I'm rather enjoying this thread. It's making me think a bit more about the watch that I put on in the morning.
Today it's an Audax.
I would be proud to wear your Audax Marc, it's a cracker! The only other Audax I've come across, was the ladies cocktail watch I repaired.
Today I grabbed this pretty much as I got up late after barely any sleep and it was the first watch I laid my hands on. It is a Jaz Paris Quartz fashion watch.
post-1462-0-43336700-1445357339_thumb.jp
Thanks for all the comments on yesterday's Audax, it seems to have been well received.
Today it's a Vertex Revue.
One of my smaller vintage watches but very comfy and an excellent time keeper.
Hi all,
Wearing this Vulcain 'Meteor II' today. Don't you just love these funky names? I've always had a soft spot for Vulcain..a lot of it is due to the name itself and the logo (as on the caseback below)..
Inside is nothing spectacular.. just an ETA2452...tried and tested (sorry no pics)!
Anil
Oh and its on a stretch Speidel bands. I don't usually like these stretchy bands but I made an exception in this case as the ends match the case perfectly.
Anilv
I bought my wife a NOS ladies Vulcain for her Christmas a couple of years ago, and it's here everyday watch. It's also a watch name I like, and I keep hoping to pick up a Cricket sometime.
Wearing my 'party watch' made of ebay Bits:
I 'pimped' the ETA 6498 movement (polished the wheels, blued the screws and made the plates curvy).
Keeps perfect time but MAN it's a loud tick
Yes, I know the strap's the wrong size :-)
  • Like 5
It's a Mondia for me today.
My first "proper" watch was a Mondia Sea Scout. It was my 16th birthday present from my parents and I still have it, but it was the start of my interest in Mondia watches and I now have 5 of various vintages. This one was an eBay non-runner that required no more than a service and clean up.
Seiko SKX173, 7s26a 0029
post-1200-0-84299000-1445523169_thumb.jp
Came to me not running, missing a roller jewel. My first complete tear down, clean and repair. Also first semi successful hairspring mangle  :)
Think I will give the old Sportsmatic 15040 an airing tomorrow:
better clean it up a & bung a strap on it
that's better.
Nice job on that Sportmatic BL.
Geo I reckon you earned that test drive several times over.
I was out on site today so went for something a little more robust than I would for the office.
Citizen Promaster, a nice big solid reliable chunk.
I love the dial on that Omega.
Today I grabbed this Seiko Alarm Chronograph watch to be my watch of the day. You don't see many of these around anymore or fully working ones, especially considering that they used to be so popular at one time.
post-1462-0-82828700-1445619709_thumb.jp
Today I went with a Longines Wittnauer Automatic watch, these actually have a ladies watch movement inside them, probably to keep it slimline.
post-1462-0-14353400-1445661624_thumb.jp
    • The project is still alive. The parts are roughed out from ground flat bar stock. But before I can move ahead I decided I needed to replace the spindle bearings of my milling machine. There was too much play on the spindle.. But after diasassembly and measuring the bearing spacers, it turned out that the difference in height was 1,89 mm. Way too much to achieve preload on non-paired bairings. So, the spacers need to be ground to get them to the same height so I can use a paired bearing set. To do that I need my surface grinder up and running and that needed a hydraulics overhaul. And that would be easier if I clean out my parts washer/de-greaser first..😀 So... this is getting to be one of those "I need to fix the machine I need to fix this machine to...." type of situation. Happy as a clam though 😃
    • Have a look at this discussion where I show what I use.
    • Hello fellow watchmakers, I have a question for all of you, especially those who regularly work with the Sellita SW200-1 movement. At my workplace, we mostly handle watches with the SW200-1. As many of you might already know, this movement has a known issue with the ratchet wheel teeth breaking. However, recently, I've observed a noticeable increase in problems like: More frequent ratchet wheel teeth breakage Screws getting loose and falling off Sudden drops in amplitude And other irregular behaviors So here’s my main question: Before doing the final assembly of an SW200-1, what are the mandatory checks I should perform to ensure proper functioning and avoid post-service failures? For example, I already check: Ratchet wheel teeth condition Canon pinion friction Accuracy and amplitude Screw tightness Jewels condition But I’d love to hear from all of you — what other important things do you check during assembly? Any tips, tricks, or personal checklist items would be extremely helpful for me and ot hers working on this movement.
