51 minutes ago, gary17 said:
hey
well that went well. Motor went bang and smoked.So now to find someone who can rebuild it.
cheers
gary
Well that totally sucks.  Where did you get the wiring advice from....not me I hope.
1 hour ago, gary17 said:
Well that went well. Motor went bang and smoked.So now to find someone who can rebuild it.
I had warned before, the motor looked toasted already and had to be treated and tested with care and some knowledge.
Anyway if you measure it and can find a new one, that will cost you much less than repair. Electrical motor rebuilding is another almost  trade, no surprise as skilled labor is charged gbp 50 to the customer, goods that used to cost equivalent of a month of salary are now available for a small fraction of that.
Hey
yer its definately just the wiring so should be an easy fix for someone who knows what there doing.
I cannot replace it really as there is no equivalent motor out there now, there all either to small or have the shaft off center. would not fit the machine set up and accesories i have. But trying to find someone who can fix a small motor no chance. if i had a fleet of submarines or aircrafts or even a few factorys they would love to help.
or a motor the size of a house.
its this damn throw away society thats killing us or at least not helping me get someone to repair it. lol
Anyone has any idea who may be able to help please let me know as googling electric motor repair is just for the big companies.
cheers
gary
Edited by gary17
49 minutes ago, gary17 said:
Hey
cheers
gary
I am trying to get someone qualified to take a look at my Pearl wiring to make sure it's safe and am having the same issue, no electrician wants to tackle a job that small. However, I think the answer is to talk to someone who specializes in "appliance repair", as there are number of those in my area and I would expect this would be right up their alley. Maybe try searching for someone who does appliance repair in your area?
I must say I have been intrigued by this long ongoing post. Some have suggested adding temperature controls or replicating the speed control my “ Janta” Pearl machine (which I own) Basically all are nice add ons but are really not required, providing common sense is applied. You wash for approx 5 mins in the jars and dry for approx 5 mins and that is it. This machine, we which sells at an incredibly competitive price gives the user full control and trust me gives great results. Here is a latest vid on the Pearl which is a higher spec machine that I own.
Basically he fills the jars far to much so he can not spin off and does not use L&R cleaning fluids which will give better results and finally the drying period used is far to long.
Clockboy, the video is the one I made this afternoon:)
So, he is me. I used zenith highly rated cleaning fluid and rinse. I did end up spinning the last two jars. Put too much cleaning fluid in the first jar. But the machine worked well. I did dry for 5 min.
No one would be willing to stick his neck out, in case you get zapped or burn your workshop down. 🤣
👍👍Your vids are great watch them all the time. The issues you seemed to have is the same I had when first purchased. You will find your preferred methods and cleaning solutions. For the really grubby parts I pre- clean to prolong the cleaners life.  I would not dry for more than 5 mins thou.
Appreciate the help. What cleaning solutions do you use?  How many min in each cycle?  And, I did not put in the balance or pallet fork.  Watch is now assembled and runs well however, if I loosen one side of the barrel bridge.....the fake Swiss RR pocket watch....which means the barrel gets jammed; likely another post.
I have tried a few but always go back L&R. I have kitchen egg timer and set it for 5 mins. The final rinse I only do 2/3 mins. The drying 5 mins. I am a bit worried about reports that shellac is damaged as I have had no issues. I did watch your vid on the fake pocket watch a new one for me. Still not sure how the hands are set some have button that has to be pressed to set the hands but cannot see one or is the spring not fitted correctly.
Fixed it and now it is working well.  there is a rocker with two gears on either side where a spring is used to push the gear towards the mainspring ratchet and if you reverse the wind, the other setting gear pushes toward the Minutes wheel.
👍Many railway pocket watches had a fail safe design so the hands could not be adjusted by mistake another design for the same purpose was the lever set . Looking forward to the next vid.
Hello Everyone,
Hope you're all doing well.
Just thought I'd add a little update.
I swapped out the UK plug I'd originally used with and "Active RCD" plug (Residual Current Device), these are designed to cut off power in about 40 milliseconds if there is an imbalance in power consumption between the live and neutral. By imbalance, I mean a human in the process of getting a shock. I replaced the 13 amp fuse with a 3 amp.
As already mentioned, where possible you should match the fuse in the plug with the max amps of the attached device, so if there's suddenly more amps used, the fuse blows, not the expensive thing attached to it.
I've also piggybacked this onto a surge protector as a "belt and braces" approach.
Finally, I don't think my heater is working correctly. But, I'm not that bothered. It contributes 100 watts out of the 140 watts rated, so not using it is probably is even safer. I use a heat gun on low/medium for the final phase. Being sure to keep the gun moving and at a safe distance of course!
Best regards to all,
Ed.
  • 4 months later...
I've run about 10 watches through my Janta/Pearl machine and during the 1st cleaning cycle on the last watch the unit stopped and won't turn on again. I've left a message with the seller but haven't heard back after 5 days.
I was also having another issue where the arm the basket is attached to kept wanting to not stay in a fixed position. So as it was in the "spinning" mode when spinning off the cleaning/rinsing solution, the arm would quickly just shoot to the top of the unit, spraying the fluid everywhere. I ended up having to stand next to the machine and hold the arm in place during the spinning cycles, which was extremely annoying.
So now I have a $600 door stop 😞
  • Sad 3
I bought a 70-year-old Elma for about $150 and it's still running like new even though it looks very worn out. They come up now on then on the flea markets.
Yeah, I was originally looking for a used one before I bought the Janta but didn't have any luck. I'll be keeping an eye open again. I really don't want to have to "fix" up something though, and a lot of what I see on ebay are units that have something broken.
I read this thread with interest. Are we talking about a new Janta machine or used.. The reason I raise this is I purchased the very basic model some three years ago and it has washed lots and lots is watch parts and sometimes small clock parts faultlessly..My machine has no timer so I use a kitchen timer.
I purchased this machine as an interim machine until I repaired my L&R Vari- Matic.
The L&R is still in my garage and to be honest I can not see the difference in cleanliness of the parts between the two machines.
Perhaps I have just been lucky..😊
Edited by clockboy
I purchased mine new from a seller on Etsy.
Is there a fuse or something in the machine that might need to be replaced?
Edited by GuyMontag
Hello all hope everyone is well. I have been away from this site for a long while and usually reside reside at WUS in the Russian section.
I am to a point now that I am going to start servicing the 24XX series movements and am thinking of purchasing the
Supreme watch cleaner. I have been reading through the posts and have read good and bad. It is a little scary as the place I am ordering from says NO RETURNS 🤨
 A few questions on the unit.
Have they improved the speed control to run the motor at a slower RPM?
Is a 1 amp fuse correct to install on the "Hot Leg" for the 110Volt unit?
Would there be an advantage to install a dimmer and a inline fuse on the heater circuit?
Has anyone re oiled the motor bearings yet? are the bearings ball or oi-lite?
Thanks so much your responses will be greatly appreciated, James.
P.S. I would also like to give a shout out to my buddy..... EndeavourDK
Hello Roland my friend I hope you do well, best regards sir.
Those movements are very interesting, fun, and educational to get started with. Good luck! BTW, you might find this service walkthrough useful.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
