Finding lost parts
Hello
I keep losing the clicksprings. My tweezers can't always hold them and sometimes they just fly away. I do use toothpicks to hold them too. I don't know if this is a stupid question, but does anyone have any advice on how to find them? Or how far they usually fly? I've recovered some, but not all and I work with cheap movement so buying new parts wouldn't make sense.
The movements I work on (Seiko 6xxx and 7xxx) usually doesn't have that kind of springs, but when they do have them (Seiko 66 or 6118 for example) I work under a transparent plastic bag so if they fly I should find them inside it.
I don't use toothpicks or pegwood to hold the spring anymore, for me it wasn't effective. Many people use a bit of rodico, and I use my finger (I wear nitrile gloves when working) covering almost all of the spring, and I use my tweezers to put the spring under tension. Then I make sure the spring stays in place while I carefully remove my finger.
To find a lost spring many people use a magnet, but I haven't tried it.
Until I lost a few click-springs myself I never paid attention to the plastic bag technique mentioned above. Since I have used it, I haven't lost one click-spring. I cut a sandwich sized baggie down the sides, put the spring near its final place, cover it with the single layer baggie and manipulate the spring, through the plastic, with my tweezers. Works every time. Good luck.
On finding getaway springs, I have used the magnetic bottom on a bolt-holding tray that is used for automotive repair. It's about 6" in diameter, with a 4" magnet on the bottom. I pass it over the area under and around my bench. And it has a very good rate of success. Good luck.
Edited by MrRoundel
Add magnet note.
Thanks for the tip. I've ordered a big 5cm magnet. I always thought they would be expensive, but apparently not. Anyways, thanks!
Thanks for the reply. I've always thought of the bag trick, but never actually practiced it. I tried cutting holes in a box and work with it like a sandblasting cabinet. It worked for a while, but soon after I just got tired of it. Anyways thanks for the tip! :)
To add to the finding side of the equation: They make magnets on sticks if you'd prefer to not be on all fours while you look.
https://smile.amazon.com/Fabcell-Telescoping-Magnetic-Pickup-tool/dp/B074P1NK2X/ref=sr_1_10?dchild=1&keywords=magnetic+rake&qid=1588463301&sr=8-10
Not necessarily the one I have or would get, but an example of what I'm talking about.
It does better with practice. Trust me.
Try not to lose them in the first place. Good tweezers and tweezering technique are essential. Get a good set of tweezers. A fine tip, medium tip and heavy tweezers. When I say good, it doesn't mean $$$$$. My favorite tweezer cost just over $1.
A good tweezer must have tips that meet evenly. No crossbite or crooked tips. And tweezers, like screwdrivers, meed regular maintenance.
When a part inadvertently flies off your tweezers, don't panic. Try to see the direction it flew off. Listen for any tell tale sounds of where it landed. Did it land on the bench or the floor. Personally, I hate it when it lands on the bench. Tell me, who has a clean, uncluttered benchtop. :D
I prefer that it lands on the floor. I use a flexible magnet strip about 14" long and sweep around where I was sitting. If that doesn't work, expand the search area. It usually doesn't fly more than 6 feet away.
Oh yes, check if it landed on your clothing too. I once had a screw drop inside my shoe.
Funny. I did something very similar. I kept having Waltham pocket watch shipper springs pinging into oblivion.
I remember when I was following the Timezone watch school courses about 15-20 years ago. One of the first things Walt Odets described was how to make a parts sweeper.
His method was to use a magnetic knife holder that people used to stick knives to their kitchen wall, add a couple of nylon feet so that is can slide around smoothly a few mm above the surface of the floor, and attach a small handle if you prefer. You can then use this to sweep around the area and then inspect it with a loupe to see what you have unearthed! :-)
24 minutes ago, eccentric59 said:
Murphy's law of lost parts states the probability of looking in the correct area of your floor is inversely proportional to the size of the part. ;)
O'Toole's corollary to Murphy's law (if it can go wrong it will go wrong) states that Murphy was an optimist.....:D
Everything I lose is almost invariably non-magnetic! A couple of weeks ago I lost the cap jewel from the 1965 Rolex cal 1200 I was working on  which is not the easiest movement to find spares for, and found it by eye under a set of drawers. (I still have no idea how I saw it)
I then patted it with a pea sized ball of rodico to clean off any dust or oil and promptly lost it inside the rodico! It took me longer to find it in there than it did when it was on the floor! :-D :-D :-D
I lost a pallet jewel once. It was there on my work mat one moment then gone the next moment. I used a torch and searched high and low. I was on all fours for almost half an hour before I gave up. I said a silent prayer and when I was stretching out my aching back, I caught a glint on the floor just outside of my search area. It really was the missing pallet jewel. :woohoo-jumping-smiley-emoticon:
So my advice is when you are already on your hands and knees, it doesn't hurt to pray.
  • Haha 2
    • With something like this a gasket seal for instance if i cant find the relevant information i would use instinct to decide what fits and works best. You have the original gasket ( well maybe its original or hopefully it is )so its fairly easy to determine what material to use. Shape , for that i would look at the gasket seatings, are there grooves or recesses in either the case back or case or both, what shape are the grooves, flat or round etc, how does the gasket sit and behave in those seatings. Next thickness,that is going to be a bit of a guess, especially if the gasket is a soft one that has been heavily compressed over time. This is where a selection is going to come in handy, personally i would be choosing one that is giving me the feel of compression as its coming into contact with both of the mating surfaces. But not so much that the gasket is going to squash out and become distorted, again this is guesswork and feel is required with the allowance of compression over time, something you may want to check after six months. This part is a little moot as without a pressure test, good water resistance is not assured so the watch needs to treated as such and not as if it were a new diving watch ( not that i would treat any new diving watch as if were ). What you want to expect from your efforts is a little accidental rain catch, if you want more water resistance guarantee then a professional gasket replacement and pressure test is what you should be seeking which will be more than the value of this watch. Coincidentally i have the same watch, been searching for a stem for it for a while now.
    • It might not be a hook it might be something like this. But still the mainspring is catching on something on the slip ring because it doesn't have its own outer slipping part like the modern ones. The image below came from some vintage Omega thing I'll have to see if I can find where that has gone to.documentation A different book has this
    • I did not see a hook on the slip ring. I will check again tomorrow.
    • I think I'm having a confusion here? You would apply the breaking grease to the inside of the barrel then the slip ring would go inside. Then the mainspring goes in and it catches on the hook on the slip ring.
    • Thank you for the once again very thorough and informative reply. I'm sure at this point it's academic, but I'm always curious to know best practices. This then implies that If I'm planning to reuse the old mainspring (which I am), I should also reinstall the slip ring. I will do that and apply braking grease to the inside of the slip ring as if it were the barrel. This makes the most sense to me. Also, that bit about the center cannon pinion is very helpful. That wasn't in the tech sheet I have (attached) dated 1970. Omega 1001(1).pdf
