A design for a belt-driven Jacot Tool ...... ?
17 minutes ago, mikepilk said:
I'm sure they are wonderful, at about 160 euros, but for the few times I use it, I'll have to stick with my cheapo Indian version (and keep an eye on ebay)
13 minutes ago, nickelsilver said:
Ha, yes, much less painful on Ebay! And secondhand, they are rarely worn or abused, since folks don't use them much, haha.
If the wife knew how much money I spent on tools she would probably have a heart attack (and me too if I started to count on it). Fortunately, watch tools are so small and seemingly inconspicuous that she suspects nothing and I can keep being in denial 😉
Edited by VWatchie
  • Haha 2
30 minutes ago, nickelsilver said:
Most Jacots I've seen and/or purchased didn't come with a burnisher
May Dad left the Jacot to me and I believe it is complete.  Here are pictures of the burnishing tool.
I have only used the sapphire burnisher when using my lathe.
Edited by LittleWatchShop
I've been looking at pivot file burnishers to use with the jacot tool i've just cleaned up, there are a couple of online write ups about making an homemade pivot burnisher, one using a drill bit the other a tungsten carbide. Links below.
https://joyofprecision.com/post/11833625959/making-a-burnishing-file
https://www.snclocks.com/TechnicalInformation/Tid-Bits/Tid-Bit-11-Making-a-Burnisher/
https://abouttime-clockmaking.com/downloads/Burnishing.pdf
I will have a go at making a couple of burnishers at the weekend, one finished with 600 grit the other 400 grit, see if they work or not.
Edited by valleyguy
43 minutes ago, LittleWatchShop said:
I read somewhere or heard someone say: "My greatest fear is that when I die, my wife will sell my tools for what I told her I paid for them."
I guess that could have been me! 🤣
I guess one easy way to determine if a burnisher is good enough is to have a long good look at the pivot and the pivot shoulder under really strong magnification in a stereo microscope.
that's actually a very common concern with the people at the various chapters of the national Association of watch and clock collectors. Typically it's not with the tools because there aren't that many people repairing their more people collecting. But apparently collectors don't like to tell what they paid for things. On the other hand just think of the opportunities later on for acquiring new stuff so there's always a positive spin on things and the person who's losing their valuable stuff probably won't be here anyway so why should you care.
 You can get even with her in advance, start selling her belongings now. 🤣
Edited by Nucejoe
So with this rationale, I guess we could say that there's a positive spin on robbery murder as it will enrich the robber and the victim won't care as he's dead.
In principle, I think it is wrong that someone can enrich themselves disproportionately at the expense of someone else.
you of a really interesting view of the world can't say I agree with what I see here at all.
20 hours ago, nickelsilver said:
Most Jacots I've seen and/or purchased didn't come with a burnisher, or if they did, it was a little skinny thin one for rounding the ends of pivots using the lanterns. Most don't seem to come with bows either, otherwise I've have a dozen bows!
I have the Bergeon burnisher and so far I've only done some pivot rounding. The problem is there's not a lot of space to operate the rather large burnisher. After all there's just a small part of the pivot showing through the disc and when I rotate the burnisher it tends to hit places it shouldn't. I'd be happy with a smaller and more nimble burnisher. Should I work on my technique or would I profit from a smaller burnisher? Any ideas how to make one?
52 minutes ago, HectorLooi said:
I think you are using the lantern. For burnishing the pivot, you need to use the appropriate size runner.
Yep lantern it is. I didn't remember the word. I'm talking about rounding the balance staff ends. I looked at valleyguy's links, sure I could just make a smaller version. Does anyone have experience on specifically making a rounding tool? Would that be even called a burnisher or just a file?
are you trying to get a really nice round surface to reduce friction? Because you're not supposed to have round balance pivots there supposed to be slightly flat.
Not round but rounded on the edges like they come new.
I was really hoping you'd go for round it's really nice when you reduce the friction on the end of the staff.
then I have a picture of the procedure but there's a problem in that that looks like a grinding stone?
4 hours ago, praezis said:
Burnisher for pivot rounding look very different from normal burnishers.
You can even use them for burnishing the cylindrical part in a lantern.
I don't suppose we can get a picture?
oh and of course the other problem is doesn't look like it's being used on the particular tool of this discussion so it's probably irrelevant but the idea still there
Since we are (as usual) off topic;
Does one first do the pivot-end (if required) and then the burnishing of the pivot or first the burnishing of the pivot and then do the tip.
Some folk say that if you burnish the pivot first, you may scratch the surface of the pivot in the lantern?
Edited by Endeavor
You do the end after the diameter. You want to pick a lantern that rests on the conical part of the pivot, both to avoid scratching and so that enough pivot is exposed so you can work on it. The cylindrical part of a typical wristwatch pivot is perhaps 0.3mm long.
The burnisher looks like the photo, and resembles the last image in John's post above. Whether one makes a flat pivot, slightly flat pivot, or rounded pivot, is a matter of discussion (isn't everything in this field?). I recall in school our instructor saying that when the Swiss started supplying replacement staffs for American watches, folks had issues with rebanking. The story is the Americans tended to make flatter pivots, the Swiss, rounder. A flat/flatter pivot reduces the horizontal amplitude somewhat, and can aid in equalizing rates between horizontal and vertical.
On the left is a Bergeon normal burnisher, the right the pivot rounding burnisher. It's essentially a flat escapement file with the teeth ground off, with straight grained lines just like the normal burnisher. It's really important to finish off by knocking off the burr formed when rounding the pivot; this does take some practice and a bit of a knack to get it to break off cleanly without scratching the cylindrical part. Basically, you come around with the burnisher until it's almost in contact with the cylindrical part. I do the pivot rounding in the lathe, with microscope, so it's clear when it lets go. Again, John's image actually depicts this, but it probably isn't clear the reason why the burnisher is going all the way to the cylinder like that. Also, I don't use a stone at any point in pivot finishing, it's all from the graver (cutting tool) then burnishers. That's how we were taught in school.
You can see the rounding burnisher isn't particularly small width-wise, but it has a very low profile, which allows manipulating it around the pivot in the small space around the lantern.
Edited by nickelsilver
  • Thanks 4
It is. A square Arkansas stone, that shall assure square  ends as a first stage.
Pic (22) shows the last stage with the rounding burnisher.
Imagine the burnisher level under the pivot: burnishing the cylindrical part (a remark by Alfred Helwig, Glashutte).
Frank
N.B. nice (as always) drawings by late Hans Jendritzki
Edited by praezis
Thanks nickelsilver that was really helpful. Are fine escapement files fine enough or do I have to polish and refinish the surface?
 A file, even a 10 cut, is far too coarse. It doesn't have to be polished, but all the teeth must be ground off and the lined surface made. A coarse India stone is about right, or a coarse (about 280 grit, 45 micron) diamond hone. It takes a while to get the teeth off, so still best to start with the finest file you can find.
    • I went with 8.90£ because 12th century Italian mathematicians are always excellent topics to bring up when trying to get your guests to go home.
    • As a beginner, I’ve found this forum invaluable. I doubt I would’ve persevered without its support. I’ve had the confidence to attempt things that seemed to me impossible only because I knew there were patient and giving folks gathered around this watering hole, available to share their skill.    I would very much like to know where to go if this one dries up and everyone needs to decamp.  There’s something special about the folks gathered in this group.  How to keep in touch?
    • After a 3-week work fiasco that took up 137% of my time, I was finally able to get back to restoring a G. Boley 8mm lathe I picked up on eBay. I still need to do a bit of polishing on the tailstock but it works very nicely. Before and after pictures below. In any case, when I was reassembling the motor I wasn't quite sure which side the pully attached to, or if it matters. My question is ... does it matter? The listing photo below shows it the reverse of how I have it now, but it seemed that the cord and the reversing lever(s) should be on the right away from the belt.
    • Thanks Richard.  That’s clear.   So - another question - how much latitude is there in barrel and spring sizing? Say I have have measured the ID of my barrel to be 9mm and (all other mainspring specs being equal), the closest match I can find for a replacement mainspring is listed with an 8.5mm barrel size, is it acceptable to fit the smaller spring in to the slightly larger barrel without compromising anything functionally?  I’m in this situation now with an AS 1686 which has a 9mm barrel, but the closest replacement I can find has an 8.5mm diameter listed in its specs.  I can find an alternative 9mm spring, but would have to accept a different thickness.  I’m unsure how much wriggle room is acceptable, or whether in mainspring sizing, there’s a priority - ie thickness over barrel size etc. Thanks again for any info.  Cheers, John
    • We already have a Facebook group run by Mark , so this is a bit moot. Search for “Watch repair lessons” group.   Tom
