Case refinish
Had some spare time today and case to mess around with, took me a few hours to get this looking sorta new, satin finish achieved with simple scrub pad, then high buff, (by hand with foredom) around the bevel.  Much finer than machine finish, took away most scratches and dings with 600 paper first. What do you think? Remember, I don't have a day job to quit!:D
DSCF0447.thumb.JPG.2fdcb0a8e81460e14f6d1ed2389537af.JPGDSCF0448.thumb.JPG.968ab373a506787a817dc40e303fef00.JPGDSCF0449.thumb.JPG.2eb7480c18a32276940c7eda78ae8e6e.JPG
Next time use buffing, not abrasives to remove scratches and dings. You will remove much less material and do one only polishing step after.
  • Like 6
JDM,
Buffing machines can do a fantastic job. One of the secrets to buffing this way is to have enough horsepower in to motor to handle the buffing wheel. I have three of these machines with different wheels charged with different grits of buffing compound. These machines work well for me while the smaller motors I tried bogged down under the load.
http://www.ebay.com/itm/8-Electric-Bench-Mounted-Benchtop-Buffer-Buffing-Machine-Polisher-Grinder-/222364019880?hash=item33c5edaca8:g:BwUAAOSwa~BYaTQw
Edited by david
Indeed. For now I don't have a dedicated motor, but I use rotating tool on a vice for "micro-buffing", and a common drill, also on a support, for bigger work with 50mm wheel. Very good results so far... I don't post before / after pictures because almost all my watches gets listed :biggrin:
On ‎2‎/‎3‎/‎2017 at 1:40 PM, Michael said:
Looks excellent, Nice sharp edges on the sides. Do you have the rest of the watch to build back up?
I didn't think to look at case, it's a 7009 Seiko, (got in a lot of misc parts w/o movement) probably have one I could stick in there.
I have seen the 'lapping' technique on a wheel with compounds, you are correct, I was careful not to over abrate surfaces. I have seen 'pitting' on ssteel and once you start it doesn't matter, you'll usually not be able to get desired result, in fact you may make it look worse. Years ago when I worked in jewelry store, it was my job to do all the polishing, mostly repairs, rings and such, so I am familiar with a benchtop polishing setup/techniques. Just never did watches.
I found a bracelet that will fit case and began to use same technique on that with similar results, I'll post a pic soon.
Thanks for all the support, your opinions matter and are encouraging to me.
Dave
Here are bracelet pics, (before/after) after masking off center high polished links, used same pad to create satin look finish, returned to give center links a bit of work, I found spare movement now just need a dial and chapter ring to fit. I'll be sending out for new crystal today, so it'll be some time before I can get back to it.
excellent job, looking awesome....I bought a buffingmachine and I use it as I don't have the patience of doing it by hand...It really gives a great result on crystals as well as cases and bracelets. I don't polish them 100% as I like some wear and tear on a vintage watch.
12 hours ago, Michael said:
Outstanding job. Looking forward to next update.
Like I said, just sent out for new crystal, should be less that a week or so and I have a 7009 movement that should fit. Thanks
10 hours ago, parmenion31 said:
wonderfull work , looks brand new !
Well, let's just say it looks different and unique, I like the way high polish and satin finish sort of meld together on this one. Can't believe it looks that good myself! Thanks
Well here it is....new crystal and wouldn't you know it, broke pin when replacing bracelet, so not quite done yet!  I dunno about the gold and silver combination, but my first attempt at this type of operation, I'm happy with it. Thanks again for your generous comments.589e2a0470a36_DSCF04581.thumb.JPG.336e44a6e80a9846381e56a96574fdd0.JPG
    • Yes, I was referring to the (jewelled) gear train with HP (most of the time, I use 1300, but when Rolex says 1000, I'll use 1000).
    • did I miss the update of the message of something changing?
    • I suppose it would depend upon what your lubricating with those? for instance what does the manufacturer say about those lubricants? I have a PDF from the manufacture and a rather peculiar statement found on the bottom of the chart. my suspicion is the reason the recommending would be without epilam the HP oils like the spread except when they're in Ruby jewel's with steel pivots. tableEN lubrication 2020.pdf
    • These types of hairsprings become weak with age and very fragile. Which I expect it is that giving you trouble, and that wheel is not the correct one, if it were not bent I don't think the movement would run as the teeth are not the correct height. The problem you have is price which depends on you. It can be repaired but is it worth it to you, because there is little value in the clock. A wheel can be made and hairspring replaced. Or hang on to it and keep looking on ebay which is your best bet for replacement parts or even a complete movement but it will be like finding a needle in a haystack.
    • I did that also for a few movements - well, mainly in/around the train jewels. I made big efforts to epilame the mainplate WITHOUT getting Epilame into the Pallet fork jewels (where it's not supposed to be, right?). I made litte barriers with Rodico around that jewel and used drops from a syringe to apply on the rest.  However, I've now stopped doing this. For three reasons: 1. It's a hassle and consumes more of this liquid gold. 2. I didn't see the need when using HP1000/HP1300 lubricants and grease for most part. The two places where I'd use 9010 (i.e. escape wheel and balance) receive Epilame in specific places... or the cap-jewel-setting of the balance suspends the oil sufficiently be capillary action (see my "conflict" about using Epilame on the balance jewels).  3. Lastly, and here I really wonder about yours and others' experiences: I felt that applying Epliame to the train jewels left them looking hazy (borderline dirty) compared to the (painstakingly achieved) sparkly clean results of my cleaning process. I just can't help but think that the Epilame residuals would mix with the oil and cause more friction/wear. I don't know.    simple: it'll stay there. It won't move any further. That's exactly what is happening if you epilame a cap stone. You end up placing the 9010 right on top of the epilame and the oil will sit nicely on that spot.
