Does anyone recognise this please?
Deggsie
Today I received 12 old watches I bought on an auction site and was disappointed that 5 were quarts and not all mechanical as described. However I think just one of the watches makes up for it as it has a lot of character. Does anyone recognise this watch or movement please. There is no branding on the dial or apparent manufacturer on the movement. Inside the back cover it say DENNISON CASE. Please see photos below:
00daf86f4e772944afa79ccb4a7909bc.jpg87f84b0e6d3b19597d61933ddbef960d.jpgf3ffe6fac1733d14b9de2aa957edaaaf.jpg
I have a piece that's a lot like that one- also with an unsigned movement.  Mine is a vintage Delmar woman's watch. The movement is small and fits in a rolled gold case almost identical to yours. I'll post some images tonight.
It's a pretty movement with perlage on both the top and bottom plates, Breguet hairspring, and compensating balance. A bit of research on the internet suggested the movement may be a variation of an early AS movement, although which I cannot recall.
Regardless, it's a nice piece.  :)
Seen one a few weeks ago almost identical to yours. Can't remember if the movement was like this. Also unbranded. They're pretty interesting but don't hope for something mega rare and expensive.
Time period is 30s probably...
Unfortunately, I just noticed the Chrystal (a polymer or sorts) has been repaired with what looks like aradite presumably to stop it falling out[emoji51]
Regardless, it's a nice piece.  [emoji4]
Would information / drawings be available to help me disassemble and service? I might hold tight until I have more experience with scrap movements. Cheers. Deggsy
The back cover also says its 9 ct gold its a pretty typical ladies watch of the 1920's but you should be able to date it from the hallmark. The movement is I would guess a FHF movement, it looks in quite good nick from the photos and would probably do with a crystal change anyway as that one looks to have yellowed with age. It is a good quality watch that someone would love to have.
Thanks for your input here. So the yellowing polymer is authentic? Do you know if these are still obtainable please, or would I need to make one ?
Regards deggsy
You should be able to get a crystal for the watch from cousins or Ebay some sizes of crystal are hard to get now a days, but i find small oblong crystals for cocktail watches can be hard to source but I dont think you will have a problem with a round crystal.
Sometimes you have to take down the movement to see who made it.  Did you look on the dial side of the movement (after removing the dial)?  Sometimes there's a trademark there.
Hello Douglas. I've not taken this apart yet, but will keep you all posted on what I find. Cheers. Deggsy
If you cant find any ID under the balance, remove the movement from the case, take the hands off and remove the dial and see if there's any ID there, if not take a good picture of the keyless work and post it here as many old watches can be I d that way, the bestfit catalog should have the info and I know clockboy on here has a copy and should be able to help you. I have said many times on the forum these old ID books are a wealth of info, keep your eyes open as these old books come up on ebay.
Every thing that wis1971 has said about this watch is correct.
Doubtless from the FHF stable, similar to this, http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&FHF_002_10_5 although I expect an 8.75 ligne (19.5mm) rather than 10.5 ligne (23mm)
You will be wanting a sternkreuz m crystal... https://www.cousinsuk.com/product/domed-slightly-sternkreuz-m, and Hirsch sell a nice range of open ended straps
Sadly once finished, these have little commercial value, but make really nice and unusual presents
very nice watch indeed,....if you want I can have a look in my crystals stock for the correct crystal if you send me the size. As for the auction, if they are misdescribed, you can return them and get your money back.
That's a kind offer watch time, but I think the case has been damaged or a part is missing. There is no visible groove or way of holding the crystal in. Hence I think that's why the previous owner has glued it in[emoji51]
Acrylic crystals are a compression fit. The case should have a step which the crystal fits inside. If it has been glued in that's probably because it is too small.
You should ideally buy an acrylic crystal which is 0.2mm bigger than the diameter of the opening in the case. You will then either need a press or a claw tool to flex the crystal to fit it. https://www.cousinsuk.com/product/round-glasses-superior
Sometimes it is difficult to find the right size and so crystals do get glued in. GS hypo cement is the right thing for this https://www.cousinsuk.com/product/gs-hypo-cement
I'm not 100% sure that this would be a low dome as OldHippy says. That would be a Sternkreuz type N rather than M. Low dome type N will project more out of the case than a slightly domed type M. If you remove the old one and post a picture of the edge then we can advise.
Here's those pics I promised, better late than never. Top and bottom plate are taken before service (yes, it was a dirty one) and the last pic is post service.
IMG_1604.thumb.JPG.eb4ad7af7d8d5111753b6fef9972bb10.JPGIMG_1608.thumb.JPG.a911b085016013cc7a54000968efda15.JPGIMG_2259.thumb.JPG.76bb21adcc28b67747c86920468d789f.JPG
I made a mistake before as it's not a Breguet overcoil hairspring. The rest is quite nice though- lots of perlage.  No identifiable markings on the top or bottom plates so it's a guess as to who made the movement. I think FHF is probably the best guess.
I haven't found a service guide, but I dropped all my service pics into my Public Dropbox folder if you want to grab them. I'll keep them there for a month or so.
Hello all and apologies for the delay in getting the photos back to you as promised. I removed the acrylic crystal and it was sadly held on by something like araldite and also a grey resin like compound - see photo. My camera equipment is not high tech yet so please forgive the quality in comparison to some of the better images I see on here. There definitely is no ridge, just a plain bore in the case. Maybe this is why the crystal was held in with resin?
Here are those images:
b82523bfa14134129c2999d8284ad86d.jpg14fed3bd5a81970997288d0e06667582.jpgc78f04e517beab963d1916dc529f15ed.jpg0a9bfb8c2ac2c775b61a998a13f9a97d.jpg6ea0e9074ecb371609b3d95da1fcf4b7.jpgc111b8db3c590cc5a4198e08a30ef176.jpg
I'm struggling to see the detail of the top of the case on these pictures. Here is a similar case where you can see the expected groove on picture 6
http://www.ebay.co.uk/itm/RARE-1931s-ANTIQUE-LADIES-9CT-GOLD-375-HAND-WIND-SWISS-MADE-WATCH-CACHECASE-/232258360767
If there is no groove, then the only option I can see is one of these, although I've never seen a case like that with a stepped crystal... https://www.cousinsuk.com/product/domed-underlayed-sternkreuz-u
You will need a type of crystal for that called a underlayed crystal they are available from cousins and have a extended flat lip around the edge they are pushed in place from underneath, you have probably looked the hallmark up but it appears to be 1930 the patent number refers to the case "Cachecase" and was first patented in 1926.
Hello. For clarity, here is another photo of the outside of the case with the movement installed 09cd79b7b159348960a57814f533e682.jpg
I can see the groove you mention ref photo 4 in the auction, but the case I have just has a plain bore as in my last photos. Maybe bodged in the past due to damage?
That first case would have what is known as a low dome acrylic glass. The same with me the picture is not clear to my sight to me its blurred.
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
    • Moved in. Now working out the best place to have things so moving around the room makes sense. The wooden movement testing rig may end up being suspended from the roof with some pulleys and ropes that I salvaged from some alfresco blinds that we replaced. I always seem to salvage things from things we scrap thinking, "I have an idea what I can use these for." I hope I'm not the only one that does that. My wife hates me for it. "What are you going to do with all this crap?" Anyway, here you go. If anyone has suggestions for workflow around a room, speak up. All Ideas are appreciated. The bench on wheels will carry either a laptop or my Samsung table for using with the little camera that is on the tripod for photos while dismantling etc. The small bar fridge in the corners going to have water etc in it and I might move the coffee maker from the kitchen out there as I am the only one that uses it. I want to get an ultrasonic cleaner so I may set up some sort of cleaning rig in front of the glass of the sliding door. Where the grandmother clock is currently standing. I'm hoping that I will be able to transition my working area, which is the table that the stool is sitting in front of, fairly easily between clocks and watches. I'll be doing my best to make sure that tools for each are separatedwhen stored. Logistics. I'll have a bit of wall space for being able to hang clocks if I find some that I wish to keep or hopefully at some time to be able to hang customer clocks for monitoring after servicing/repairs. The clock on the left in the blue pillow slip and the grandmother clock are earmarked for  Jarryd and his wife, Sara. He helped me move the benches in today. And then went on to tell me that ticking clocks drive him nuts. Who doesn't like the rhythmic ticking of a clock? I have a green pad for adding to the bench for a working surface. It is not a cutting mat or one of the Bergeon mats. It is actually a green desk writing mat. Was really cheap and will do exactly what I want, I think. I also have to get the sparkies back that put our new stove in to put some power points on the walls behind the benches. Hopefully this is all going to go well. I'm excited about it. It'll beat having to live out in the garage doing it. The other thing I have to do is cut a circle or square of plastic to go over the bouncing watch or clock part black hole in the middle of the floor. I would pretty much guarantee that anything that sproings off the bench would end up going straight down that drain. 😄      I think I have been on this forum about 4 years and still yet to really strike a blow. That's a bit sad isn't it. Signed up to Mark's watch course and have yet to buy the movement for working on. Have most of the tools I think I will need so now all just a matter of will.
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
