hello everyone....
Ianh
Hi everyone,
I am a newcomer to the world of watches and watch repair.
I recently came across a lot of old watches(and a pocket watch) at my parents most of them timex from the 1970's and thought it would be nice if I could get these going.
I have done some research and managed to get movement numbers and dates from the small numbers at the number six position.
In total I have six watches that I would like to get back to working condition.
I have stripped one down taken dial off and hands and soaked it in cleaning fluid dried it off and it burst into life,just got remember how it goes back together!!
so over the next few weeks I will be asking a few tech questions and hopefully get the others working.
thanks
Hi,
I'm Jon, I'm new here too.
Good to hear you're having fun with taking apart a watch and breathing life into it again. I find the Timex watches hard work to work on, as most of them weren't designed to be serviced per se. They are riveted closed and don't have jewels, even on the pallet fork, they are just metal pins, that's why they have that particular sound. Not to say don't work on them. I got one going the other day that used to be my Dad's with a few drops of oil. You just might find a watch that was designed to be serviced and had a good movement with jewels more enjoyable. I've just bought 10 on eBay for about £30. All mechanical hand winding..
Well, that's my thoughts on Timex
sorry but, I do not understand why this comment of Timex movements being riveted and non serviceable is so prevalent.  I have worked on thousands of them using the guidelines in the service manuals aided by some homegrown techniques. As for no jewels, that is also not on point. Their are serial 17 jewel movements used and even 7 in the electric models.  It can even be said that the end cap on many of the  M24 is actually a synthetic jewel and not metal as the rest of the movement is.
Well anyway, if you need any help with the Timex just LMK.
quite true that Timex is not easy to work on if you take the traditional approach of a full tear down service.   But, they actually do not require full tear down unless it is confirmed that parts are damaged.  Even at that point I no not recommend full tear downs unless you have a ready supply of NOS parts and are willing for it to end it total frustration :)  Given that there were millions of vintage Timex made it just much easier to find a donor rather that work on a movement that won't quite get back to working order.
1 hour ago, Ianh said:
Thank you for the welcome, I’m about to assemble one Timex as we speak no doubt will need guidence as I never took any pictures before I took it apart!!.
Do I start a new topic if I need help?
Thanks in advance
would be easier to read a new post with just the repair itself.
5 hours ago, Jon said:
Hi,
    yes;  timex pates are rived together.    did you know the early ones were screwed together? this allows  complete dissasembly?  there a few of them still around.  vin
Edited by vinn3
add welcome note
Thanks in advance
If you can identify it's calibre I can probably post it's tech sheet.
    • Ah so its you thats buying up all the DD calibres 🤨.
    • Hi Richard,  I keep buying CAL.59 movements to practice on 🙂 Not started yet though, I'm gathering tools and building my confidence to start.
    • Problem solved. For some bizarre reason, the hook on the wall of this barrel is not properly centered vertically, but is oddly high on the wall, maybe 3/4 up the way up. When replacing the mainspring, this caused the outer coil to be displaced upwards as well such that it protrudes out of the barrel and caused the barrel lid to not sit quite flush to the barrel. Since this is a motor barrel, the lid is actually the first wheel and inner coil tube/hook all in one piece, with no “snap down” action that would have made the problem more immediately obvious. Maybe with an older mainspring the spring’s end hole was enlarged such that this wasn’t an issue, but hard to say how it ever worked otherwise. Replacing the barrel with one from a different model 1900 where the hook was properly vertically centered allowed the lid to sit flush without mainspring interference and the friction problem went away. The bridge was far too thick to be bent (and isn’t), for those of you thinking that was the problem. Placing the removable arbor in the watch without the rest of the barrel proved that the proper end shake was actually there as long as the overall height of the assembled barrel was correct.
    • You are so true on a lot of what you have said. The main reason for changing the mainspring even if the old one is in good order is because it will take out your thinking that the mainspring is contributing to poor power output or fluctuations in amplitude. If a new spring is fitted that box can be crossed off as a potential source of a problem. Most customers are happy to pay the extra £20 for a new mainspring if they are already parting with a couple of hundred pounds for a service. A new spring is an investment for good running for the future.
    • According to Borel the 814 and 815 use the same escape wheel. It's kind of an oddball being so long.
