Magnets do not go with  - Some hair springs, Watch tools, Automatic works, calendar works in fact anything that is used in a mechanical time piece that is non magnetic.
Magnets do go with - Iron filings, etchasketch game, door catches, motors, speakers, pickups, pinged away springs and components.
My advice - Move all magnetic devices away from your work area. I have one of the rubber mats you mention and I have removed the magnets from them so I can use it in my work area. Do this and they can be useful - do not and you will suffer the effects.
14 hours ago, wls1971 said:
Introducing anything magnetic into the work space when repairing watches is a no no I cannot see where it would be useful to have such a mat in watch repair. The only magnet I have is for those unfortunate times when a part does ping off into the distance I do a sweep of the floor with a magnet finds the part 99% of the time.
Now if your a big tea drinker I have a Chocolate teapot for sale somewhere.
Come to think of it, maybe he thought I was asking for flooring ?
Thanks
I use a vinyl board cover that you can get in larger sizes than the Bergeon mats. They come in larger pre-cut sizes and are a little cheaper in cost. I just obtained a large sheet and cut it to fit the entire table top. They usually come in the light green color and clean up easily. You can find them online in art supply houses or mechanical drafting supply houses and usually go by Vyco or Borco in the US.
Why is it that watchmaking work mats are always green? What's so special about the color green? I'm almost certain there's some traditional material-based reason, but I really don't know what it is. Anyone have any insight into that dark corner of horology?
To calm you down when you lose a balance shock spring, or screwdriver slips.
  • Haha 2
Hi According to the great and the good  the colour green was chosen because it reflects the right amount of light creating less eye strain. Not to mention as  Old  Hippy said you can find the parts easier. The colour green is in the middle of the spectrum of visible light. Blue/purple being the longest and the reds being the lowest in distance .
  • jdm changed the title to Bench Mat
  • jdm pinned this topic
Parts are mostly on the white to red spectrum with a little blue thrown in. Highly reflective. A matte mat makes sense for the reflectivity. Green and red are on opposite ends of the spectrum, but I was exaggerating/simplifying a bit with red and thinking copper. Thinking historically, it's not hard to imagine a watchmaker 100 years ago would have used a vegetable tanned-tan leather mat. About the right durometer. I've done a fair amount of leather work, and even did some semi-formal experimentation with leather treatments from that era, and I'm not aware of anything that results in that characteristic green. Rubbers in that era were, actually about the same color or black, but the black was early vulcanized and quite hard. The only other thing I can think of would be green velvet. That would likely be a covering over something, but if the knap (I think that's the term) was long enough, the fibers would "grab" anything and keep it from bouncing. I think I've seen cloth covered writing desks with green pads, and it seems like this could be a similar situation. I don't think they were velvet, or if they were, the knap was long gone. I could be way off base...
Edited by spectre6000
  • 11 months later...
Frankly, i think it's because Borco / Vyco drafting table mat comes in gray, white, and green.
White is hard to keep clean, gray is too dark to find steel parts on.
And the watchmaking work mats are the same exact material.
Edited by TimpanogosSlim
 Once upon a time we had in the UK Government Training Centers where unemployed persons could go for re training. The one in Leeds had a watch/Clock department and all the benches were quipped with the same as what Old hippy described, probably because it was relativly cheap, and the paper could be changed. I use a cutting mat with all the grid lines removed and or a large cork mat both work well enough and I no problems with either.
it's been awhile....sorry off topic
hows the vise working out? it looks really good. as long as I got you here got a question for you. bench mat, green or black? i know about green and eye strain, easier to see parts, etc but what about black? i did a search on here but didn't really find anything. what do you think?
Edited by MechanicMike
forgot a few words!
You mean vice?  Well, I quit smok'n, drink'n and chas'n women, so I am on the mend.
I am using both colors.  On the two watch benches where I do watch work, I am using green.  On the watch bench with the lathe, I am using black.  I think, qualitatively, that the black does reveal shiny objects better than the green.  I know this because all of the swarfs from turning are readily seen.  So, why don't I use the black one for working on watches?  I probably would if I did not already have the green in place.
There may be a great deal of personal preference that cannot be quantified.
I have a further thought to add, maybe valuable to other n00bs like myself.
It came to mind after i launched a cap jewel with the tweezers i was holding it with so that i could put a dot of oil on it. Because a droplet of 9010 has enough surface tension that the red oiler can pick it up.
In retrospect I know i could have stuck it to some rodico. I've been watching too many youtube watchmakers and i think some of them are showing off their skills.
10 years ago, during my initial foray into breaking watches for fun and expense, I came across a particularly sticky silicone mat at a freight salvage outlet that i like to browse from time to time.
It was marketed to the elder care industry, people suffering from parkinsons, etc. The picture on the package was of a lidded beverage resting on it at a 45 degree angle and not falling off.
It was a Dycem non-slip mat. One of these:
https://www.amazon.com/dp/B001VATDGK/ref=twister_B08B7MRJX9?_encoding=UTF8&psc=1
I did not pay that much. Because it was freight salvage.
It was bizarrely sticky. Parts dropped on it, if light enough, would just stand there at whatever angle they were at when they struck it.
It doesn't have an applied or impregnated adhesive, it's all van-der-walls forces and similar. It's a magnet for dust and fiber so it does need occasional cleaning. or frequent cleaning.
I don't know where my dycem mat is these days. Probably in storage next to the bag of watch straps that do not fit my gargantuan wrists.
But i found a lesser silicone mat in my accumulated junk that is at least a little sticky, and it works well enough at holding a cap jewel in place while i oil it. Also holds pieces in place for pegwood cleaning, etc. Larger flat pieces like barrel covers sort of have to be pried off it with tweezers.
It occasionally needs to be wiped down with some isopropyl alcohol on a paper towel or microfiber or whatever.
Cap jewels and similar items are easily handled with a silicone tip jewel picker. And easily found with an UV light.
7 hours ago, LittleWatchShop said:
You mean vice?
nope. I mean vise. But I still have a couple vices I should give up too! 🙂
thanks for the info. reason being is my local material house is out-of-stock of the spendy brand name green one but has the same in black at a huge discount. I might try one.
8 hours ago, TimpanogosSlim said:
I don't see how it would be superior to a twisted nodule of rodico.
Since it has an handle, doesn't catch dirt, and lasts forever, it's better than rodico for this task.
ha! same one I've bought since then and now use. cept green. but the very same and works well.
wonder why I don't get notifications of replies anymore it seems?
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
