Case refinish
Had some spare time today and case to mess around with, took me a few hours to get this looking sorta new, satin finish achieved with simple scrub pad, then high buff, (by hand with foredom) around the bevel.  Much finer than machine finish, took away most scratches and dings with 600 paper first. What do you think? Remember, I don't have a day job to quit!:D
DSCF0447.thumb.JPG.2fdcb0a8e81460e14f6d1ed2389537af.JPGDSCF0448.thumb.JPG.968ab373a506787a817dc40e303fef00.JPGDSCF0449.thumb.JPG.2eb7480c18a32276940c7eda78ae8e6e.JPG
Next time use buffing, not abrasives to remove scratches and dings. You will remove much less material and do one only polishing step after.
  • Like 6
JDM,
Buffing machines can do a fantastic job. One of the secrets to buffing this way is to have enough horsepower in to motor to handle the buffing wheel. I have three of these machines with different wheels charged with different grits of buffing compound. These machines work well for me while the smaller motors I tried bogged down under the load.
http://www.ebay.com/itm/8-Electric-Bench-Mounted-Benchtop-Buffer-Buffing-Machine-Polisher-Grinder-/222364019880?hash=item33c5edaca8:g:BwUAAOSwa~BYaTQw
Edited by david
Indeed. For now I don't have a dedicated motor, but I use rotating tool on a vice for "micro-buffing", and a common drill, also on a support, for bigger work with 50mm wheel. Very good results so far... I don't post before / after pictures because almost all my watches gets listed :biggrin:
On ‎2‎/‎3‎/‎2017 at 1:40 PM, Michael said:
Looks excellent, Nice sharp edges on the sides. Do you have the rest of the watch to build back up?
I didn't think to look at case, it's a 7009 Seiko, (got in a lot of misc parts w/o movement) probably have one I could stick in there.
I have seen the 'lapping' technique on a wheel with compounds, you are correct, I was careful not to over abrate surfaces. I have seen 'pitting' on ssteel and once you start it doesn't matter, you'll usually not be able to get desired result, in fact you may make it look worse. Years ago when I worked in jewelry store, it was my job to do all the polishing, mostly repairs, rings and such, so I am familiar with a benchtop polishing setup/techniques. Just never did watches.
I found a bracelet that will fit case and began to use same technique on that with similar results, I'll post a pic soon.
Thanks for all the support, your opinions matter and are encouraging to me.
Dave
Here are bracelet pics, (before/after) after masking off center high polished links, used same pad to create satin look finish, returned to give center links a bit of work, I found spare movement now just need a dial and chapter ring to fit. I'll be sending out for new crystal today, so it'll be some time before I can get back to it.
excellent job, looking awesome....I bought a buffingmachine and I use it as I don't have the patience of doing it by hand...It really gives a great result on crystals as well as cases and bracelets. I don't polish them 100% as I like some wear and tear on a vintage watch.
12 hours ago, Michael said:
Outstanding job. Looking forward to next update.
Like I said, just sent out for new crystal, should be less that a week or so and I have a 7009 movement that should fit. Thanks
10 hours ago, parmenion31 said:
wonderfull work , looks brand new !
Well, let's just say it looks different and unique, I like the way high polish and satin finish sort of meld together on this one. Can't believe it looks that good myself! Thanks
Well here it is....new crystal and wouldn't you know it, broke pin when replacing bracelet, so not quite done yet!  I dunno about the gold and silver combination, but my first attempt at this type of operation, I'm happy with it. Thanks again for your generous comments.589e2a0470a36_DSCF04581.thumb.JPG.336e44a6e80a9846381e56a96574fdd0.JPG
    • No John, we don't want Mark to change anything, we are just scared of losing a brilliant forum and losing contact with each other.  As pointed out, this forum is full of knowledge and I for one,  consider the regulars friends. I would hate to lose contact with you and the others.   PS, this forum is really important to me.
    • one little minor problem with your chemistry experiment here which is what exactly is epilam? In other words is it an exact substance with the chemical you specify or is it a term? For instance originally it was steric acid either dissolved in some sort of solvent or it was applied by vaporizing it. Then now it's all kinds of different things the watch companies all have different ideas there's a whole bunch of patents. So is not always an exact substance.   let me snip out a image from the patent that I attached up above. Notice I highlighted something it seems to disagree with your evaluation.
    • I guess You had to try, as it would be hard to sleep without that try, but, I know the result before the experiment... As I told before, the friction will be so big that the wheel will not turn. The pivots have to be thin and polished - the bigger the number of the wheel (2th, 3gh, 4th...), the thinner the pivot. What You are trying to do is possible, but forming the new thin pivot must be done on lathe. Thus the wheel will get shorter, but can have new pivot without the drilling for normal standard repivoting. Then piece of brass can be soldered under the pivot hole in the bridge and new hole drilled in it to form the new bearing.  Well, this way is not the recommended one, not quite correct, but it is possible to do for the excersize... When I say lathe, lathe may be verry simple, someting like turns, but made of what one has in reach of his hands. If You want to try, I will try to guide
    • yes by all means let's gather up our weapons tar feathers find the nearest tree in case Mark is not agreeable to our terms on our demands and storm his Castle. I don't quite understand what you're trying to do here? In other words you want Mark to somehow guarantee that the group will live on forever no matter what? You want Mark to somehow change his business model of what is trying to do or should we just take the group away from him? oh and is quite possible that Mark never realized that his discussion group would take on a life of its own. That the members of the group would like to continue on forever.
    • I'm not sentimental, I see it this way.  I inherit something I  don't like, I could sell it, buy something I do like and remember the person with the new item.  For example, I  inherit a watch ( I haven't), I don't like it, I  buy a watch I do like, every time I look at the watch, I think of the person.
