How to remove stuck Cannon Pinion
Tmuir
Tonight I've been dismantling a 1920s AS movement for a ladies watch in a silver case.
Other than needing a good clean it doesn't seen in too bad condition, but I can't remove the cannon pinion.
My cannon pinion remove cant shift it, and neither can I using a Pin vice.
What do people do to help free up tight cannon pinions as I'm worried if I just use more force I will damage it?
By penetrating oil do you mean something like the dreaded WD40, or INOX, or is there something more appropriate for watches?
I don't think I'm ready to try the nippers approach yet.
No never use that muck. I my days you could buy 3 in 1 penetrating oil.
Avoid wd40 and other automotive products of similar ilk as they have wax in them!    Use the thinnest oil you have available and warm it a bit before you put it on (better even soak the plate and pinion in a pot), you may have to leave awhile.  Could also use kerosine (parrafin oil) or BBQ lighter fuel as these are very thin and will act like a penetrating oil.  Proprietary penetrating oils will work if they do not contain a wax (for waterproofing) but are more expensive as they normally contain corrosion inhibitors as well.  These inhibitors may also convert any rust and make the matter worse on such a small item!!  It is probably just tight due to old solidified oil or grease and this will need to be softened.
Did you try this type of cannon pinion remover ?
23 hours ago, Mark said:
Is the train wheel bridge off? I can't see from the pics.
The wheel bridge was off in the photo.
For Noirrac1j, yes I have a cannon pinion remover and that couldn't shift it.
After leaving a drop of oil on it for 24 hours it still didn't shift so I refitted the bridge and cleaned it without removing the cannon pinion.
Is the cannon pinion free to turn on the shaft of the center wheel? If not, how do you intend to set the time? If it is free to turn, it should come off. I have used hairspring collet levers or hand removing levers to pull tough ones. If it is tight, anything that tends to pinch it will only make it harder to remove. The suggestion to tap the end of the centerwheel is also a good idea as long as you don't damage it.
Absolutely your choice but I cannot stress enough (for other people who may read this thread) how bad of an idea this is. A cannon pinion un-lubricated will cause the watch to stop or worse damage the escapement if the hands are set.
For every problem there is a solution and that is the job of the watch repairer to solve.
If the pinion cannot be extracted easily then it must be removed carefully by force. This may be a job for someone who has experience with this but it does need to be done for sure.
Do not leave it like that.
I totally agree.
Hi Tmuir, just checking it is not the taper pin type, where no matter how hard you pull it will not come off. You need to tap the centre pin out from the cannon pinion side
No. It's not. That's why I asked if he had removed the train bridge. He answered that he had and so it is not the taper pin style otherwise the bridge would not have come away.
Failed, I must not of had even pressure  when levering and broke the centre wheel shaft.
I managed to remove the broken shaft from the cannon pinion on my staking set, lesson learnt I will use my staking set rather than leavers next time I can remove the cannon pinion via regular means.
Can anyone identify the calibre of the movement?
I can see the bridges are different, but the placement of everything else is the same as the AS340 and if possible I would like to try and find a new centre wheel for the movement
I have a calibre 340 10.5L in the parts bin but its much later in the production run than yours and dates from 1936. There seem to be a number of differences but its pretty closeIMG_2556.thumb.JPG.cd17119f9f89ae4d70fd07b9dccabd70.JPG
I'm about to place an order to cousins for other items and they still have AS340 center wheels in stock in stock for a few pounds, so I will take my chances and order one.
This is why I still only practice on 'cheap' movements so my mistakes aren't too costly.
    • Update: I posted over on NAWCC and it looks like I melted the fine coil wires where they come into the solder lugs. After dropping the heat way down on my iron and being absurdly careful, I have a humming fork!
    • Hell0 @nevenbekriev. Thank you for your advice. I have removed the old setting using my staking set--I will keep the KIF spring, since it is still good.  I am awaiting the replacement setting, and will update when I do that. In the mean time, I looked at the escape wheel and it looks ok. What do you think?
    • Aloha All, I recently bought this Seitz tool on eBay, but it is missing some pushers reamers.  I ended up ordering new parts for those that were missing before I received the actual Seitz tool (bad idea).   Upon inspecting the pushers/bits, I noticed 23 of the 56 provided with the set had no numbers. Further inspection revealed a huge difference in the quality of those unnumbered.  Do all Seitz pushers/bits have a number on them?  I'm pretty sure that 33 of the 56 I received are cheap Chinese knockoffs.  The worst part is that I ordered $80 of parts to replace the missing pushers/bits, and now I'm looking to return the tool. I'm not crazy, right? If these are Seitz parts, they should all be numbered, correct? The first two pictures are the Seitz (numbered), and the other pictures are the suspect parts.  Will I even be able to get a refund?  Thanks, Frank
    • It was £10 + min fee, total £16, could not leave it there. Its a Stanton A.D.2. http://stanton-instruments.co.uk/
    • Chief- The picture below shows the three parts from the dial side that are most useful to "fingerprint" a movement in conjunction with the diameter of the movement.  That's why forum participants are always asking for dial side photos in posts asking for identification.  As far as the setting lever screw, it actually sits loose in the main plate. The threads engage the setting lever below, and the elongated stem above the shoulder sticks through a hole in one of the bridge plates so that it's held captive if unscrewed all the way.  So you may be fine as far as that goes.
