Replacement movement for Citizen watch
Davey57
Would anyone know whether there might be an equivalent modern replacement for a Citizen watch movement. The watch in question is an Eco Drive 0855 chrono. The watch itself is in great condition but the movement is rendered useless by a broken pivot on one of the flimsy plastic train wheels. I could eventually find a donor watch I suppose but if a new moment was available at reasonable cost it would make sense to fit one. I understand that Miyota and Citizen are one and the same, might there be a Miyota equivalent. I have tried to find some kind of cross reference document but with no joy.
Or, if anyone might have a scrap movement of one of those calibres from which I could harvest a replacement for the broken part I would be happy to buy it.
Many thanks
Same as almost everything that is new?  Movement doesn't exist? Or breed of watch enthusiast will die out . Try finding a new or a couple of year old Seiko movement? There aren't even parts available for them?
Buy and trow them i the out  when the get broken. Funny to buy a watch for lots of money and none can fix it .
I stick to the old as long as there are parts.
I can get a couple of pictures tomorrow. The watch is completely stripped down. I will measure the main plate or, in this case, the plastic bit.
I don't think it is a particularly new watch, I think they have been around a while. Cousins list the 0855 as obsolete. They have stock of 0870, the only difference "afaik" is it has a date wheel which doesn't matter but, they are £50 and the watch isn't really worth spending that sort of money on.
Good day. I've found that the Citizen parts are often more available than they first appear. The trick is to figure out what the Miyota movement number is. It is not always the same as the Citizen reference.
For example - I recently needed a rotor for a Citizen movement F500. I searched high and low, and the only option available was directly from Citizen. Cost prohibitive, and unless you have a silver tongue, they do not want to sell you parts over the counter. Thought that watch would be end of life. As others have pointed out, they don't hold a lot of intrinsic value. I happened to stumble on to the fact that 'F500' was a Citizen specific re-label of Miyota's FS00 reference.
Lo and behold, that part was available from Cousins (as a movement listed, or just the rotor by request). Ended up being cheap as chips, and a rather simple repair. Heirloom watch? No. Worth cost of repair? Absolutely.
Good luck!
Jules Borel is your friend... but it doesn't get you a much cheaper solution.
If you search their database for the 0855, the only part available is the capacitor, clicking on that also turns up the Miyota 0W50, which is the same as Citizen 0850.
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=Ve_BYM
Cousins offers you a link to the parts lists for both, so you can check if the part you need is the same. https://www.cousinsuk.com/PDF/categories/2620_Citizen 0850,0855,0870,0875.pdf
Bad news is that parts for the Miyota movement are also not available and the movement is £40
In the screenshot it is part number 30, the 5th wheel and pinion. All of the other gears that look like it are white but this one is the only grey coloured one. Might help you spot it if you have one. Unfortunately I have also discovered that the two small contact springs are missing, 2nd screenshot.  I was given this in pieces in the hope that I could get it back together.
If you have any parts that would be fantastic. Thanks very much
Nice piece of detective work. Thanks for the info. I will have to give that a go and see how to do it for future reference.
It's beginning to look like I will just have to keep my fingers crossed for the one for sale.
I have checked the part number on the Citizen website and it shows your part number as being the hour wheel. From the same list the number for the 5th wheel is 084-190.
Does the part in your packet have a hole right through the middle? If so unfortunately. It's not the right one.
Thanks for trying anyway.  At least I have the Citizen part number now. Strange but the document from Cousins has completely different part numbers.
I will have a dig about on the net with the Citizen part number and see what turns up.
Cheers
Dave
I love it when a story has a happy ending, especially when you need to piece together lots of bits of data from different sources!
Cousins database often doesn't know the full application list of parts in their inventory.  I have seen this many times, but if you can get to the raw part number then you can often find parts they don't list against any calibre.  I think they will add parts to the list if someone asks for it by calibre number and part type if they can then track it and it's in their stock.
If you want to buy screws for Omega movements you just search for the screw part number - they never seem to list them in the calibre parts database.
  • 3 years later...
1 hour ago, alex771 said:
есть еще запчасти для данного механизма?
If you read above that will pretty much answer your question of parts availability.
Please note this is an English language forum and is not very polite to have others to use a translator to understand you.
   "polite"    we don't need that here.   vin
  • Confused 1
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
    • I think attaching a nut to the lid to pull it off is the least destructive, any damage damage on the outside is going to an easier fix than any created when trying to push it out from the inside. Scratching up the inside of the lid , mainspring or arbor bearing will be risk. Just my opinion.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
