On 1/12/2022 at 10:09 PM, TimpanogosSlim said:
I would still say 100% don't buy this model. But if you were saddled with it anyway, and you already have or can beg an M6 helical insert kit, you can make it less worse.
Good work. However even if perfectly built I still recommend against buying this type, because the design is wrong. You can't have a light, screwed in press where the screw forms a triangle with the two skinny pillars. As soon some force is needed as when fitting certain thick diver's crystals or bezel, it will distort and press unevenly. When the spindle was placed in between pillars that wouldn't happen, below a link to a type made like that, still cheap but at least would work better for sure https://www.ebay.com/itm/291052426947
  • 4 weeks later...
Since this particular subject thread already exist, I thought I'd post this here (instead of starting a new thread).
I would like to know if this Bergeon 5500c  8" Crystal Bezel Press Case Back Watch Case Min 1/2"  is a reliable and cost worthy tool to purchase to remove a crystal?
Or would I just be wasting my money and look for something better, quality made?
Is it even a true "Bergeon" tool or a knock-off reproduction?
Anyone here actually owns this specific one?.....and if so would you be kind enough to post your thoughts?...opinions?....reviews?...etc.
Thank you in advance.
evor.com/products/watch-repair-tool-case-snap-back-closing-press-remover-closer-vice-clamp-set?variant=31443873661026&utm_source=criteo&utm_medium=US
5 hours ago, Orhorolgy said:
vevor.com/products/watch-repair-tool-case-snap-back-closing-press-remover-closer-vice-clamp-set
Vevor is possibly the largest Chinese retailer for various machinery, they always have the best price, of course nothing they sell is manufactured outside China. Above I have explained why I recommend against presses where the spindle is not inline with the pillars, or at least have a cast body or sturdy construction. If you go with this one let know how it does.
OK....I see and yes that does make sense now as to why the price(s) is so much cheaper.
I think I will pass on it since, as you previously mentioned, the spindle is not always inline with the pillar and well I really don't want to mess with having to return / ship back an item, etc.
I take it that ordering one of these particular models is a hit or miss, since it's really not guaranteed that it's perfectly alined?
On 4/26/2016 at 7:41 AM, noirrac1j said:
Sure you can use an inexpensive crystal press...I have one with the curved metal base and aluminum dies with a few teflon bases for pressing  casebacks They work pretty good but be careful not to put too much pressure or you'll break the crystal and possibly damage watch case.
JC
Hello,
I resume this post to ask a beginner question hoping that some experienced member can give an advice.
I own a cheap Chinese press too (threaded) with some basic dies for casebacks.
Since my work on watches is only an hobby and I rarely fit a glass (like once every 2 months), as of 2022 can someone point me to a complete and not too expensive dies kit that can permit me to fit every type of acrylic and mineral glass?
I would like to buy a die set that I can, if possible, reuse in the future with a better press if my work on crystals becomes more frequent.
I will buy a crystal lift for the high domed. I usually work with 30 to 42 mm case size watches.
Bonus: what about square, oval or tonneau shaped glasses?
I know that this topic has already been discussed but too many information and a complex "crystals taxonomy" are really confusing me!😅
Thank you very much.
Regards.
My answer can only apply to those with 3D printers.  I have a BB Crystal press and a full set of their aluminum die.  However, I never use them.  I print the die I need on my 3D printer.  Rarely have to print any more because I have printed so many.
Your question about odd shapes--had not thought of that.  But, again, I can solve that with my printer.
Hi LWS   I take it thet the ones that are printed are the snap on  type.  Might be handy for menbers if you could post the patterns some time, not having a printer I buy them.      cheers
Correct, the BB crystal press uses a non-threaded post with a small spring-loaded bearing that catches the fitting on the top.  Just a post on the bottom.
Are you in the US or on the other side of the pond?
https://www.ebay.ca/itm/202714239644?hash=item2f32b5d29c:g:-sUAAOSwdcNdDEAg
I have heard good things about this one. I’ll be clear though, I don’t have one, but there is a YouTube video of an enthusiast using one.
Problem with the lever press is that you are relying on your own strength to press it in. With a Screw press, you have far more control over the pressure.
There are many of these available on Ebay and at retailers. Listing says they will accept generic and Bergeon dies.
As I wrote many times before, I do not recommend this type, the shaft is offset from the pillars, it distorts more easily. This one has strong pillars than the supercheap ones, but the issue still exists.
Lots of professionals will tell you exactly the contrary and they have a good point screw conceals the force, no much force should be needed anyway, consequence is, crystal breakage.
Careful with these as there are many some are good some not so good.
I had different types. Robur was one I had but the dies break easily. These are the others as near as I can find. The one in the last photo I found to be the best type but I can't remember the makers name.
Good advice, thank you.
  • Mark unpinned this topic
  • Mark pinned, unpinned and featured this topic
  • 4 months later...
On 3/20/2022 at 12:08 AM, LittleWatchShop said:
Well, I was gonna send you a bunch if you were over here. I am happy to post the stl files.  Do you use the BB crystal press?
Is it possible to post those stl files (or even the step files)?  Thanks!
Yes and no.  I really do not archive stl files.  What I have done is parameterized the CAD file, so I just enter the parameters and print what I need and discard the stl file.  If you use (or willing to use) FreeCAD, I can send you my source file and you can print to your heart's content.  Would have to email it, or put it on Thingiverse.
3 hours ago, watchweasol said:
being a screw type you can apply controlled force
I can certainly see the utility of this feature.  I always worry using my lever BB Crystal press.
Yes, I also use FreeCAD (among a few other CAD programs) so if you could provide that, I would greatly appreciate it.
  • 4 weeks later...
I just picked up a BB press and it seems really nice. What do you guys think of it? Any advice for using it? i'm assumin gi have to put a cloth or something between the dies and the watch to prevent scratching.
I love mine. I have a full set of aluminum die, but I 3d print custom PLA die. I don't need cloth protection
I saw that, taht's interesting. Why do you 3d print them instead of using the aluminum ones? just to avoid the chance of marring?
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
    • One of the problems with trying to Photograph Phils things are that his enjoyment was building these things so they tended to E falls on what will see if I can find some earlier pictures or any pictures I wasn't even sure because I was looking for that specific picture for somebody else and even it got the last version and that would have been the last version. You will note that he put the indexing on something that he could unscrew it or whatever and it can slide back out of the way so the rest of the lathe can be used as a lathe. With the lathe cut are actually coming down from the top I was there once where he demonstrated how to cut a pivot with the setup it was really beautiful. Older set up if I remember it's not a worm gear assembly in the thing in between the stepping motor and the holding block I believe this particular one was like a 100 to 1 gear ratio. Earlier version with watchmaker's lathe. Even looks like he is the watchmakers bed and then switch to something he made. Then I do have other pictures and things of the rotary stage in use. In the raw so if you tube videos here is an example of one were somebody's mounting a three jaw chuck. At one time there were available on eBay they were not cheap but if you're patient like I was I found one cheap on eBay. After you watch the video it look at his other videos he is a whole bunch of other examples of the same rotary stage. That I do know there are other pictures examples and possibly videos you just have to track them down. One of the minor issues of finding this particular tech sheet for the unit is I believe it was a custom manufacturer and the company change their name but I remember the new name here's a link to the company https://www.ondrivesus.com/rino-mechanical-components
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
