I honestly don't know how many lathes I have. About 5 years ago it was over 70. Counting Turns and Jacot lathes I am sure the number is well over 100. Some of the real expensive ones such as the larger size Derbyshire and Levin instrument lathes, a double pedestal Boley production Lathe and several more Levin WW (8mm and 10mm) lathes were not in the pictures. I also have two Sincere lathes. One I bought brand new years ago and another I purchased recently that is going to have to be restored.  If I have time I will post pictures of these at a later date.
I have been collecting these for the past 45 years and have no interest in selling them; at least not for several more years.
david
Edited by david
Well that explains why I can't find myself one then - you have them all! I have approval to ask Santa to bring one, but been struggling to find the right one at a reasonable price :-(
Edited by StuartBaker104
Stuart,
A lot of people buy these machines thinking that if they stay with an old school designer label brand lathe they can't go wrong. Often this does not work out as the purchaser does not have the necessary machinery and skill set to put the lathes back into original factory specifications. This could include designing components, turning, milling, lapping, surface grinding, spindle grinding, hand scraping and inspection procedures. Just removing the old paint and refinishing a machine opens up an expensive can of worms. This is usually beyond the budget and skill set of most watchmakers. The second problem then arises which is finding the necessary accessories in good condition in order to make the machinery actually perform usable work.
To the best of my knowledge the only companies left making small machines are Horotec, Levin, Derbyshire, Star, Bergeon and Sincere. The Derbyshire and Levin lathes are, in my view, the best of the lot (50 millionths spindle runout). The Star, Bergeon and Sincere are cone bearing lathes and, once adjusted, all work in a satisfactory manner. Of the remaining  three, the Sincere is the most  affordable.
Buying a used machine requires a considerable investment of skill, effort and equipment .Here is a picture of a Levin drill press that I helped my friend Tom Mc Allister restore.
david
15 hours ago, david said:
Stuart,
david
I would personally love if you started a thread on how to restore these old lathes.
I own a BTM lathe that I was given some 30 years ago when I was 13 which could do with a strip down and service before I start to use it and would love a thread covering the basics on cleaning and restoring lathes like this.
Tmuir,
I have only seen pictures of the BTM lathe and have not seen the actual lathe. I looks almost exactly like a Geneva style Boley but I don't know if the companies were connected in any way.
Mark Lovick has a video on Youtube showing the disassembly and assembly  of his Sincere lathe. I think the video was about changing the drive belt but also shows how to take the machine apart and put it back together.
david
On 12/16/2016 at 12:57 AM, david said:
Stuart,
david
Thanks for your advice David. I had been considering a used but recent looking Star lathe which was up for £500 as a slightly more expensive solution to a vintage gamble, and your post almost pushed me into doing that... but it sold earlier today.  Will keep hunting with your thoughts in mind.
Stuart
Edited by jdm
Please don't include pictures in quoting
Stuart,
Take a look at this before making a final decision. A basic package can be purchased from Sincere for far less than this more complete set. I purchased one years ago and have been very happy with it. Both Colin Andrews (The Great British Watch Company) and Mark Lovick (Watch Repair Channel) have these machines. I am happy with mine and I have not heard any bad reviews on this equipment.
david
Edited by david
i purchased it all from sincereclocks on ebay roughly 8 months ago, i cannot remember the price but it has gone since i originally looked a year before . i wish i could spend more time on it , hopefully i would get some time over the holidays...
That is an awesome!! I'm trying to find a lathe too. I recently ran into a problem with screws for an invicta watch that were stripped and missing some length. I thought to myself if I had a lathe I would have just made four new screws. If any one knows of a lathe for a beginner let me know. Thanks Jeremy.
I see that you have many lathes that seem to pretty much the same (last pic in the first set), any reason why?
I understand that sophisticated tools have an engineering beauty that goes well beyond common uses object, like -for example- watches. At the same time, the pleasure of collecting items (in a large quantity) which are meant to make other objects, escapes my comprehension.
Buying new, the most likely candidate is the "sincere" Chinese lathe mentioned and pictured above.
The sincere lathe can be found on ebay.com but not ebay uk, although it appears they will ship to the UK. Sadly, it looks like £500 for the lathe, £250 for a set of collets plus shipping and duty, which is going to take this over £1000...
Will keep hunting :-(
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
