Hello fellow watch lovers, I have just completed a build from part sourced from various sellers. It turned out to be the best build for me yet and I have 20200515_234824.thumb.jpg.5a1f8974dc75d6bbfaf0883500906b5d.jpg20200516_002855.thumb.jpg.a7dff742bc011aa2ae29e1930a9c722a.jpg20200515_230958.thumb.jpg.5b4a2db673437c4ac5f2257022d8cc7c.jpg20200515_231021.thumb.jpg.cc984a60524ca30223d95ef9ec48c65f.jpg20200516_002734.thumb.jpg.1bfcec482231023448dab44ebd6dc109.jpg20200516_002831.thumb.jpg.43831cb8e5f8fdf769aa46ead7ec9536.jpgreally amazed myself and the skills I had to exercise on this timepiece.  I have impressed myself with this one and it is a stunner with a salmon dial. The NATO strap is very lovely on this timepiece.  I apologize for the lack of details on this beauty, Enjoy
  • Like 7
You done very good a good looking watch for sure, you can be proud.
Is it based on a Landeron 48 or similar?
PS. Just a tip. the chronograph hand should just reach the outer perimeter of the seconds , now its just a tad to long ;)
I fabricated the second hand because they are impossible to find. I cut it down and bent the tip like the vintage hands a little to miss the crystal. No Landeron movement in this one. The dial and movement and hands did not fit so I had to make them fit.
I just searched ebay everyday until the parts were available. This type of dial is very difficult to find. I started with a case then I found the dial that fit that case and then find a movement that will fit the case. If it doesnt fiT then just make it fit. Saw, grind, file, paint, whatever u need to do to make it fit.
What movement did you use? Is it a true chronograph? Is it mechanical or quartz?
Mechanical movement using modified D304 and venus 150 parts. I just sold it on eBay within one week of being on the auction site. It is a beauty and did not want to let it go but I need a lathe
  • 3 months later...
  • 2 months later...
    • So if anybody overrides what i say, listen to them haha. I'm not an expert but i've just been in this boat a dozen times as i used to mess up hairsprings bad, but the good part of that was that i got to learn how to fix them.  What made my life SO much easier was learning how to adjust the hairsprings with the balance installed on a disassembled mainplate, unless it's a very serious problem or on an inner coil you can't get to i would recommend trying this in part because the spring will mostly ALWAYS look flat when the balance wheel is not installed on the cock. Install the balance wheel back in the cock and the cock with the cap jewels in the mainplate, with it installed even the most imperceptible twist will be pretty obvious. Just make sure the balance jewels are also installed. In these movements, if 99% of the time any twist or problems gonna be around the terminal curve, twists often near the stud, especially if you've been removing their awfully designed studs from the balance cock. If there's a reliable way to install those things without introducing a minor twist to them i haven't found it. they're an awful design. INstall the balance on you mainplate WITH your capstones/chatones and look sideways across the balance under magnification. Look for the highest or lowest spot of the now not flat hairspring. 180 degrees from that high or low spot is where your twist will be. You have to be VERY careful with twists as the tiniest over or under twist brings it out of flat. If the area i have to untwist is near the stud i just use a pair of #5 tweezers or some very sharp fine curved tweezers and gently see which way i twist it corrects the twist, then i hold the very fine point of the tweezers on the hairspring and just gently squeeze and check it and see if it started to correct it, then i rinse and repeat. Tiny adjustments is what you want, don't close them all the way, and dont' introduce a flat spot in them. it's just a little nudge by closing the tweezers on it at an angle. .  If the twist is not near the stud, i grasp the hairspring with some very fine curved tweezers as gently as possible while still holding it then i do that same sorta tweezer squeeze with my #5's.
    • Has it got the logo on the crown. I think you're best option is going to be to remove the damaged stem and measure it. Edit Do you have the case reference number.
    • Movement is Omega 1012. I bought this from Cousins:
    • Welcome to the WRT forum.
    • To get the full diameter, I'd have to take it out of the case, which I won't be able to do until the screwdrivers arrive.  I doubt that it's much use to you, but the raised rim on the case, encircling what you see of the movement, has an outer diamter of 28 mm and an inner diameter of 24.8 mm. The case outer diameter is 32 mm.
