Pegging jewel holes
Lc130
As above, definitely use pegwood. I find that the quality of the pegwood makes a significant difference as well, some grades are easier to sharpen to a perfect shape. The indian orangewood sold by cousins, although a step up compared to toothpick, is not up to the job for small jewels found in watches.
Amen. I’m on the lookout for a much better quality pegwood so if anyone cares to mention a source in the UK or Europe I’m all ears.
Anyone sourcing folks with a majic pegwood up to the job, would make a living by it.
I join hands with pip, Thank the lord for the pegwwod we are about to receive.Amen.:jig:
Is indian orangewood a label? brand name? Or tells  the wood is off of some type of indian orange tree. If so plenty orange trees in my front yard so all I need is a pencil shrapener:lol: .This is got to be the stupidest question ever on forum.
BUY? being a Scot (now in Australia) why buy pegwood, just get a scrap bit of oak, ash, whatever as long as it is hardwood, use a tennon saw and cut it into about 1/4 inch squares, and chisle the end to the size you need. Failing that I have also reused Kabab stickes after a BBQ. :biggrin:
  • 7 months later...
Just took a look at the Cousins website. They have the Indian orangewood as mentioned by Oli above, the German orangewood he recommends, and swiss beech or hornbeam. All are at the affordable end of the scale. Then there's the luxury article from Horotec, which is described as Swiss gentian wood. I guess this is the sort which Nickelsilver praises above, in which case I assume the price is justified. I'm looking for something which will take a really fine, sharp but durable point, but still clean well.
Wouldn,t that be nice.
The gentian wood would be really fragile, it's close to pithwood in consistency. Great for polishing bevels, not much else.
Regular pegwood is light years beyond toothpicks, the "normal" horotec i described above is a-ok for jewels down to say 0.07mm no problem. You should peg the pallet hole jewels if nothing else, a good 30-40 degrees of amplitude lie there!
A bit of drift but still related to pegwood.
I have a table pencil-sharpener bolted to my desk. I use it to get a nice conical tip and then use a knife to get a fine point. If I hand shape the point I find I really need to focus on getting the tip central otherwise it wont spin concentric when you roll it between your fingers. Te sharpener does 95% of the work and I just contribute the last 5percent.
Note, while you may get by with a hand sharpener, the table type ones hold it  central better.
Anilv
Try getting yourself a couple of mechanical drafting pencils and a sharpener. These can really put a fine point on pegwood as shown in the photo compared to your standard No. 2 pencil out of a desktop sharpener.
sharpener.thumb.jpg.49a5bddfbb81972d6d199761fc1e9100.jpgS20191103_0003.thumb.jpg.76a33e311b2158f993c53203317b1278.jpg
Edited by eccentric59
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
    • Hello and welcome to the forum Dan. Used to know Middlesboro quite well, that was twenty years plus ago. Attached a little reading to get you started. TZIllustratedGlossary.pdf
