Fitting Domed glass crystals
Tmuir
I've got a cheap quartz diver watch (That isn't used for diving) that I'm replacing the domed glass crystal on for my dad.
This will be the first glass crystal that I will be fitting that isn't just a flat one.
I have the Chinese clone of the Bergeon 5500A press with all the aluminium dies.
I'm looking at biting the bullet and purchasing the Bergeon delron dies for domed glass which are not cheap. Bergeon 6527-6CP
Please confirm for me that I will be flirting with failure if I just tried to use my aluminium dies to fit a domed glass crystal as I just want some confirmation before I part with my hard earned cash.
Yes I know I will be spending way more on tools than the watch I will be fixing is worth, but I don't mind that as its an investment in the future of fixing more expensive watches, but only if I really need to buy them.
I''ve got one of those for fitting the 'unbreakable' acrylic crystals.
I am talking about the flat bottoms solid domed mineral glass crystals which you need to push in that sit in the plastic I ring in the case.
I'm pretty much sorted for fitting any acrylic crystal and for flat mineral glass, but the possibility of shattering a domed mineral glass does concern me if I use the wrong tool.
These are what I'm talking about
https://www.cousinsuk.com/product/250mm-domed-flat-bottom-cousins
I would not use a metallic dye on glass or mineral glass. Then again I wouldn't really use them on acrylic either.
Can't you just get the cheap chinese plastic/nylon ones ? I have those and they do the job fine. Just get the ones with a metallic thread.
Happy to buy the Chinese ones if they do the job.
I have a very cheap Chinese ones where the dies just push on and its crap, so you reckon the Chinese ones with the metal threads are ok?
A world of difference between swiss bergeon tools and chinees.
The chinees made scratches the crystal before you can get in installed.
Considering your intent for long term use and" investment" I recommend the high quality tools.
Sorry , didn,t mean to disagree.
Looks like there are many more types of watch glasses around these days. In my time it was normally high and low dome, tension ring and shaped and the branded types. Plastic or nylon dies are better than those metal ones. I never had the influx of Chinese or tools from India.
Obviously you should get the expensive ones if you can afford them but I don't know if the swiss make plastic dyes.
If not the chinese ones will suffice. But remember to get the ones with metallic threads. And be sure to screw them all the way in.
If the dome is not severe, use a scrap of pine or fir (soft wood) as a buffer and a regular arbor press. You could also apply (a TEENY-TINY) bit of Molykote 111 to help the glass slip into the ring.
If it's a real PITA, I'd be looking to the factory Seiko tool/die for the job. I bet you could order the tool (once you figure out what exactly it is) from an authorized Seiko shop. Or, maybe let the shop press in the crystal if they have the tool on hand.
I'm not above going to the "experts" when I'm well out of my comfort zone with these things...
    • It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position.    So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff from the seat-side out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it worked perfect 🙂 I'm very happy how this method worked out ! 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
