ETA dirty escapements
CaptCalvin
Why is that every escapement on brand new ETA movements that I see all look like this? Doesn't look right does it? Doesn't read bad at all on the timing machine though: clean lines, 310 amplitude and everything. So what's up with this? Is this just how 9415 looks like after some run-in?
Edited by CaptCalvin
No it doesn't look right. I guess only the person responsible at ETA factory may know what is that and why it happened.
But if you suspect it's lubricant all you have to do is to re-apply and check again after 24-48 hrs.
imageproxy.php?img=&key=8c41f123521b3122More images of the pallets. Also the escape wheel is covered in droplets of oil. Nobody else have ever had these observations on their ETA's? I still consider myself new to watchmaking but this seems to go against all the examples of good watchmaking I'd seen. All the ETA's I've ever seen in the 2 years I've been in this hobby, all brand new, looked like this...
The Swiss use something called Lubrifar to lubricate their escapement's.  It is a mixture of oil and Molybdenum disulfide. If you look on Pages 13 and 14 of the attached Omega document you'll see the reference to it.  As the Molybdenum disulfide is black in color that's what is your probably seeing.
Omega__8645_WI_40_rules for lubrication-2.pdf
AndyHull adds trying a spot of Molyslip on the jewels to his very unwise 0W30 in the Timex etc. 404 watch lubrication experiments. In other news, Swiss watch shops start selling AndyHull voodoo pin cushions.
Edited by AndyHull
But that's an ETA, and they recommend 9415, so they should manufacture with what they recommend ?!? And any deviation from stringent quality standards is unacceptable, no matter where the factory is located. BTW I'm not aware of ETA assembling mechanical outside Switzerland.
1 hour ago, Nucejoe said:
i finally found a way to make a payment, I think, and need some escape lube to hear some tic toc. So if I get no 300 degrees I can always blame it on you.:D
Lubrifar?  Mkebius941 ?
I think the consensus is that 9415 is best. I have used it three or four times so far and got excellent results. The small bottle is so big that will last not one by 100 lifetimes, if anyone wants to have some just le me know.
Would you gentleman decide which one.:pulling-hair-out:
Don't blame us for not being able to make a decision blame the Swiss. It's all their fault over time continuously changing which lubrication's and not explaining why were supposed to change. Then the various manufacturers that have had their own private lubrication's that were never going to get.
Then don't worry about the Lubrifar It's been around for very long time and a very long time ago we could got a kit to apply it I'm sure it was astronomically expensive and it's been long since discontinued so other than coming on a factory escape wheel we can't use it.
Then I've attached Moebius's Current lubrication chart.
Then we have the other little problem of time? The problem with the tech sheets are they range over quite a time span and lubrication has changed over that time span. So like the general lubrication guide shows 9010 used to be the choice for escapement lubrication. Replaced by 941 specifically for that. Then 9415 came out originally for higher frequency watches as it stays in place better. Then you get an either or and now it seems to be just 9415 for almost everything.
Then I think a lot of this has changed as we get modern timing machines we can see the effect of bad lubrication especially over time. We get the factories servicing their watches now recognizing that maybe the original lubrication rules just didn't cut it.   I think this is why you see the quantity of lubrication applied like the pivots has increased considerably because the old rules lubrication just didn't last over time.
tableEN.pdf tinf_9415_en.pdf tinf_941_en.pdf
tableEN.pdf 351.41 kB · 0 downloads tinf_9415_en.pdf 305.82 kB · 0 downloads tinf_941_en.pdf 297 kB · 0 downloads
I see the effect by ear, darn thing wont run unless I lubricate escape teeth, you want to see it on video? And not just one movement. Pin pallet ofcourse.
Thank for sending the links.  Best wishes.
5 hours ago, watchweasol said:
Hi  are these watches made and assembled in switzerland or are they swiss parts assembled in Asia as many are to reduce labour costs that may answer the question.
All my examples are from Bulova(Accuswiss), Tissot, Victorinox, and Mido.
From what I can tell Lubrifar Can be found on Rolex, Omega and ETA plus probably other companies. Then what they manufacture with and what they recommend is not always the same thing. They have access to stuff that we don't have yes it seems simple manufacture and service with the same stuff but that isn't always the case.
So no matter what you have to lubricate the escapement and the current recommendation until something better comes along is 9415. Just don't use too much especially on modern watches you lose amplitude but that doesn't mean you necessarily have to go as extreme about this as Omega does in their technical documents.
If this is moly grease, then it tends to coat metal parts with an almost permanent coating of molybdenum disulfide on metal parts and in this case, also on ceramic parts (the jewels) we have to assume.
Molybdenum disulfide is similar to graphite, both in colour and low friction properties, but molybdenum disulfide is better for certain applications. The grease may also contain some form of oil to keep it in suspension, and it may be this oil that is being liberated and then sputtering on the metal sides of the gear. Possibly the strange dispersion pattern you are seeing is due to the application of an oleophobic coating on those metal surfaces.
In other words, what we are seeing may be normal, for this application, however since watch manufacturers guard their secret sauce recipes very tightly, and thus, I can't find any online information to support these assumptions,  my observations are only speculation.
I have limited experience with MolyS2 in a different area.  I shoot precision rifle and some competitors use moly coated bullets for a variety of reasons.  I can tell you that once moly is used on a metal part that sees any pressure or significant compression (i.e. the inside of a rifle barrel), the moly is there pretty much forever.  These guys (not me fortunately) scrub and scrub their barrels and the moly stays behind.  it's a one-way-street for them.
I would suspect that the escape wheel teeth on watches lubricated with any moly greases or oils have a thin coating of moly in the metallic surfaces where the escape jewels contact the teeth both on lock and the slip phases of the escape movement.   Good or bad I cannot say.  I seriously doubt that there is any penetration into synthetic jewels, but I have no data to prove or disprove that aspect.  MolyS2 is dirty and get all over everything near it.  Like copier toner.
RMD
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile and is supported by the literature:   A review on control of droplet motion based on wettability modulation principles design strategies recent progress and applications.pdf   However the hole point is that we have less mobile oil so an oleophobic  would see to be the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic (beading) and cohesive/adhesive resulting in low mobility?? This may explain the high price??
