinking, "I have an idea what I can use these for." I hope I'm not the only one that does that. My wife hates me for it. "What are you going to do with all this crap?" Anyway, here you go. If anyone has suggestions for workflow around a room, speak up. All Ideas are appreciated. The bench on wheels will carry either a laptop or my Samsung table for using with the little camera that is on the tripod for photos while dismantling etc. The small bar fridge in the corners going to have water etc in it and I might move the coffee maker from the kitchen out there as I am the only one that uses it. I want to get an ultrasonic cleaner so I may set up some sort of cleaning rig in front of the glass of the sliding door. Where the grandmother clock is currently standing. I'm hoping that I will be able to transition my working area, which is the table that the stool is sitting in front of, fairly easily between clocks and watches. I'll be doing my best to make sure that tools for each are separatedwhen stored. Logistics. I'll have a bit of wall space for being able to hang clocks if I find some that I wish to keep or hopefully at some time to be able to hang customer clocks for monitoring after servicing/repairs. The clock on the left in the blue pillow slip and the grandmother clock are earmarked for  Jarryd and his wife, Sara. He helped me move the benches in today. And then went on to tell me that ticking clocks drive him nuts. Who doesn't like the rhythmic ticking of a clock? I have a green pad for adding to the bench for a working surface. It is not a cutting mat or one of the Bergeon mats. It is actually a green desk writing mat. Was really cheap and will do exactly what I want, I think. I also have to get the sparkies back that put our new stove in to put some power points on the walls behind the benches. Hopefully this is all going to go well. I'm excited about it. It'll beat having to live out in the garage doing it. The other thing I have to do is cut a circle or square of plastic to go over the bouncing watch or clock part black hole in the middle of the floor. I would pretty much guarantee that anything that sproings off the bench would end up going straight down that drain. 😄      I think I have been on this forum about 4 years and still yet to really strike a blow. That's a bit sad isn't it. Signed up to Mark's watch course and have yet to buy the movement for working on. Have most of the tools I think I will need so now all just a matter of will.   I have to make a crank handle for my Joe Collins spring winder as well and some spring retaining tubes as I can't find where I can buy them. I will be salvaging (here I go again) the aluminium tubing from my old hang glider which I have to scrap as I can't fly anymore and it is too old to sell. All the aluminium tubing is aircraft grade so I am hoping it will be suitable for the winder. I have also been making a bushing tool and I have just worked out that it will work well with my Dremel stand. So another thing that I can turn into a working tool. Don't know if you guys have ever seen the ad about the guy that buys himself a new 4WD and the son says "We're going to need a bigger boat." So Liz is looking at all the stuff we have to get rid of and says "We're going to need a bigger bin." Really difficult to work out how big a Dempster bin we need. Sigh.
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
