My pocket watches
jdrichard
Super nice collection and work behind!
I have bought a few PW's myself in the lower price range and usually find them being cylinder movements with broken balance pivots, which kind of halts my further advance since I find very little options for replacement parts.
I do have the staking set and have managed to swap out balance staff a few times on regular wrist watches, so if could just get the parts I would jump on it, even though I realize the cylinder movement has it's own issues to work around.
Any hints or experiences in this direction would be appreciated.
/Bsoderling
Nice collection, do you mainly focus on pocket watches then?
Yes, seems so. Love working on repairing the old ones. Cleaning watches is far to boring for me. Need to fix stuff, Engineer by degree and profession. Electrical Not mechanical
I wonder how many other EE / computer engr types (like me) are on here?
/Bsoderling
I started with Elgin pocket watches of a particular size. What is nice is that they are common as dirt and there are still loads of NOS parts for common sizes on ebay. Elgin shared parts across many grades. That may be true for other big brands too.
I suggest starting with a few non-running movements and getting practice disassembling and reassembling without destroying the super delicate parts. The move on to servicing running watches. I spent too much time trying to fix broken movements way beyond my skills and tools.
Sent from my Pixel 2 XL using Tapatalk
Nice PW collection. I too have quite a few. I find it hard to believe that I have only one Hamilton, a 992B. I have mostly Waltham, some early and later Howards, Elgins, etc. I got into servicing pocket watches many years before I started to take on wrist watches. If you can learn to turn a staff well on a lathe, you'll do very well fixing many broken pocket watches that are hard to source staffs for. Keep up the good work. Cheers.
  • 8 months later...
On 2/3/2018 at 11:53 AM, Chopin said:
Very nice. Anything particularly fancy or interesting ?
I've never owned one but I do want to get my hands on one and service it myself... It's hard to find one in good condition sadly... Or they're simply too expensive.
Would a pocket malnija cater your taste? Comes with all spare parts you will need.
Regards joe
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
