Watch of Today
You know there is a spring in wind screen wipers. You can use it to make the anchor out of it, no thermal treatment needed. -
That was in the 50's... imagine how much you would be saving at today's prices. A bargain! 😄
Like @HectorLooi says, drilling it yourself is definately doable. This could also be a fun and quick project to make it yourself from std 2mm float, even if time/money is a factor. Lots of "how to" information incl video's online on the drilling. Cousins sells clock/barometer glass and they also mention instructions for drilling in that product section.
I guess the hole is to equalize air pressure inside the case. But does it need to be in the dead centre? Does it even need to be in the glass? Anyway, I have drilled small holes in glass before using a dental diamond bur. I used a dental highspeed handpiece for the job but a normal drill press would probably work. You need a coolant to carry away the glass particles to prevent clogging the bur. You can build a dam around the spot to be drilled with plasticine or Rodico and fill it with water. Use very light pressure and be patient. It's going to take awhile. When the hole is almost through, turn the glass over and drill from the other side to prevent chipping the edge of the hole. Good luck. -
https://www.cousinsuk.com/product/pallets-complete-american-ansonia Try these. You might have to choose the closest looking one and modify it. Wish @oldhippy was here. He'd be able to advise you.
