orient 46941 regulating
nickpeh
Hi,
I tried to regulate the movement from orient 46941, it seems how slow i tried to adjust the reading still the same and time shown average 3 mins faster in just few minutes. Is it the problem lies on the beat error ? By using this software, beat error showed zero, so I eliminate the idea of that...any advice from u guys?
I am kinda new to watch disassemble, in this pic config will I able to remove the balance bridge assy ? I tried to remove but seems something not releasing from lower area , I am afraid to pull due to the hairspring. Do I need to remove any parts frm dial side to release this balance bridge?
High rate / low amplitude suggests that the h/s coils are fouling up on something.
You said that you have cleaned the h/s; when you reinstalled the balance did the h/s coils sit nice and concentric or were they still bunched up as in your earlier photo?
How did you clean the h/s?
Is the h/s sitting parallel to the balance with proper clearance to the balance arms and the cock?
Have you tried demagnetising it?
53 minutes ago, nickpeh said:
After several hours of regulating , seems cant get the gained rate lowered...wondering what could be the issue.
Something is fowling the hairspring at a guess. Your original post showed a good amplitude and the beat was within tolerance so something has gone wrong since your adjustments.
Is there an easier way to demagnetise?  I soaked in kerosene and leaving it to dry , repositioned it and anchored down.
Clockboy is right.  Raw kerosine is distilled from crude oil can also contain a lot of sulphur and other undesirables so is not suited for cleaning any parts of a watch unless very very dirty with old caked oil (then need to ensure you clean off all the kerosine).  It can though be used as a penetrating oil to ease tight fitted parts.  Rather than use raw kerosine use BBQ lighter liquid fuel as this is basically de-odorised, de-sulphurised and cleaned up kerosine.
Edited by canthus
fact
I did degreased it after soaking in kerosene using solvent, but after detailed inspection, realized hairspring end was slight bent causing the balance wheel unable to stay center. I will get new one to replace.
orient 46941 movement seems no banking pins, so now is it align the balance wheel impulse pin between pallet fork?
