V & C deck watch. Advice please
Good afternoon. I have got this watch which I believe is a silver German officers marine deck watch circa 1943 by Vacheron Constantin.
My father- in- law gave me the watch in the 1970's and I had it repaired as I remember the balance shaft was damaged. It's not been used since but it no longer works and I would like some advice on what to do please.
Would it be viable to get it repaired and serviced?  Where would I go for this?
Any idea of the likely cost assuming just a service is needed?
The watch has sentimental value so would not be sold. Would anyone have an idea of its value, as this may have a bearing on how I proceed. At some stage it will be passed on to the family.
At the moment it sits in this old watch box. I could just leave it as it is and admire it?
Any thoughts.
Because of its history with the swastika on the back. Many people collect anything of Nazi German memorabilia. I would think it would fetch a good price. The movement is high quality as well. If you do intend to sell it be careful, some laws prevent such items of Nazi German memorabilia from being sold.
Follow clockboys advice you can't go wrong.
It is a jewel.
What you can do, is to search for a high quality crystal for it and who knows maybe a spare movement. A rare piece is happier in the company of it's spare parts.
You will become an appraiser on it, as you hunt it's parts.
Good luck.
A  example Issue number M10822 exactly the same model sold at Mellors and Kirk auction house in Nottingham for £3,200 in 2018 it carried a pre sale estimate of £4,000-5,000 so would expect your example to be in a similar price range.
Any thoughts.
    good show.  keep it.  nice display box,   restore that.    i think the M is for navy.     vin
Thanks for all your useful comments and advice. In view of what has been said, I would like to get the watch working and will see what the pocket watch repairers in Oxfordshire have to say.
Regards
Paul
Page 235 of Konrad Knirim Military Timepeaces has M9491 of this watch. It is a Vacheron & Constantin Geneve calibre 163 with Nickel finish.
It is a 'Class 1' 'Navigation watch (Class 1 being the best) so was for the German Navy as you have already mentioned
Sorry can't give you much more than that, but agree its a high quality collectable watch, so well worth fixing.
1 hour ago, Nucejoe said:
Is the small subsecond genuine v&c ?
Yes, there was also a more common deck watch by V.C that did not have a up down indicator  they turn very regular in auctions and go for around £1,500, there are also centre seconds deck watches by V.C.
Thanks for the info wls. I think min hand is rubbing on the crystal. I bet if op just get that sorted out, it picks up and runs.
I am fairly certain this is a caliber 162, as the 163 only has a seconds sub dial, while 162 also has an up (auf) and down (ab) indicator below 12'o clock, like seen on this watch. This is a winding indicator.
Edited by Thesecondtallestman
I'm only quoting the book, it could be wrong
    • Hi everyone, I put together a Venus 178 recently, but found that the hour counter "creeps" ie. runs when the chrono is disengaged. This is the similar type of setup as the Omega 861, where the hour counter is driven off the mainspring barrel, but stopped when the chrono is disengaged by a friction spring.  Am I correct in assuming that the friction spring for the hour counter driving pinion should be dry? I am guessing that the issue will be either the spring or the driving pinion, but while the driving pinion has some wear the spring looks decent.  I've attached a couple of photos in case anyone has any tips. Thanks in advance!
    • Thanks everyone for the replies. It seems setting the hand is a bit of a guessing game, and I thought there would be a very specific way to do it. Since the reserve indicator hand moves clockwise as the spring is wound, I tried setting it right at the start of the black side. But setting it there doesn't really make sense, because by the time the spring is halfway wound, the hand is only at the end of the red side... In my head halfway wound shouldn't mean the hand is still "in the red."
    • Lovely part of the country! I spend most of my days driving along the A64 for work in and around York. I'll be sure to drop plenty of questions soon! I've actually got a couple of watches on the way that I'm pretty sure I'll need some help with! They look pretty beat up from the pics but I love a challenge and an excuse to buy more tools 🤣
    • I have two of these in my home. You need to remove the movement from the case, take off the hands and remove the dial and take a few good photos of the front plate so I can see what the problem is. The round nut unscrews and the hands pull off pull them off from the center and not the tips as you could break them.
    • I asked the question of one of the sellers. Its for removing the pins and making the holes in motorbike drive belts. God knows why they were both in two seperate joblots of watchmaking tool, thats bizarre. I haven't posted your setting lever steel yet mike, been busy with my mum past few days and had a locked myself in at home lazy watch repair day today 🙂 but I'm out tomorrow so i will get it off to you then.
