I bought the L&R Master from this seller, and he did an excellent job on refurbishing it. He truly does deserve the 100% feedback... I would definitely buy from him again.
Funny I look most days to see what is about in watch tools and I know how cleaning machines can be pricey. A nice good cleaning machine is so much better then cleaning by hand which is something many on here tend to do. I have thought about buy one just to keep as a sort of memento.
Why? What it does that can't be done by hand or ultrasonic ?
If you have never used a cleaning machine you wouldn't know the difference. With a good cleaner and rinse the difference from cleaning by hand is unbelievable.
What if one uses the same solutions and give the jar a good shacking? Isn't just warming up and shaking that an non-ultrasonic machine do?
A cleaning machine also has a built in dryer it dries and doesn't leave any marks. Shaking parts in a jar you can do irreplaceable damage, not recommended.
A blown air dryer? Or temperature based?
A machine can keep your brain cells intact. Those who sits and cleans in the hand exposing themselves to a work environment like 50 years ago ... I could never dream of sitting and cleaning with toxic substances and solvents in front of my face ...
Why do the women sometimes are hard to be clever on? Think of all the times they have cleaned nails in acetone :-)
Sexism aside... I use isopropyl alchol in an ultrasonic cleaner far away from my bench. I don't think I'm placing my health at risk.
Great…. You mentioned just hand cleaning too ..... it is not healthy in the long run for those who choose this option!
I hope you saw my smile at the comment about nails cleaning
I simply meant "not using a specialized machine". I copied the term from previous postings. I also refrain from staying close to strong chemicals, it's common sense really.
On 5. november 2014 at 7:25 AM, SSTEEL said:
Me too, the end is in sight :)
Most of the screws and bolts etc need to be replaced, with the exception of the specialist screws/bolts, hopefully I can find these at my local hardware store. As you can see, many of rusted up, or chewed up.
15722540265_8326cc2345.jpgUntitled by Micky.!, on Flickr
Is the screws on the machine in inches or metric?
I have 2 of these type of cleaning machines in the loft from when I first started out at home and couldn't afford an automatic type machine, might have to dig them out and put them on the tinterweb, they are brilliant for someone just starting out. I used to set an egg timer so I remembered to move it round to the next jar and then put it on a socket timer when over the heater drying off.
These are cracking machines, one thing to be aware of is to make sure the jars are kept topped up with fluid, if you run them with not enough fluid in the jars it can burn the ultrasonic out.
there is a company in the uk that will do a full rewire, respray and replace the ultrasonics for a more powerful version for £1600. Sounds expensive but if you are after a cleaning machine that is upto standard for the brand accreditations then these are the cheapest way of getting a cleaning machine with ultrasonic that's  upto the standard the brands require.
That one doesn't have the transducer - but very true what you said.
I had two varimatics with the ultrasonic units but I prefer my elma super elite - it's manual but never have a problem with it, plus I get to keep the watch in the jars for much longer should I want to.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
