Watch of Today
mk3
Bulova Royal Clipper....
I have recently started to gather some watches in the Bulova " Clipper " series . These watches are very affordable and have a Classic look in both round and rectangle shapes .  I really am not sure how many different clippers there are because I am seeing a different clipper name all the time such as Jet Clipper , American , Sun , Sea ,  Golden , Midnight , Ocean , etc............
From what I gather from ongoing research , the Clippers are 17 jewel , but none have a clipper designation on the dial .
This model is called the Royal Clipper and is identifiable by the contrasting quadrant shades . I picked it up on the bay for a small price and it was advertised as having been cleaned and serviced , the crystal refinished , and a new strap .  I knew that the dial looked like it had the measles .
When I got it I had to clean up an excess of lube on the movement , replace the cracked crystal , replace the paper thin cheap strap , and lume the hands because the lume was practically not there . The case back was over polished and showed all the imperfections also . I also took a chance on cleaning up the dial .
I took the liberty of adding a couple of pics from the internet to show what the dial looks like....
And the watch....
Yeah , I cheated and hi-lighted the dial . You couldn't see the quadrants very well ,....and it looks better in person ,..honest .
You can't lie to the camera .
Looks really good
Sent from my SM-T585 using Tapatalk
Maratac GPT-2 with a Miyota 9015 movement. After regulating it with what I learned here it's keeping time dramatically better than what it was.
It's really nice to be able to regulate yourself. Unless the movement is of superb quality and has little variations between different positions, it really matters as the watch could behave differently to different lifestyles.
took the boss out today, second time in a year, trying to keep the original enamel, well, original!
17586683_1708341626130564_34483315314524
You hardly see this Elgin Direct Reading from 1957 with the crest not buffed off the face and you might see one with the red enamel maybe once a year but still having the blue enamel is a rare event!
Wow , That is a very nice watch....  I like the band on it . Is that also original ?
Today I'm wearing this BWC with a Landeron 248. Case, crown, pushers, dial and hands are in terrible condition, but I bought it some weeks ago to service my first chronograph. It was dead on arrival and now it runs well, even the chronograph functions.
Nice story with this: I had a lot of trouble with the minute counter which didn't switch and stopped the watch. As I work as an engineer in the automotive industry, I'm always thinking about geometrical problems. So I spent about 10 hours working on the eccentrics and the jumper to find the correct setting but didn't get it. In the end the solution was dirt in the bearing of the minute counter which caused too high friction. When I told this to my girlfriend she couldn't stop laughing. "Well, you may be a pro in geometrical affairs but cleaning is not your cup of tea." I have really no idea why she said that... B)
  • 4 weeks later...
Got this gmt for £74 off Amazon.
It's not that bad . 300m water resistant and fitted with a TY2846 movement. Not upto eta or seiko but not too bad with a 35 second variation on one position but 5 others with less than 20 seconds. Amplitude a bit on the low side.ca65e21a93d3231d09ac4352cd0c03b3.jpg2738432ccf61e126f599409a6076d5ad.jpg
  • 4 weeks later...
Hi guys! It's been a long time since I've posted here.... I plan on checking in a little more often..
Here's my latest creation that I'm wearing today. I designed the dial after a current Hamilton Khaki model... I posted a picture of the printing plate too!
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
    • Hi   Find attached parts/repair notes for the JLC 911,  might be useful. JLC_JLC 910, 911.pdf JLC_JLC 910, 911 Repair Notes.pdf
    • Hello and welcome to the forum Dan. Used to know Middlesboro quite well, that was twenty years plus ago. Attached a little reading to get you started. TZIllustratedGlossary.pdf
    • for the most part no. Each individual watchmaker and/or shop had their own system. One of the shops I worked at basically had a reference to a page number in a book. then there are some shops that do no markings at all as they keep their records on a computer and they don't have to mark the watch. Usually if somebody is marking and they've service the watch before you'll see those next to each other. then as far as anything resembling a standard goes at one time the American watch and clockmakers Institute assigned all of their members a number. but that was a very long time ago and I doubt that they are using it anymore.
