Watch of Today
mk3
1 hour ago, ro63rto said:
Thanks ,...I just got this one and I have 2 other non-runners . 1 of them just stopped working correctly . Both non-tunners will run , but not set properly , and you can't buy the circuit boards or get them repaired .
All three look good and the one in the Watch of Today post still has the plastic protecter on the back .
Nice Bimroy... where was this in Singapore?
I used to work in Singapore and there used to be all manner of Russian stuff to be had in 'Change Alley' opposite the Clifford Pier. More cameras than watches from what I remember!
Anil.
Something I'd like to wear but finding links is a bugger, I even called Seiko.:pulling-hair-out: Just wouldn't look right with a strap. Even though 24hour hand is missing, (I got it that way!?!?!?), overall this is in great shape and alarm reminds me of when "the boss" is due home, no matter where in the world I am!:startle:DSCF0303.JPG
Nice [emoji106]
What model is that?
Anil.
Hi,  I picked it up in the bugis area, there's all sorts of shops and business tucked away there.   I might take a wander to change alley today.
43 minutes ago, ricardopalamino said:
I've had this Grand Seiko 5641 - 7000 for about a year , but today is the first time I have worn it .
I gained a renewed appreciation for it after a couple of hours .
It's a GS high beat, what's not to like, I'm so jealous:thumbsu:
The 2209 is a bit unusual the below is an excerpt from a famous german movement reference site.
With an intermediate wheel between central minute pinion and a separate minute wheel the complete train is moved to the periphery. And due to the indirect sweep second, there is also no second wheel in the center. Thus neither balance nor barrel is overlapped by any wheel, and the complete height is avalaible for barrel and balance. The result is a rather low profile without reducing sturdiness or accuracy.
Looking at the movement picture I just realised that the hairspring seems to be a bit out of round..ie coils not centered. Keeping good time for the last 4 hours though.
One thing about russian watches is that even lower grades have a Breguet overcoil hairspring...but not on this watch however. Despite being targeted to the the higher end of the market, it has a normal (non-overcoil) stud. This is probably because the focus of the designers was to achieve a thin movement and an overcoil would have added more height.
Anil
8v22-7000, I may end up changing to strap, but because it's kind of unique, it deserves a proper band. Thanks for your approval!
A dark brown croc would pair well with that.
If you are feeling adventurous, have a look at green croc too. would go well with the gold.
I have the same issue with my 7t42. It could do with 1or2 extra links but cannot find any.
15 minutes ago, ricardopalamino said:
Screen shot 2016-08-30 at 5.49.02 AM.pngI use these . They were not available in the 16mm size for a long time . 16mm is what I have used on most of my Seiko deployment clasps . I just ordered 4 ea.
Good idea, thanks!
p.s. I find the green croc might look pretty special too.
That's just because they bought an American factory in consignment conditions that happened to make watches like that. If they were making e.g. pin pallets movement then the entire Russian population would have been kept awake by their lovely noise for some 60 years [emoji4]
George, hats off to you, those movements are a real pain to tackle, but you do it with quite an enthusiasm and your work is first class! Much impressed.
Cheers,
Bob
PS. Beautiful watch, to my taste watches with that movement tend to be quite appealing.
Cheers,
Bob
Thanks bobm12, I actually enjoy repairing these watches, and the 7T32-7F80 I last posted in particular was kind of a challenge, since it had a broken pin on the plastic baseplate, that prevented the movement to function correctly (among the other issues...). I posted pics on my new blog, if you want to see the status it was in (will not link it since it is also a shop). Since it was a family heirloom of a friend, I had to try and restore it to its formal glory. A picture of how it came to me is attached to this post. He did send a beaten working watch with the same movement, but unfortunately that one also had some issued, so from two watches, I made one. The other will still be repaired, though.
Edited by GeorgeClarkson
Nice strap and very appropriate, Ro63rto! I love the watch.
@GeorgeClarkson George, what paint did you use for the bezel? I'm curious since I have a couple watches that can use some of the same treatment. I was thinking about using Testors acrylic model paint...or even the (to me) more convenient Molotow paint "markers"....Thank you in advance.
Cheers,
Bob
    • So leave off the seconds. Stand the movement on its edge, its the dial edge that rests on the pad ( either rubber or cork , something that wont slip ). Use a finger of your left hand to hold the movement upright,  right hand presses the release and flicks out the stem. I do it this way so i can see what I'm under a microscope. But you could hold the movement between two fingers of your left hand, its the right that has to manipulate the stem out by pushing the release and flicking out the stem with  right ring finger nail. Sounds more complicated than it actually is. I guess you could fix a push pin to something solid, then all you need to do is push the release against the pin, leaving your right hand completely free to pull the stem out.
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial.
