How to remove stuck Cannon Pinion
Tmuir
Tonight I've been dismantling a 1920s AS movement for a ladies watch in a silver case.
Other than needing a good clean it doesn't seen in too bad condition, but I can't remove the cannon pinion.
My cannon pinion remove cant shift it, and neither can I using a Pin vice.
What do people do to help free up tight cannon pinions as I'm worried if I just use more force I will damage it?
By penetrating oil do you mean something like the dreaded WD40, or INOX, or is there something more appropriate for watches?
I don't think I'm ready to try the nippers approach yet.
No never use that muck. I my days you could buy 3 in 1 penetrating oil.
Avoid wd40 and other automotive products of similar ilk as they have wax in them!    Use the thinnest oil you have available and warm it a bit before you put it on (better even soak the plate and pinion in a pot), you may have to leave awhile.  Could also use kerosine (parrafin oil) or BBQ lighter fuel as these are very thin and will act like a penetrating oil.  Proprietary penetrating oils will work if they do not contain a wax (for waterproofing) but are more expensive as they normally contain corrosion inhibitors as well.  These inhibitors may also convert any rust and make the matter worse on such a small item!!  It is probably just tight due to old solidified oil or grease and this will need to be softened.
Did you try this type of cannon pinion remover ?
23 hours ago, Mark said:
Is the train wheel bridge off? I can't see from the pics.
The wheel bridge was off in the photo.
For Noirrac1j, yes I have a cannon pinion remover and that couldn't shift it.
After leaving a drop of oil on it for 24 hours it still didn't shift so I refitted the bridge and cleaned it without removing the cannon pinion.
Is the cannon pinion free to turn on the shaft of the center wheel? If not, how do you intend to set the time? If it is free to turn, it should come off. I have used hairspring collet levers or hand removing levers to pull tough ones. If it is tight, anything that tends to pinch it will only make it harder to remove. The suggestion to tap the end of the centerwheel is also a good idea as long as you don't damage it.
Absolutely your choice but I cannot stress enough (for other people who may read this thread) how bad of an idea this is. A cannon pinion un-lubricated will cause the watch to stop or worse damage the escapement if the hands are set.
For every problem there is a solution and that is the job of the watch repairer to solve.
If the pinion cannot be extracted easily then it must be removed carefully by force. This may be a job for someone who has experience with this but it does need to be done for sure.
Do not leave it like that.
I totally agree.
Hi Tmuir, just checking it is not the taper pin type, where no matter how hard you pull it will not come off. You need to tap the centre pin out from the cannon pinion side
No. It's not. That's why I asked if he had removed the train bridge. He answered that he had and so it is not the taper pin style otherwise the bridge would not have come away.
Failed, I must not of had even pressure  when levering and broke the centre wheel shaft.
I managed to remove the broken shaft from the cannon pinion on my staking set, lesson learnt I will use my staking set rather than leavers next time I can remove the cannon pinion via regular means.
Can anyone identify the calibre of the movement?
I can see the bridges are different, but the placement of everything else is the same as the AS340 and if possible I would like to try and find a new centre wheel for the movement
I have a calibre 340 10.5L in the parts bin but its much later in the production run than yours and dates from 1936. There seem to be a number of differences but its pretty closeIMG_2556.thumb.JPG.cd17119f9f89ae4d70fd07b9dccabd70.JPG
I'm about to place an order to cousins for other items and they still have AS340 center wheels in stock in stock for a few pounds, so I will take my chances and order one.
This is why I still only practice on 'cheap' movements so my mistakes aren't too costly.
    • This is a flying cutter, usual one. The cutter itself is shown in the pictures in the first message, it is made of broken tungsten carbide drill bit. I asure that all the angles of the cutter are as they should be. I have video - little older one - that I made when onse making the same kind of winding pinion for a Poljot 2200, which is even smaller than this one. It is not easy to see in the video, but the tool rest moves about 1mm towards the object in Y direction and then returns back untill cutter is rotating. Then the spindle is rotated one tooth ahead and everything repeated untill all teeth are cut.
    • After a bit further research could it possibly be an AS 970?
    • Latest project was a non-running ebay purchase with an FHF70 movement. I stripped and cleaned it, reassembled it, and got it running. So far so good, nothing damaged AFAIK.  I was oiling the top jewel on the balance (the one in the cock) which was a slightly unusual shock setting. I removed the spring (3 leaves) which was part of a chaton holding the cap jewel. This left the hole jewel behind which I retrieved with rodico and then lost it. I was taking it off the rodico, very gently as I thought, with tweezers, and then it just disappeared.  Fast forward a week, I got a donor movement, non-running, with the plan to just take the shock jewel that I’d lost. It was the same movement but had standard incabloc settings, and was steel rather than copper/brass.  I changed the cock and balance complete and it ran, not very well. I switched the lower jewel setting, cleaned and oiled both jewels and the replacement balance. Without the pallet fork the balance swings very nicely with a puff of air. With the fork in place, balance out, it flicks side to side nicely with power in the mainspring.  Put them together and it doesn’t run. The impulse jewel sits in the fork and it stops.      Any suggestions how I proceed? In case you didn’t follow that I have 2 FHF70 movements, nothing broken as far as I can tell, but mixing up the balance wheels and jewel settings results in a non runner.
    • Oh and this almost perfect third wheel pivot and slightly set mainspring  Ah ok yes i see what you mean, good idea. I'll try that if i fluff this one up. The image isn't great quality but i like the idea though.
    • Why cut the paper, cut a square around the image and grind to it.
