Introducing myself - Jody
JWSimm11
Hello everyone,  My name is Jody and I am in San Antonio, Texas.  I became interested in watch repair a few months ago when I sent my  Longines Conquest chronograph purchased in 2012 to a watch repair guy because the chronograph pushers are frozen.  His diagnosis- replace the mainspring for $540 dollars-  it keeps perfect time....  when I received it back the case back fell off... it wasn't even tight! I question that diagnosis so I to do some research on mechanical watch repair.  This lead my Mark's videos and I was  hooked after watching the first one.   I am now working my way thru all of his videos... a new passion!!  Below is a picture of my watch after the back fell off.
Hi Jody welcome to the forum. Sounds like you have had a bad experience.  Pushers seize up due to ingress of water swat dirt, The fix the problem the movement has to be removed and then the pushers which contain small clips and springs. If you van supply photos of the movement and  the caliber number we may be able to find the tech sheet for your watch. It will give you a better understanding of what it comprises of before taking it apart.
He was probably "disappointed" that you didn't feel for his attempt, and so returned it hastily. You can check his professional affiliation looking at the AWCI directory online.
2 minutes ago, yankeedog said:
Pushers? You could remove  the movement  from the case and wash  it in hot  soapy  water.it would  most likely  free them  up.rinse in distilled  water allow to dry thoroughly  before reassembling.
Wash the  case that  is.
I'm a little hesitant to open my watch.  I saw a quote somewhere that said something to the effect of..."don't practice/learn on your own watch".  My regular watch guy retired last month at 82.  He serviced my watch 3yrs ago and fixed a loose screw that was preventing the autowind pendulum from swinging... charged me a grand total of $35 dollars.  I may just send it to Longines,  they offer a full service including polishing the case and bracelet for $390.  I may try operating the chronograph manually bypassing the pushers,  that should let me verify it's the pushers and not the movement itself.   If I do I will post a video of my efforts.
Interesting. What I see in your video is a phillips head screw holding the case clamp at an angle. I also see the case ring rotated a little. The stem should be centered in the cut-out part of the ring and the case clamps should be straight. I agree with Nucejoe --  I wonder if when your loose screw was replaced , the case ring shifted enough to block the pushers?
So,  I was able to manually start, stop, and reset my chronograph.  I then went back to my jeweler who recently hired the two questionable people that said i needed a new mainspring.  We open the back,  he loosened the screws and adjusted the movement ring... and like magic the pushers began working as designed.  Saved myself $540.  Thanks to Mark and all his great videos because my jeweler is just that.. a jeweler and only knows how to change batteries.... but he has an AWESOME SET OF TOOLS
P.S.  Hey Mark,  kindly do a Public Service Announcement concerning ''CHEAP WATCHMAKER TOOL KITS".   It did serve on great purpose...I realized you need to actually spend a little money if you want decent tools....  <Lesson Learned>
    • Yea a have given it a full service this movement is chinese 2813 whats the left angle for this movement does anyone knows  and how to do a remove the default 52 degrees on my timegrapher?
    • Sure! Some very accomplished repairers never use epilame! I have often wondered if it is worth the trouble. Not using epilame will shorten the service intervals though, but that could be better perhaps both for the owner and the repairer!? Speaking of oiling, I just read this: After WWII in the 1950s the first Synthetic Oils came on the market. Most watchmakers did not rush to use these oils since they were bad for business now that the watch serviced with Synthetic oil would not come back to him for service for another 5-7 years he would lose a lot of income. ~Ofrei.com   Anyway, I wouldn't be surprised if it would be more correct to think of epilame as a binder rather than a repellant. Until convinced otherwise that's how I will think of epilame.
    • I read that same article last night  H.  I think epilame is too much headache for me, sources aren't always accurate, some conflicting. Such is the GRAVITY of this situation, Is it ok if i just STICK  to a thixotropic oil 🤣
    • Not sure I follow along. As I stated in one of my previous posts, the epilame will remain intact between rubbing parts as long as the surface is lubricated by oil or grease. Maybe it's just a coincidence, but note how the epilame-treated surface is illustrated in @Waggy's post. It looks like the oil is exposed to a binder (epilame!) so that it can't move sideways.
    • The epilame under the oil will also be removed  Unless the oil makes a barrier between the epilame and the escape teeth 😅 I think i need two strong coffees now 🤣
