david
Some Of My Watch Lathes
JDM,
In the watchmaker style lathes there are three basic designs. These are the JACOT, WW, and GENEVA style lathes. The reason they look similar is because I have more than three. I have other small lathes such as two UNIMATS but I do not consider them to be watchmaker lathes. The reason for having so many is:
1) I like the machines and enjoy restoring them.
2) An investment for my later years. The increase in value of these machines has far outpaced my 401K.
david
Share this post
Link to post
19 hours ago, StuartBaker104 said:
The sincere lathe can be found on ebay.com but not ebay uk, although it appears they will ship to the UK. Sadly, it looks like £500 for the lathe, £250 for a set of collets plus shipping and duty, which is going to take this over £1000...
Compare to the Vector for GPB 3,900 which is the same product, full options and boxed.
https://www.hswalsh.com/product/vector-watchmakers-lathe-hl11
Attached for reference the summary of prices and ebay Items from "sincereclocks"
This is not a cheap hobby. But still cheaper than others:D
LATHE PRICE (1).xls
Share this post
Link to post
On 17/12/2016 at 1:53 AM, david said:
Tmuir,
I have only seen pictures of the BTM lathe and have not seen the actual lathe. I looks almost exactly like a Geneva style Boley but I don't know if the companies were connected in any way.
Mark Lovick has a video on Youtube showing the disassembly and assembly  of his Sincere lathe. I think the video was about changing the drive belt but also shows how to take the machine apart and put it back together.
david
Hi David,
Sorry for being slow in replying I've had a busy few days.
The BTM was made in England for the British military and their allies during WWII and is basically a direct copy of the Bolley lathe as for some reason German made lathes were in short supply in the UK during this time. :D
I have never had access to a Boley lathe to compare it directly to my BTM to see if the parts are truly interchangeable though, but I am guessing they would be as it would of allowed what Boley accessories were in the UK to be used with the lathe.
The lathes have two finishes, 'War Finish' with is black crinkle paint on the stand and grey paint on the rest, or those that were made after the war have a chrome finish which were made to sell to the general public. Obviously after the war many became war surplus so 'War Finish' ones are more common.
Is the video one of Mark's premium videos as I haven't come across it on his youtube channel and have yet to subscribe to his premium videos although I can see at some point next year it will become worth my while.
Tony
Share this post
Link to post
Tony,
If you take it apart clean  all of the bearing components (spindle, cone bearings, thrust bearings) and make sure there is no grit or other contamination on the surfaces. I like to use hydraulic oil as a cleaning solvent. When I reassemble the spindle components I wack the collet end with a piece of soft wood to help seat it. I then tighten the nut in the back until the spindle begins to bind. After that I back it out by about 1/4 to 1/2 of a turn and the spindle should turn freely. You can then run it for a few minutes and check for any heat build up. When it runs without end shake and there is no heat build up you have it adjusted properly.
david
Share this post
Link to post
Thanks David.
I've yet to get it out to check as Christmas preparation got in the way. When asked by the wife to stop what you are doing and help sort out everything for Christmas I know better than to argue with her.........
Share this post
Link to post
Santa was good to me today... my Boley & Leinen lathe arrived as expected. I will have to strip it down and clean before trying it out as it's very grubby.
At the risk of starting an international incident, can I please ask for suggestions on spindle oils that I can buy in the UK? I have seen that I can buy Castro Hyspin 32 in 5l cans from RS components for about £20. Seems like a lot more than I need, but I can't find anything else obviously suitable in smaller sizes.
Also how about suggestions for oiling the cross slide?
I've seen that I should use petrol to clean it with... but disposing of a large quantity of dirty petrol won't be easy, so planning on white spirit :-)
Thanks
S
Share this post
Link to post
I'm not sure of the correct oil to use but if you go to Myford lathes they have several different grades purely for general oiling and one for headstock bearings. Sold in 1 ltr cans.
Myfords are small lathes but well renowned for their quality so I would think if the lubricants are ok for their machines they would be ok for any small lathe
Share this post
Link to post
I have found that hydraulic oil has a good viscosity for the cone spindle bearings. I do not like extremely thin oils such as 3&1 oil. I personally like to have lubricant on any two rubbing metal surfaces. As long as the surfaces are wiped clean and re-oiled on a regular basis to prevent the build up of gunk, you should be in good shape.
david
Share this post
Link to post
Thought it was time to share some pictures of my new lathe now it's all cleaned up. Sorry, no pictures of it in pieces, but my hands weren't in a fit state to touch my phone or camera.
It was extremely grubby and the rear bearing was very tight on the spindle and took some removing and a bit of polishing to make it fit properly, but apart from that all was very straight forward and it seems to run very true and smoothly when adjusted. The cross slide has lost most of its plating, but the slide rails are adjustable to take out any wear.
I patiently rewired the 50 to 60 year old motor controller (sewing machine type), only for a big capacitor in it to go bang after 5 minutes, so I decided a new motor and controller would be a better bet. That's still in the post, and I'll wait for it before mounting on a board.
I would like at some point to find a tailstock drilling attachment - one popped up on ebay today, but it's expensive as it has a whole tailstock with it that I don't need and may not be able to shift on again. I also need to get the female end of the tailstock runner re cut as it's quite badly chipped.
I followed the instructions inside the lid and have boight some Mobil velocite #6 for the bearings. The cross slide has a thin smear of grease for now, so will see how that goes.
Edited by StuartBaker104
Share this post
Link to post
On 2017-01-04 at 5:15 AM, david said:
Stuart,
Your lathe looks like a real treasure. I hope it inspires other forum members to post pictures of their machines here.
david
Ok, here are some pictures of the lathes i use at the moment!
The lathe I use the most, Boley/Leinen Reform
A sturdy Boley used mainly for lapping details on watch cases
For bigger objects I use my Boley Prec.2
Currently under resoration, a Wolf / Jahn 8mm lathe with a whooping 493mm bed - intended to treplace my Boley for lapping jobs etc.
And finally a Harrison M250 - used for making parts, jiggs etc. for the lathes etc.
Edited by RCDesign
Share this post
Link to post
So I went to the watch and clock fair at the NEC last weekend. It seems to get smaller every time but it's only 10 miles down the road for me so it seems churlish not to pop along.
I did have an objective, which was to talk to the people from PennyFarthing tools about tailstock drilling attachments for my lathe. Their answer wildly exceeded my expectations and for £35 I bought this which is a ground bar fitting my tailstock with a taper fit precision 3 jaw chuck.  They make them in house and at it's first outing I used it to bush a watch barrel.  May be a bit of a stretch for pivoting but very happy so far.
Share this post
Link to post
Loading...
    • Hi *, Originally I did not introduce myself thinking noone is really interested who I am but after a few months and after receiving so many friendly advice and comments I felt i must do it. The story is started with this one: WWW Eterna I knew absolutely nothing about clocks and watches apart from the fact that they do show the time and you can overwound them.  Now i am on level 3 with the course and I have already serviced a few watches and clocks. I seem to like clocks more than watches but time will decide. I want to live a 1000 years to see all type of clocks and watches and to try all the food we have on this globe.  Id like to learn more about clocks and watches and I would love to have the experience with them but I have a very limited time I can spend with them, anyway I am going to be the new Tompion. If you find a WWW watch in the dirt let me know I am interested in buying it. I am Hungarian but living in UK, Cambridgeshire so I am not just breaking the pivots, but English too time to time. Good luck and my best regards, lui
    • The cockroach  of watches.
    • Hello Clockmakers, unfortunately I could not spend much time with clocks recently (what a relief for them) but now I have to read about carriage clocks. I paid £48 pounds for this one without knowing anything about carriage clocks, sounds realistic but i dont know. I have already manually cleaned the case a bit, but did not touch the movement yet. What I noticed is that every brass piece has a number stamped in it: 756 What does that mean? Serial number? Or the type? Ohh and more thing. Should it be really shiny and polished? Generally speaking? Or shall we leave the patina on? Best regards, lui  VID_20191016_002219.mp4
    • Thank you. This repair forum is fantastic on many  levels the people on here are honest and reliable and makes the whole experience pleasurable.
    • Yeah, I have allways been that ”engineer” kinda guy these things are truly amazing machines and any kind of learning related to watches intrique me on so many levels! Hope you will get the appreciation that you earn at least from these comunities if not from your family and friends ps. The pun was nice
