The Joy Of Watch Repair
Which of the following gives you the most ecstatic feeling? [emoji23]
o "One more turn and it's all in!" - winding the mainspring into the barrel by hand
o "Fourth wheel in... Third wheel in... Escapement wheel in... And they are all turning freely! Wee!" - aligning the train gears into their jewels
o "swing please... Swing please... Yes!" - installing and seeing the balance assembly swing into action
o "0s/day...0.0ms...270 degrees... Straight line... Not bad!" - after regulating the watch
o "Such a pretty watch!" - admiring the assembled watch head without strap on wrist while still wearing finger cots
o "You know what? I fixed this myself!" - telling your wife/children/friend your new hobby
o "I can watch all these videos all day!" - gets popcorn and sit in front of the computer to watch Mark's videos
Best feeling...
'the click as the last pivot falls into place'
Worst feeling...
'the click as you tighten down the train bridge screw (means you've broken a pivot)'
'the 'oooHH sh!t' feeling when the watch you're working on hits your lap on the way to the floor'
Anil
Balance in and instant start for me! :)
Same for me !
Nothing is more depressing than doing all the dis-assembly, getting the parts fixed and cleaned, putting it all together and when the balance goes in, nothing happens...
I would have to go with when you drop that balance in and it comes to life on its own..
the worst is finishing up a restored watch and as you rubbing off something on the train bridge with some rodico and your thumb hits the balance and you here a click and realized you just broke your balance staff... I walked away from my shop for a few days after that one..
Id have to agree with Geo, that is always a guilty pleasure for me.
Personally for me its discipline of patience, patience , and more patience. Perfecting each stage and giving my very best efforts & concentration into each part. Hand polishing alone can take days or even weeks, but results are worth it.
I agree! And I should have added that aspect of watch repair. At this stage of acquiring skills, I tend to focus on servicing the movement. But I guess knowing how to handle crystals, watch cases are just as important... And satisfying!
First swing of the balance has to be right up there, but what about that feeling when you finally track down that elusive part after 3 hours on the Internet?
S
I know the feeling! I once had a need for several parts of a movement but had a hard time finding all of them, not to mention the cost has between piling up. But when I saw someone selling the same movement albeit not working and for repair, I gambled and grabbed the item. With my fingers crossed I waited for the movement to arrive, hoping at least the parts I needed are in good condition. Fortunately, the gamble paid off! Happiness!
For me finding the reason for a fault & fixing that fault.  A real sense of achievement :woohoo-jumping-smiley-emoticon:
When a customer would say I've had this watch or clock repaired, I've taken it back many times and it still doesn't work. When you repair the fault and knowing it is going to be satisfactory. That would be one of my best feelings, because you know next time the person wants something repaired there more likely to bring it to you then to take it elsewhere.
That's me too. And when the reading on the timegrapher is perfect after fine tuning the hairspring.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile, and not less mobile which is the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic and cohesive/adhesive resulting in low mobility?? This may explain the high price??
    • The description there is exactly how it's done, and it's very well written!
    • Would it be correct to say that the stronger the mainspring, the thicker the oil should be? So for a fusee mainspring, should a thick grease be used?
