Pegging jewel holes
Lc130
As above, definitely use pegwood. I find that the quality of the pegwood makes a significant difference as well, some grades are easier to sharpen to a perfect shape. The indian orangewood sold by cousins, although a step up compared to toothpick, is not up to the job for small jewels found in watches.
Amen. I’m on the lookout for a much better quality pegwood so if anyone cares to mention a source in the UK or Europe I’m all ears.
Anyone sourcing folks with a majic pegwood up to the job, would make a living by it.
I join hands with pip, Thank the lord for the pegwwod we are about to receive.Amen.:jig:
Is indian orangewood a label? brand name? Or tells  the wood is off of some type of indian orange tree. If so plenty orange trees in my front yard so all I need is a pencil shrapener:lol: .This is got to be the stupidest question ever on forum.
BUY? being a Scot (now in Australia) why buy pegwood, just get a scrap bit of oak, ash, whatever as long as it is hardwood, use a tennon saw and cut it into about 1/4 inch squares, and chisle the end to the size you need. Failing that I have also reused Kabab stickes after a BBQ. :biggrin:
  • 7 months later...
Just took a look at the Cousins website. They have the Indian orangewood as mentioned by Oli above, the German orangewood he recommends, and swiss beech or hornbeam. All are at the affordable end of the scale. Then there's the luxury article from Horotec, which is described as Swiss gentian wood. I guess this is the sort which Nickelsilver praises above, in which case I assume the price is justified. I'm looking for something which will take a really fine, sharp but durable point, but still clean well.
Wouldn,t that be nice.
The gentian wood would be really fragile, it's close to pithwood in consistency. Great for polishing bevels, not much else.
Regular pegwood is light years beyond toothpicks, the "normal" horotec i described above is a-ok for jewels down to say 0.07mm no problem. You should peg the pallet hole jewels if nothing else, a good 30-40 degrees of amplitude lie there!
A bit of drift but still related to pegwood.
I have a table pencil-sharpener bolted to my desk. I use it to get a nice conical tip and then use a knife to get a fine point. If I hand shape the point I find I really need to focus on getting the tip central otherwise it wont spin concentric when you roll it between your fingers. Te sharpener does 95% of the work and I just contribute the last 5percent.
Note, while you may get by with a hand sharpener, the table type ones hold it  central better.
Anilv
Try getting yourself a couple of mechanical drafting pencils and a sharpener. These can really put a fine point on pegwood as shown in the photo compared to your standard No. 2 pencil out of a desktop sharpener.
sharpener.thumb.jpg.49a5bddfbb81972d6d199761fc1e9100.jpgS20191103_0003.thumb.jpg.76a33e311b2158f993c53203317b1278.jpg
Edited by eccentric59
    • How about using a magnetised screwdriver for picking-up and fitting screw, then run the assembly through a demagnetiser.  I know magnetism is a no no, but this method is less fiddly, and has worked for me on several occasions.
    • Find a plastic tube, cut longer than the K&D, put your tools etc in it and hold both ends.  The plastic shouldn't have any effect.
    • Hi, I’m thinking about upgrading my demagnetizer and wanted to check to see if anyone has experience (good or bad) with the Chinese knockoff of the Elma demagnatizer. At present I use the cheap blue job on watch movements and while a tad clunky it seems to work OK for movements. However it doesn’t really handle tools and other larger pieces (like my anvils which are very magnetized) particularly well. i also have a US made K&D demag unit but have put it aside permanently re: it is so strong I can’t hold the tools, anvil whatever stable enough while passing the piece through the donut hole and ultimately the piece ends up more magnetized then when I started. Feedback would be most welcome since I can’t justify the $299 for a Elma unit but can spring $49 for a Chinese knock off.   thanks jay
    • Hi there, welcome
    • Due to inflation our 404 club price cap seems a little unworkable, so here are some options to re-boot ihe idea - first three are what common currency to choose (pic 1  out of 3) the rest 4-10 are the price cap  (pick 1 out of the 7 options)
