Showing content with the highest reputation on 03/28/24 in all areas
  1. Heres my watch of today, a Smith 13'" RY . My missus bought me this for this Valentines day a bargain 14.99 with a reduction, the seller has occasional 20% off offers now and then so it was about 15ish with delivery. I love Smiths and i love bulleye dials, this is my first one. The watch arrived non working as stated and i knew what was inside and what would be against me, but i enjoy a challenge, we dont expect a lot if anything from pin pallet movements. A balance pivot was broken and i didnt have another staff but i did have another RY with a battered dial so i robbed the balance and tweaked it around to make it work apart from that mostly just a good clean and relubrication. Keyless works are pretty rough by design and the crown is a bugger to get in and out with the dial on, the setting lever hits the dial before it releases it, so a little mod is needed to help that along. Major problem was the pins on the lever were quite worn which make the old tg have a snow storm fit. Its a similar read for most pin pallets, these were brass as was the escape wheel. But perseverance is me, i didn't change the pins but i did spend some time dressing and polishing the worn areas which improved the trace a lot with some straightish lines and a beat error of .5 . Not sure what the lift angle should be on these and i Wasn't in the mood to work it out and who believes timegraphers anyway, but at the default 52° it runs with 260ish full 210 after 24 hours dial down , the verticals rates were pretty much all over place. So lets just put it in it's superlight aluminium case and see what happens. Been wearing it now for 3 weeks and it's consistently losing around 1.5 minutes a week winding each morning i think pretty good for an old pin pallet watch. I just love this dial, thanks wifey heres my Valentine's gift for yer sweetie x
  2. Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but , fair play to Cousins UK for standing up to them. Now the question, will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers. Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
  3. Less give a damn- more **BLEEP** it! …nice that it is keeping time I’ve done a couple of these (one with your assistance) and there’s a third that needs work on the tension between what drives the hands and the barrel. Did you have any issue with that? …and I saw Ranfft make a small comment in a thread re: pin pallets- a couple drops of Tillwich blu, let it run down the pins. It is good for 20 degrees of amplitude… I’m using this oil as a cheat code on my unmotivated Venus chrono…
  4. The pivots look OK. In this position, balance may rub on the pallet bridge, the roller table may rubb on the pallet fork, the bottom of roller table may rubb on the main plate, and on the tip of the screw that fixes the bottom endstone plate, the impulse jewel may rubb on guard pin, the rounded part of the pivot may rubb on the hole jewe too. Thiss all may be due to broken, missing or moved down endstone, or the plate with the stone has some dirt or other obsticle under it. But, sometimes different odd reasons can exist, like for example someone has changed the balance from a donnor movement. All the reasons are visible and must be checked. For beginning, remove the lever and it's bridge and do the free oscillations test.
  5. Getting back to the issue which is us guys repairing or just enjoying horological exploits. The big worry now is how sound is Cousins as company going forward. The of cost if this 8 year legal battle will be astronomical. Cut backs will happen noticed already how the Cousins catalogue is half its size this year. The main supplier going out of business will hit the UK horological community in a big way. On the Brexit issue it was about a sovereign country being able to make its own laws and trade with any country in the world. I cannot see what was wrong with this. For those who wish to re join the cost would be very high indeed.
  6. Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
  7. I voted leave too, my reasoning was the the EU is undemocratic, no elected officials. I don't regret it but I am sad that both sides acted like petulant toddlers. Shameful. I'm not on other forums but if I was and left this site, would you shun me? Of course not, we aren't petulant toddlers.
  8. Now this has happened I bet China or India just to name two will start to produce none genuine parts. I did. But idiot Boris Johnson failed miserably in his negotiations. The E U stitched up the UK like a kipper. Nigel Farage offered his help but big head Boris declined. So this is why we are in this mess all because Johnson wasn't clever enough.
  9. Hi. I would like to take issue here regarding battery driven , watches, clocks,etc. I will and do repair these clocks in fact I have sever al in my collection as well as the regular mechanical ones. I have one on my mantle piece over 60 years old tha belonged to my wife’s Aunt, long gone Iam afraid and it has been cleaned etc and never missed a beat and is accurate. Every one has their preduices as regards Electrical /electronic Horology but I regard it as part of the progress time line of the art of Horology and to be treated as such. Like Darwin’s theory of evolution it evolved. Two cavemen knocking rocks together and a shard broke off , looking at it he worked out if it was stuck on the end of a stick he would have a spear. Likewise his pal seeing what he was up to picked up a piece and did the same, now that’s evolution. Some clockmaker decided to build a clock that ran with a battery and no spring to wind up and break, progress and both the mechanical and battery driven clocks evolved, the battery ones got better to the point that if it broke you changed the complete unit. Likewise watches did the same but both can be repaired by people who approach Horology with an open mind without preduice. We all have our likes and dislikes bu I for one would never dismiss any technology because I don’t like it. The mobile phone is a good example of modern technology at work as is the automotive industry. There buttons and switches in my car I don’t use because to me they are not nesessary but I still drive the car.
  10. yes that's definitely not right at all. I have a picture one of my friends has a Omega coaxial there was having issues to lose asking me where he should send it. As that's a specialty watch I suggested the service center. When he got it back he sent me a picture so the replace the dial as you can see the hands the mainspring barrel and I think the price was really quite decent considering all the stuff they can replace. So I do know they do change the barrels but the other person I worked at the service center when I would ask questions and unfortunately I can't remember all the answers. I think a lot of the changing a parts is at the discretion of the watchmaker. Plus I don't know enough about the chronographs and whether that would be considered a vintage watch? I take some of the vintage watches may have been sent directly to Switzerland or another service center. Obviously with a watch like the one down below they probably have a infinite supply of parts is its relatively modern vintage stuff becomes more interesting even the watch companies don't have necessarily infinite supply of parts. But no matter what the watch shouldn't disintegrated six months that's definitely an issue.
  11. I wish they would have done so in this case. The whole story went like this: I sent my speedmaster to an omega service center about 10 years ago (at that point of time I haven't even started watchmaking). After the watch came back to me it had only about 6 months wristtime until january 2024 (not fair for this nice watch but the other pieces of my collection want wristtime too ). So my conclusion is that the barrel was already faulty when it came back from service, can't imagine that amount of wear in 6 months wristtime. In january 2024 the performance on the wrist was quite bad, so I decided to have a look by myself. I have to admit that I didn't check the barrel close enough as I thought it must be ok, couldn't have issues after official omega service. That was a mistake, I will learn from that. Follow the golden rule: Nothing is certain except death and taxes.
  12. parts touching that aren't supposed to touch definitely would cause an issue. there not supposed to be touching there supposed to be independent which means that @VWatchie is correct that the ratchet wheel has no effect on performance. so if the ratchet wheel in your particular case is touching that is definitely going to be an issue and needs to be addressed. did you know that the Swatch group service centers do not change mainsprings? Swatch group service centers have an infinite supply of spare parts so they just change the mainspring barrel the whole thing. Plus anything else the watchmaker doesn't like just gets replaced like anything related to the escapement they just replace the components because they can.
  13. as I'm reviewing the discussion this is exactly what I was thinking. You look at the front of the watch you look at the opening in the back and the fronts definitely bigger than the back at least by the pictures. I don't think I've ever seen in a screw on bezel at least like this. I'm pretty sure you'll have to pry the ring off to get the whole thing off. They do make special tools for this though if you can't get something conveniently underneath it. one of the unfortunate problems of Swatch group products are we don't have access to a Swatch group database because otherwise if we had a case number we can look up the casing information and get all kinds of nifty information but somebody has to have Swatch group access. I look forward to the crystal lift idea make sure you get a video for us we all could use a laugh. Well you're not going to be laughing as your crystal is going to disintegrate so is the bezel and not can be a pretty picture at all crystal lifts are only for acrylic crystals plastic the flexible. I'm guessing that's probably a sapphire crystal and sapphire does not bend to come out it was pressed in. The bezel ring has to be pried off carefully would be my guess.
  14. So, first let me apologize for the delay in responding to the several comments that I received. Thank you for taking the time to offer your advice and thoughts on potential paths to solve my problem. In my continued search for a solution I stumbled upon a video that described the process of properly identifying the manufacturer and movement number. I followed the directions, disassembled the watch and found the information I needed. The movement is an ESA 944.111. During the process of identifying the manufacturer, I also identified an additional problem with the plastic base plate. I came to the conclusion, as Cyclops had suggested, that I would probably be better off replacing the movement if it was available. l was able to locate a supplier on EBay who had three new ESA 944.111 movements in stock . The supplier is Migma Watches located in Germany. They were kind enough to pull one of the movements and put a battery in it to confirm that it was working. I bought it and it is on the way. I would have preferred to have repaired the original as I have owned this watch for 42 years but I’m quite happy to just get it functioning again. I should be able to get it up and running in no time once the movement arrives. The rest of the watch is in very good condition. Thanks again for your help!
  15. Hi We all know why they leak and what causes them to leak, therefore we avoid the causes. We keep them in environmentally safe conditions. I have witnessed a leaky battery that cleaned up ok and still worked but I have also see a watch where I removed the back an all there was left was a crusty deposit that’s how bad it can get @RichardHarris123i doubt you will find any meaning full data as each manufacturer will keep his failures out of sight. Most of the batteries are constructed from the same or similar materials and the most common cause of failure is the separating membrane breaking down , gassing causing pressure in the can and breaking the seal, end of story. Whether you would ever ge5 an un biased report is doubtful
  16. I'm not sure I have any question left here, but want to relate my Captain Ahab story getting this junk Elgin grade 206 7j watch to run. It came to me in a bag of broken watches a relative's acquaintance handed over. The "before" picture hides the fact that all 3 brass wheels were seized together with green corrosion. The case was black, but this I learned right away was just a badly tarnished coin silver. It cleaned up really nicely. It's a type of case I have not encountered before, extending a 6 size movement to more like the a 16 size case with a broad spacer ring. When disassembling the case, I broke the stem sleeve. It was rusted and brittle. I figured this was unimportant and I would eventually replace it. Though I was surprised to find how much those parts sell for. I expected them to be available by the sackful, but instead sellers want $15-$20 for a single one. I kicked this down the road so I could get the movement to run. The movement cleaned up okay, and I was able to remove corrosion enough to reuse all but the 4th wheel. It had 5 or 6 teeth that were eaten away not enough to stop the watch, but to send its timekeeping haywire every 45 seconds. I worked on this over several months, replaced some wheels with spares, tuned the escapement to my current skillset. The movement ran, eventually acceptably well. The balance is out of poise I think, based on a 40sec positional delta. I can deal with that when I have a poising tool. But with the dial and hands installed, it would never keep accurate time. Sometimes it would be good for a day then suddenly lose ten minutes or lose 6 hours. It felt like a cannon pinion problem. I got the tools to tighten the cannon pinion. This didn't help at all. I replaced the center wheel because its arbor was kind of worn. That did not help either. I replaced the cannon pinion entirely with a donor's. It had a positive snap on install and good feel to handsetting but still no change in behavior. I thought maybe the hour wheel was riding up out of mesh with the minute wheel so I tried manipulating and eventually stacking dial washers, no change. I learned how to close the holes in the hands for a firmer fit on the hour wheel & cannon pinion. I was going to give up on this one when I found someone selling a bag full of stem sleeves for a reasonable amount. I bought them and installed one that fit, planning to sell this watch on and note its fault for someone else to figure out. But after installing that stem sleeve and recasing it, the watch is now keeping time all week without any issues in the motion works. Why? Because the keyless works on this type of watch are inverted. The stem must be pushed in and secured by its detent with a stem sleeve to engage the winding mode. Otherwise, its default position under spring tension is to engage the hand setting wheels (in the photo above, that spring is not engaged but that's not the problem). All the while I was trying to get the hands to keep time, it was running uncased and the cannon pinion was therefore driving all the handsetting wheels. It can't do that without slipping occasionally and that was its issue all along. It still isn't perfect, I need to troubleshoot a problem with the spring tension in the keyless works while it actually is engaged in winding mode. But now it's all together, and will make a nice little desk clock or something once I clean up the dial a bit to hide those cracks. And the next time I work on an American stem wind/stem set watch I will make sure it is cased when I test it out with dial & hands.
  17. Birth year (1975) Seiko DX.
  18. although not in this case. It was the Lugano Convention and its deficiencies that allowed a Swiss court decision in the first place. This isnt really a Brexit issue at all. A decision that affects both the EU and the UK should never have been heard in Switzerland. I bet the authorised service centres in the UK are pretty pleased. It's a massive shame, though; I believe watch owners should be able to choose to have their watch serviced by whoever they trust.
  19. nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie. I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock. When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving. I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position. No, I did not take the movement completely apart. That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
  20. Isn't that the same guy who told Zelenskyy to escalate the war with Russia/Putin when they already had a peace deal? 2 years later and we have half a million young Ukranian boys dead. He doesn't seem very clever...
  21. The anchor pin should be perpendicular when the anchor is sat on a flat surface and if you post a close up picture of the backplate I will be able to tell you the correct torsion spring , running fast or slow is usually wrong Torsion spring. Here is a video from my YouTube channel showing how I set the beat
  22. I think if you want to play Billy big b.ollocks then you have to have something up your sleeve, anyone that knows how to fight, plays dirty. Lets face it a lot of folk that voted for Brexit just rolled up their sleeves to say up yours EU hoping for good changes. We have idiots for leaders and probably none of them clever enough to clean the shitty stick they were given. I didnt vote, what will be will be. You've signed up to another forum !!! Why you defector , you snake in the grass, you infidel consider yourself shunned.... you.......you........you CAD
  23. Ive heard about that oil before for the lever pins. I found it easy to work on , it didn't have a whole lot of pivot wear but i bit sloppy on the lever cock, i think you have to live with what you have or bin it. Stiff to wind and set ? Not a cannon pinion issue that has no friction thats made up further back and if I remember the barrel drives the hour wheel. No problem on this one .Let me know when you start it as i have another that donated to this one, i can work alongside you with it, two heads are better than one.
  24. Over the last weeks I followed VWatchies thread about his ETA 2763 showing erratic amplitude: https://www.watchrepairtalk.com/topic/28929-serviced-eta-2763-having-erratic-rate-and-amplitude/page/4/#comment-245378 I have a similar problem on an Omega 861. The base movement shows alternating amplitude in both horizontal and vertical positions. The range is more than 25 degrees, no periodical behavior, pure random. In the above quoted thread there was a lot of talk about the regulator pins, hairspring, collet, geartrain, etc. and I do not doubt that all these may be sources for the problem. However, I couldn‘t get one question out of my head: Can the problem be on the other side - mainspring, barrel, ratchet wheel? Some kind of error which prevents the barrel from delivering constant torque to the center wheel? To find out where to look I built the following setup: I assembled the movement without barrel and ratchet wheel. Then after some research and calculation about torque in the geartrain I 3D-printed this part and completed it with an axle and a pin. The movement in a well chosen vertical position. Please notice the spoke of the center wheel. Now the „torque generator“ is fitted to the center wheel. The axle is pushed into the pinion and the pin is lying on the spoke. Finally I have to choose the correct weight to get a torque which results in an amplitude in the area of 280 degrees ( yes, watchmaking is an expensive hobby - my 2 cents). And that‘s all. When the lever is in nearly horizontal position this setup provides a nearly constant torque on the center wheel for several minutes (I assume you live in an area with constant gravity). For me this one answered my question. The alternating amplitude was gone, less than 4 degrees fluctuation now, which is always the case with my Weishi. So the source of my problem is somewhere in the area of the barrel - will work on that the following days.
  25. you think you're going to sleep tonight you're not, you're going to ponder the question of what makes you think those of the right parts?
  26. Sounds like the story with my Rolex. Poor (expensive) job done by an official Rolex dealer with an "in-house" watchmaker, hence I learned watchrepair and did the servicing myself. Same story as I learned with the Omega 861, again poor job by an "in-house" watchmaker by an official Omega dealer. Once your watch goes through that back-door, you have no idea what is going to happening to it Quite nice that they sent back the parts which had been replaced !
  27. glad it worked out, those ESA movements are obsolete but new old stock is still out there, now that you know the make/model you could also do a cross reference to see if something more current would line up with the dial feet and hands...for future use if needed
  28. I am same as you oldhippy I won’t touch anything with a battery, I keep getting requests to but I just say I only do mechanical clocks, there are quite a few errors & omissions with the repair guide have a look at this. https://mb.nawcc.org/wiki/Encyclopedia-Subjects/Torsion-Clocks/Book:Horolovar-400-Day-Clock-Repair-Guide-10th-Edition-Errors-and-Updates
  29. Nice experiment. As it will be no problem, please put a twice less mass (half of the two penies) and read the amplitude, will be interesting. I mean to determine what is the relation torque/amplitude.
  30. When a newbie starts to put His fingers in a clock movement, if the clock starts to tick, then the newbie's heart is full of joy, He is inpatient and wakes at night to check if the clock is still ticking... A ticking clock or watch is like a man that breaths and has pulse. And this doesn't mean that that man is healthy and able to do work. The same with the clock - if it ticks and even to the end of power reserve, this still means nothing and doesn't guarantee timekeeping at all. And the main parameter of a clock or watch health is the amplitude. As You didn't mention anything about amplitude, I guessed that it may be You case too... Yes, the amplitude is measured by degrees of rotation of the balance wheel against it's 'zero' or neutral position. And a table with the amplitude will have one additional column, for the amplitude. Actually, I don't need this table, but just to know if the amplitude is good enough or bad, at least when the main spring is fully wound. Good will mean above 250 degr., and all less than 180 will mean too bad. Yes, the guard pin and safety roller are what is shown and they would never touch when the balance swings. If they touch, this leads to friction and amplitude loss. Yes, the gap with the arrow is 0 and it is a real problem, but it is true only when the string is in horizontal position, and I believe that the picture has been taken exactly in such position. In vertical position, which is normal for the balance, the mass of the balance wheel must straighten the hairspring in a manner that the balance will hang on the spring and neither the bottom of the tube, nor it's top will touch the limits. This is easy to check - try to lift or lower the balance along the string and You must see that it is possible and actually it hangs on the spring... As I understand, You didn't disassemble the movement and cleaned it in whole. No, this is wrong, as all the abrasive particles that got in the bearings with the dust and as wear product will stay there, and the old hardened oil can not be fully removed. The main springs can not be cleaned at all this way too. Sometimes such cleaning leads to stop of the movement again in about one month, and sometimes leads to very fast wear of the bearings.
  31. Date complication on my Seiko Kinetic is retro. Right, I couldn't find a Cobel whose caliber designation starts with G, all seem to start with C or CB . Didn't buy it anyway, description by the seller said automatic, turned out to be quartz. Rgds
  32. That is an unusual date complication. I've not seen an Asian watch with that configuration.
  33. does not say Swiss anywhere, could be asian....
  34. Thank you @VWatchie for the excellent and clear video. Also thanks to @nickelsilver for the comprehensive information that led to this video. Tom
  35. Its been over 25 years since I gave up horology in my time there were not so many of them about and the book I had I only found one mistake and that was with a miniature movement the suspension spring was too strong. All those I repaired the spring layout was printed. I certainly would not have touched those horrid battery ones.
  36. Great experiment! Maybe you would see periodic change if you could register rate and amplitude for longer periods. Passage of one barrel tooth takes about 5 minutes! Frank
  37. I have to admit that I don't agree here. On the 861 the ratchet wheel is placed right on top of the barrel and underneath the bridge. In combination with some wear and dirt it could cause some scrubbing to the barrel and so influence the performance.
  38. I have looked for information on battery leakage, I can find the reason but no recommendations for the makes least likely to leak.
  39. Hi guys. I have used Renate batteries for years and only had one failure and that was no leak it just packed up, replaced FOC of course. I think we must not get **BLEEP** about batteries and surveys because as @Neverenoughwatches said who wrote the chart and who did the survey and who sponsored the survey, probably energiszer . @VWatchie if you have used Renata for years and no problem why switch just because some one wants you to buy their higher priced batteries. Batteries no matter what make even car batteries have a shelf life depending on storage conditions humidity levels, heat cold all will effect the life. Indeed I have purchased the odd car battery in the past that packed in in short order. You buy a battery through many dealers and the price depends on the dealer. The same Exide battery purchased via your local motor trade shop is more than likley tens of pounds cheaper than the main dealer or the AA, RAC, etc. it’s a question of choice, I don’t intend to change just for the hell ofi it. Based on my experience Renata are as good as any on the market regardless of price.
  40. Plus, Vostok movements are Swiss in their construction, so nothing odd about being Russian! Everything you learn when working on cheap Vostok movements can be applied when working on the more expensive Swiss movements such as ETA, Sellita, Unitas, Omega, Peseux, and so on.
  41. Latetothegame has posted about this watch before, it just might be a lot easier to replace the works than repair that post, your movement looks to be quartz, the Chronosport I saw had an ETA 555.11? so could be ETA, Ronda, I do not understand why a movement model number or picture of said works is scarce?, one can only help with more info or drill the post out and go from there.....
  42. one of the confusions for people new to watch repair is what are they working on? Yes you have a description up above but that is not helpful as we need to know who actually made the watch itself. In other words companies purchase movements and put their names on them so we need a picture of the watch movement itself from the backside to identify the watch.
  43. Hi there is always the possibility of drilling out the stump a nd glueing a pin in place to act as the pivot
  44. you're not the only one in the make the observation of they work okay and maybe they can work better? Here's an example from a watch company Omega watch companies are interesting continuously changing their thoughts and ideas on how to solve a problem and typically throwing lots of money at the problem. That's because they have a infinite supply of money unlike us. so let's go back to an earlier sheet from Omega where they did recommend one of the tools up above. Basically a much fancier version of your blue box and demonstrates how it has to be used. In other words when you push the button and produces a alternating magnetic field and whatever you're trying to remove the field from has to be slowly withdrawn if you expected to become demagnetized. Otherwise you just place it on her in and push the button ou'll achieve exactly the opposite. These all work by magnetizing the watch with the sine wave of the power going in and as you slowly withdraw you slowly cause the magnetism to diminish to nothing providing you do it correctly. then this is watch repair there is almost never one procedure for anything. So yes there's a whole bunch of different tools for demagnetize ing. I suppose it has to do with how much money you have. Then is it necessary no if you don't care about the watch running or keeping time if you don't care about those things then yes it's necessary. Then it depends upon how obsessed you are for when you should do this? When the watchmakers I used to work with when the watch came out the cleaning machine he would demagnetize all of the individual parts baskets before reassembly and I assume he did it after assembly but I don't actually know. somewhere is at a lecture where I'm not sure they actually carried the demagnetize are on the tool belt but if they had a tool belt it would've been on their. In other words they were continuously doing it because it doesn't actually hurts anything for the most part then does it matter? Normally what I been taught in school before putting the watch on the timing machine you always demagnetize but by doing that you miss out on something? I was once doing a comparison of a witschi timing machine and the Chinese 1000. I did not demagnetize I timed the watches loaned to me by the person who loaned the timing machine and found something really fascinating yes this watch desperately needs to be serviced but what else does it have going wrong? here is a timing machine program notice in the simulated paper tape the same affect the scene on the graphical display notice the watch still needs to be serviced but something is changed? then from out of the timing machine manual telling you the same thing we have yes magnetized watch is not a good thing. Really gets bad enough they hairspring coils could stick together in the watch will run insanely fast. So as part of his servicing watch has to be demagnetized that includes even modern watches we do it all the time in the shop is put it on the demagnetizer including watches that claim they can't be magnetized.
  45. I see your getting help so my warning will be a waste of time but a lot of times you don't get help if we've never seen the watch before or never worked on it. Which sometimes happens if this watch is a proprietary Swatch group watch so be careful what you break you may not be able to replace whatever you break. Swatch group doesn't like all watchmakers only their chosen ones and even then they barely tolerate them.
  46. This is clearly a front loading movement. Measure the width of the dial, then measure the width of the opening in the case-back, then you'll understand there is no way the movement could come out of the back. It's pretty apparent from your photos
  47. I recently received this little gem from my father, who I believe got it from his. I know little to nothing about watches except what I’ve learned reading and watching videos of watch repairs in the last 48hrs. The crystal is yellowed, and cracked along the edge, causing it to fall out of the bezel constantly, and appears slightly damaged by some chemical. The balance wheel’s shaft’s pivot points (what are these called?) are broken, causing the balance wheel to sit on the .... base plate? And not turn freely. Otherwise i think its in good shape. Would anyone recommend trying to replace the balance shaft, or just trying to find an entire balance complete to replace? And the crystal.... should I stay with the acrylic and replace it or use glass and some form of cement to hold it in? Any thoughts, comments, questions, or advice would be super welcome!
  48. One of my favorites. I had to re-lume it.
  49. Armani Exchange cost £0.99 plus £3.85 delivery needed good clean and new seals on stem as old seals rotted and case back seal new battery and all put back together definitely a 404 club worthy watch And yes that’s how dirt it was
