Hi all - new member from the South Coast
oli
Hi all
Well, after a very long time lurking, I thought it was about time I joined this forum! My name is Olivier and I live in the UK, in the South Coast area.
I have been a watch collector for a many years. My interest (obsession?) for working on watches started a few years ago, with a cheap tool set from ebay, and the plan to customise a Seiko SKX. It turned out great, and by then I was well on that slippery slope!
A few years down the line, I have a little workshop area setup in my house to practice and enjoy the hobby. I mainly work on Vintage Mechanical Seikos.
I have learnt so much through reading threads on this forum, I hope I will be able to contribute as well.
I will conclude my first post by thanking Mark for sharing his knowledge on his youtube channel - It has been inspirational for me, to the point that I have now decided to take the hobby to the next step, I will soon be starting formal training with the BHI.
All the best
Oli
Hi all and thank you very much for the warm welcome. I'll try to answer all the questions in this post (sorry multi quoting is not my forte!)
This is a photo of my collection of Seikos as it currently stands
Photo%2014-08-2016%2C%2017%2023%2059.jpg?dl=1
I say currently as it is only transient... Over the years I have had an MM300, a Samurai, a Quartz Grand Seiko SBGX005), 2 pogues (one yellow one blue), and a very rare SBQJ019 (GMT & perpetual calendar) to name the more notable ones. I guess that makes me a bit of a Seiko nut but I do also collect other brands!
Sorry I don't have a photo of my first mod to hand, but I will look for it next time I'm on the computer.
The BHI course I want to start is the distance learning, technician grade, with tutor feedback. I will probably go on 1-2 practical courses, but I want to focus on the DLC first.
And I am not sure what the earliest Seiko I have taken apart is. It would be from the 70s for sure, i have worked on 7S26, 6309, 7548, and 7009s.
Thank you all for your responses and friendly welcome
22 hours ago, Cad101 said:
 Some pics of your mods
Found my first one! It was filed in my laptop in my 2011 folder... I didn't think it was that long ago! It takes me back a bit
it was based on a SKX. The mod consisted of the following:
Military dial and sword hands
New Seiko bezel insert and hardlex crystal
Aluminium chapter ring
vulcanised rubber strap from Cousins.
Bearing in mind that before I did this I could just about remove a strap, it felt like a huge achievement at the time :)
On 21.8.2016 at 0:40 AM, Cad101 said:
Nice looking watch big bold and bright. At the moment I'm waiting on parts from mother Russia for some vostok amphibia mods. But the post is a nightmare at around 5 weeks ah well only 4 more to go :D
Patience my friend, patience. Think of other things, and suddenly the parts comes...
So many fine looking old Seikos, Im too into mostley Seikos myself too, divers.... That 6105-8110 is it with an aftermarked dial or original?
On 19.8.2016 at 10:11 PM, oli said:
Hi all
All the best
Oli
Hello, and very mutch welcome. You sound like a good chaps, since you likes Seikos. I also have a pogues, there are nice watches...reminds me of the old days....
Hi all
All the best
Oli
Welcome to us! This is a great site, with lots of nice people...
    • It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position.    So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff from the seat-side out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it worked perfect 🙂 I'm very happy how this method worked out ! 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
