I purchased a bag of shellac flakes off eBay and cannot get them to melt. Instead, they just get a little soft and sticky but won’t form a string when pulled from the pallet warmer. Applying more heat just makes them crisp up. I’ve seen several of Mark’s videos in which he heats up shellac and it melts nicely but I’m not getting the same results.
Is it possible that I’ve got a bad batch of flakes or is it something else that could be causing this? Would it be better to use a shellac stick instead of flakes?
Very interesting you should post this. I was thinking the same thing.
Off camera I started with my shellac flakes which I prefer but I had the same problem. Soft but not melting - was quite frustrating. Changed over to the stick and it was perfect. I have a huge bag of flakes but I fear they are now useless. Fortunately its not an expensive product.
Sent from my SM-G950F using Tapatalk
Thanks, Mark.
As an amateur watch repairer, it's good to know that it's not just me. I'll order some new shellac in stick form.
I don't have any experience with shellac bought in flake form but I am curious what would happen if you reconstituted them into a big mass. Bunch all of them together and heat them up. If this is successful perhaps the shellac can be used after all.
I suspect they may be adulterated with "something". Try dissolving them in denatured alcohol, mentholated spirits or isopropanol and then evaporating the alcohol off. Any other "stuff" may separate from the shellac. The flakes may be intended for french polishing, in which case the "stuff" may be some form of wax, which typically would not dissolve in alcohol.
Well that question got me googling...
There is a lot of discussion about this on the ”interweb”, but mostly in relation to woodworking and nail polish!
Shellac is a natural product, subjected to various purification processes prior to sale which have changed significantly over the years, so firstly, the shellac we buy today is likely to be much purer and more consistent than in the past.
Shellac flakes sold for making wood finishes definitely deteriorate with age. After a period of time the can no longer be dissolved in alcohol. I haven’t found out exactly why, but moisture, heat and light are all cited as causes. So, keeping your flakes in a sealed dark container would be a good thing.
Shellac in stick form will have a lower surface area for a given volume and therefore certainly less susceptible to moisture.
Once mixed with alcohol, shellac will start to react chemically, (search for esterification if you want to know more), and evaporation of the alcohol doesn’t get you back to where you started. This is why pre-mixed shellac varnishes have a short shelf life.
Shellac is chemically similar to acrylic, and hence made of long polymer chains. I’ve read conflicting information about whether these will cross-link in ultraviolet light (the process that causes unbreakable watch crystals to go yellow and brittle). However, I would expect it to behave in a similar way - again, this is a non reversible reaction.
All of this may go some way to explain why some people reprt there is no problem with cleaning pallets in alcohol and others saying it softens the shellac.
I’m now into this deep enough to need a good chemist to get me back out. Any volunteers?
Shellac is never useless Mark :). From small drawers to large antique cabinets it's a lovely and rewarding material to work with.
Yes, there are many varieties of flaked shellac, from the most common raw which may even contain pitch, to low wax, to wax free, which is clearer and more resistant to humidity. To remove wax from shellac dilute in alcohol 50% leaving it a week, then seep with paper filters.
Edited by jdm
The sticks that Cousins sells are really nice for work-cementing etc and work really well to set pallets, but that type dissolves in naphtha, which I use as a rinse. They sell a light coloured a dark coloured stick; I've only tried the light one.
Another type of shellac from cousins is shaped like large blobs, but that's more of a course pitch-like cementing variant that is useless for small work because of the amount of filler material in it. I have another big bar of shellac of unknown origin, which is useless for the same reason.
In the end I got some old shellac flakes from my friend, and they work excellent. No idea where they came from or what type it is, but my one teaspoon of lucky flakes will set a lifetime of pallets. :)
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
