End stone problem.
WildBill
Hi, I was in the process of oiling the end stones, I didn't realise they were in two pieces, and I have lost one, maybe its possible to get a replacement..
The top shock absorber went OK, although I found it very difficult to do..."Being the first time" When doing the bottom shock absorber I lost the flat one,
I  also broke the small retaining clip....realising this is going to a nightmare of a job to do....Advise Please.
  • Confused 1
Everyone's favorite job, replacing shock springs. I hope you're up for a challenge.:D
Sometimes the endstone for the top shock absorber is thicker (taller) than the one on the bottom shock block. keep that it mind or you might just break some more shock springs trying to close them back up.
We should be able to help you out once we get that information rogart mentioned.
Looks like you are in luck. For the ST96, you can order the incabloc settings and the stones and springs from Cousins
https://www.cousinsuk.com/category/st-movement-parts
https://www.cousinsuk.com/PDF/categories/1305_Incabloc By Factory - Standard.pdf
https://www.cousinsuk.com/product/inca-end-stones?code=INCA12111
The inca catalogue is in French to make it all more exciting, so Bloc Dessus = Upper complete block (the one in the balance cock), Bloc Dessous = Lower complete block (the one in the main plate). Pierre = stone and Ressort = spring.
121.11 is the upper shock (dessus) end stone, the lower (dessous), in the main plate, would be 722.11. Just type 722.11 into the Cousins search box.
As mentioned above you may have broken the spring by trying to fit the wrong jewel or fit it upside down, so be sure you get this right.
Lots more info on the inca website here, http://www.incabloc.ch/en/huilage.php but I can’t see the jewel sizes to measure up your end stones and check.
1 hour ago, WildBill said:
Is that it Inca 122.11- highlighted in yellow, that's the lower shock on main plate.? so looking forward to
putting the spring in "not"...will order it today...thanks for help....
Putting those springs in is one of the trickier tasks - I really struggled when I started. I found it useful to use Rodico. Put some above where the spring is to go, stick the spring on to the Rodico, and slide it down.
I have contacted Cousins requesting 722.11 for a FF ST 96... The lower shock stone spring got broke trying to them out, the spring looked fatigued and in poor condition, I just helped it on its way..   Am I right  the jewel is in 2 parts 1 part  stay in its retainer, the other part that you oil that goes on top, and the spring keeps it in place.
Yes, have a look at this (what is shown as 'The Mobile Bushing with it's jewel' is one piece')
Edited by mikepilk
32 minutes ago, WildBill said:
I have to get the broken piece out yet.....its it just fitted into a slot, so it should just pull out with tweezers....."Hopefully"
To get the spring out you may have to push the setting out a bit to free the slot.
The whole setting is out already I think , just the piece of broken spring remains...
Don't know how I'm going to see what I'm doing....I have only cheep loops the most powerful one is 15. just had a look at the broken
spring my finest tweezers seem far to big, might have to do a job on them.
Hi Stuart, I managed to get the end stones for my ST Movement, I don't know how you find the right number ie 722.11 for the lower end stone...My question is I need a spring as well but know the right one to get, can you tell me code no. of the one I need ...Also I must mention on getting out the broken spring, (not even sure if I've got it out) I may have damaged the area where the spring goes.
Apart from getting another Main plate complete with the jewel in place...Do I have any other options,.?
You can identify the individual parts from this table: http://www.incabloc.ch/en/systeme_incabloc.php
So you will see 722.11 on the row for ST 96 under the column headed “pierre de contre pivot dessous”. If you need the spring for the same fitting it would be “ressort de contre pivot dessous”, which is 770.03
If you have damaged the area where the spring goes, then that is the “bloc”, which can be replaced by removing the u shaped clip from the other side of the plate. The nomenclature for the spareable parts is here:
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
    • I think attaching a nut to the lid to pull it off is the least destructive, any damage damage on the outside is going to an easier fix than any created when trying to push it out from the inside. Scratching up the inside of the lid , mainspring or arbor bearing will be risk. Just my opinion.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
