  On 9/29/2023 at 2:16 AM, nrm said:
I've got a couple watches lined up in addition to the one I posted about in the Newbie repairer category
Expand
The Poljot looks pretty good. Its probably a Poljot 2614.2H, and parts are relatively easy to come by. Quite a few USSR era Sekondas share this mechanism.  I'm looking forward to seeing the Gruen too. I presume the button on the Ricoh is a date quick set. I'm not that familiar with Ricohs, so it will be interesting to see how that one is put together too. Watch out for flying springs on the Poljot date mechanism.  Don't ask me how I know. 🤨
I've got a couple watches lined up in addition to the one I posted about in the Newbie repairer category -- waiting for my confidence to arrive. Not a huge investment, but I'd like to give them the attention they deserve, and hopefully once I get inside, they deserve the attention I give them!
Something about having a small queue makes me feel a bit more urgency in getting stuck in.
IMG_0095.thumb.jpeg.42a9ef3416f96af6538ccc6a6ea35265.jpegIMG_0058.thumb.jpeg.3a7fb97732221f6443d74790c7d4eaeb.jpegIMG_0100.thumb.jpeg.02c107dd4f334b9d9b23002e96995f6c.jpeg
Expand
The Ricoh is interesting, plenty going on with that dial, i like it. The Gruen much more reserved but should be a good watch. Grunen for a time shared movements with Rolex, also dial names as seen here. Its not a Rolex but it is a Gruen nice watches matey šŸ‘
Another Accutron 214 found its way into my shopping cart. Not sure how that keeps happening...šŸ˜‡
I've always liked the railroad dials, and I'm a sucker for the blued hands.
This one was sold as running, for a nice change of pace.
Expand
You've been bitten by the Accutron bug!
It's here, and not only does it look great, but it's running out of the box! It's such a weird experience after all the busted watches I've been buying šŸ™‚
Seriously, I'm such a sucker for the blued hands.
  On 10/10/2023 at 4:59 PM, JohnR725 said:
As it's running out of the box can I assume that you're not going to service it?
Expand
Let's not get ahead of ourselves here. I'm not one to leave well enough alone.
That said, if it looks nice inside and keeps good time, it'll go down on the list and I'll just enjoy wearing it for a while.
Expand
May I make a suggestion? Why don't you just enjoy your watch and not worry about servicing it. Then if you lose your mind to decide the service make sure you invite me to the discussion as there's something you don't have.
Interesting timing for this somewhere else in the group I'm still composing a response that part of it has to do with updates to documentation which never find themselves down to the original documentation. Or basically technical documentation is generated at the time the watch came into existence. Technical documentation does not cover all of the variations changes updates etc. although that documentation may exist it doesn't necessarily find its way back to the original documentation.
For instance as this is a railroad grade watch did you notice when you're setting the watch it has a hacking feature? Typically in the railroad grade watch 214 version the hack is they are so that you can set the watch to the exact second. As this watch I believe would've been a railroad grade certified and hacking would be a must.
Expand
I did know that RR grade watches generally hack, but the seconds hand continues to sweep while setting on this watch. Come to think of it, I did notice the second hand jumps a bit when you start to set it, so maybe it's trying to hack but something is missing/out of alignment/broken.
I just opened it to check, and it is the correct 214H hacking movement, and has the same M5 date as the case, so I'm guessing it's right.
Also interesting that the movement plates are silver (steel?) and not the brass color of the other movements I have. I'll have to do some more reading on the history.
There was a lot of organic matter, so at the very least I'll be de-casing the movement and cleaning the case.
Anyway, I don't want to hijack this thread, so once I get things apart and cleaned up I'll start my own.
Expand
Yes I'm trying not the hijacked the discussion we can look at pretty watches technical can be somewhere else
the date codes as far as the case goes isn't always clear because sometimes I think the factory used whatever cases they had versus movements but yes if they're the same that is a good indication versus dramatic differences.
As far as the colors the plates go I've seen both of them I don't know why they change the colors.
Expand
Probably not broken and no you can't see the hack it's on the other side.
Tactical I'll give you is remember the case back as the crown and if there's a lot of dirt and grime under their it's spacing conceivably could change a little bit but the biggest changes spacing would be those back gaskets the original ones that we can't get anymore. So for the hack to work the back gaskets and exact location of the stem is extremely critical. Did I mention pain in the? Yes it's a pain the setup and delete something that you don't have any way so I wouldn't worry about it.
A Molnija (ŠœŠ¾Š»Š½ŠøŃ) 15 jewel October Revolution (ŠžŠŗŃ‚ŃŠ±Ń€ŃŒŃŠŗŠ°Ń Ń€ŠµŠ²Š¾Š»ŃŽŃ†ŠøŃ) USSR era pocket watch is on its way to the 404 club.
The Molnija 36xx movements are basically a copy of a CortƩbert movement used in Swiss watches from around 1940.
In a working condition, these are fairly popular, but this one appears to be missing the top balance jewel, as well as the bow. It was described as "Balance is not working", so the price was a bargain bin £1.99
Almost certainly needs the balance jewel, and may need a balance staff too. I think I have a scrap movement with the jewel, but it too needs the balance staff, so I may have to go hunting for some of those.
Edited by AndyHull
Not a watch, but still pretty exciting. I've been looking for small parts and tools storage solutions, and I found these nifty Bulova "Repair Master" stacking drawers on eBay. I got two of the two-drawer units, and one that's full of parts! The single drawer just showed up and the other two should be next week.
They're a little small to hold larger movements, but will be great for my drawer o' random tools and small parts. I have a bunch of tiny zip-top bags on order for corralling small parts.
Ɨ   Pasted as rich text.   Restore formatting
Ɨ   Your link has been automatically embedded.   Display as a link instead
Ɨ   Your previous content has been restored.   Clear editor
Ɨ   You cannot paste images directly. Upload or insert images from URL.
    • Hello, My name is David and I’m a vintage watch collector/ wanna be hobbyist watchmaker from France. I really want to progress into my watch repairing hobby. For now, I’m only having fun servicing my own watches and spare movements, simple small 3 hands from the 50s (Omega, eterna…) Learning step by step or at least trying to šŸ™‚
    • More setbacks and successes...  After letting the watch run in (but before I fixed the BE) a chunk of the radium lume fell off one of the hands and pulverized leaving radioactive dust all over the dial šŸ˜ž ā˜¢ļø ā˜ ļø So before I could continue further I decided I would remove the radium lume.  I have removed radium lume from hands before where it was already starting to flake away but this time I had to work out what I was going to do with debris on the dial.  I decided that getting everything under water and removing all the lume was probably the best way to go. So here is what I did... I put an essence jar I use for cleaning parts and filled it with water and put it into a big ziplock bag along with the tools I would need - a sharpened piece of pegwood and  a 0.80mm screwdriver  -  I put on a pair of nitrile gloves and a covid style mask and then opened the back of the watch. Now with the back off the watch I could do the rest inside the bag.  I removed the watch from the case and removed the hands from the dial (through the bag) and then undid the dial screws and removed the dial from the movement.  I then put the hands and the dial and the watch case into the water and removed the movement from the bag.  Carefully and slowly with one hand in the bag and one hand trying to poke and hold stuff through the bag I gently rubbed away the lume from the dial and hands with the pegwood. I then took the parts out of the water and removed the jar from the bag (leaving the parts still in the bag) - with the majority of the dangerous stuff now in the water I disposed of this (down the toilet) and gave the jar a good rinse in running water before refilling it and returning it to the bag where I gave all the parts another rinse in the new water.  I then took the parts and put the geiger counter over the top of them and looked at them carefully under UV light to see if there were any flakes still hanging on. I dried everything with some kitchen towel. Once I was finished will all that I remved the parts from then removed the gloves and put them in the bag with the paper towels and the pegwood and thew the bag in the household waste. Finally I gave the dial, hands and case another rinse in the sink under running water.  I didn't bother following up with a rinse in distilled water water because the water here is pretty clear of limescale etc and I find it doesn't mark! So here are the results of my weekends work! Timegrapher dial down (dial up is almost the same) The fixed shock setting New crystal - and lume removed from dial and hands
    • Hi and welcome! I'm new here too—greetings from Leicester, UK.
    • Image of the watch with new crystal. I am happy with how the watch has turned out, bought from Ebay for Ā£12 as non runner, and managed to get a donor movement from ebay for around the same price, crystal was Ā£14.24 from Cousins. The crown is quite worn but still easy enough to wind the watch, and the dial of the watch has a few scuffs and some dirt that wouldn't come off without me worrying about damaging the dial.
Ɨ
Ɨ
