Does anyone recognise this please?
Deggsie
Today I received 12 old watches I bought on an auction site and was disappointed that 5 were quarts and not all mechanical as described. However I think just one of the watches makes up for it as it has a lot of character. Does anyone recognise this watch or movement please. There is no branding on the dial or apparent manufacturer on the movement. Inside the back cover it say DENNISON CASE. Please see photos below:
00daf86f4e772944afa79ccb4a7909bc.jpg87f84b0e6d3b19597d61933ddbef960d.jpgf3ffe6fac1733d14b9de2aa957edaaaf.jpg
I have a piece that's a lot like that one- also with an unsigned movement.  Mine is a vintage Delmar woman's watch. The movement is small and fits in a rolled gold case almost identical to yours. I'll post some images tonight.
It's a pretty movement with perlage on both the top and bottom plates, Breguet hairspring, and compensating balance. A bit of research on the internet suggested the movement may be a variation of an early AS movement, although which I cannot recall.
Regardless, it's a nice piece.  :)
Seen one a few weeks ago almost identical to yours. Can't remember if the movement was like this. Also unbranded. They're pretty interesting but don't hope for something mega rare and expensive.
Time period is 30s probably...
Unfortunately, I just noticed the Chrystal (a polymer or sorts) has been repaired with what looks like aradite presumably to stop it falling out[emoji51]
Regardless, it's a nice piece.  [emoji4]
Would information / drawings be available to help me disassemble and service? I might hold tight until I have more experience with scrap movements. Cheers. Deggsy
The back cover also says its 9 ct gold its a pretty typical ladies watch of the 1920's but you should be able to date it from the hallmark. The movement is I would guess a FHF movement, it looks in quite good nick from the photos and would probably do with a crystal change anyway as that one looks to have yellowed with age. It is a good quality watch that someone would love to have.
Thanks for your input here. So the yellowing polymer is authentic? Do you know if these are still obtainable please, or would I need to make one ?
Regards deggsy
You should be able to get a crystal for the watch from cousins or Ebay some sizes of crystal are hard to get now a days, but i find small oblong crystals for cocktail watches can be hard to source but I dont think you will have a problem with a round crystal.
Sometimes you have to take down the movement to see who made it.  Did you look on the dial side of the movement (after removing the dial)?  Sometimes there's a trademark there.
Hello Douglas. I've not taken this apart yet, but will keep you all posted on what I find. Cheers. Deggsy
If you cant find any ID under the balance, remove the movement from the case, take the hands off and remove the dial and see if there's any ID there, if not take a good picture of the keyless work and post it here as many old watches can be I d that way, the bestfit catalog should have the info and I know clockboy on here has a copy and should be able to help you. I have said many times on the forum these old ID books are a wealth of info, keep your eyes open as these old books come up on ebay.
Every thing that wis1971 has said about this watch is correct.
Doubtless from the FHF stable, similar to this, http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&FHF_002_10_5 although I expect an 8.75 ligne (19.5mm) rather than 10.5 ligne (23mm)
You will be wanting a sternkreuz m crystal... https://www.cousinsuk.com/product/domed-slightly-sternkreuz-m, and Hirsch sell a nice range of open ended straps
Sadly once finished, these have little commercial value, but make really nice and unusual presents
very nice watch indeed,....if you want I can have a look in my crystals stock for the correct crystal if you send me the size. As for the auction, if they are misdescribed, you can return them and get your money back.
That's a kind offer watch time, but I think the case has been damaged or a part is missing. There is no visible groove or way of holding the crystal in. Hence I think that's why the previous owner has glued it in[emoji51]
Acrylic crystals are a compression fit. The case should have a step which the crystal fits inside. If it has been glued in that's probably because it is too small.
You should ideally buy an acrylic crystal which is 0.2mm bigger than the diameter of the opening in the case. You will then either need a press or a claw tool to flex the crystal to fit it. https://www.cousinsuk.com/product/round-glasses-superior
Sometimes it is difficult to find the right size and so crystals do get glued in. GS hypo cement is the right thing for this https://www.cousinsuk.com/product/gs-hypo-cement
I'm not 100% sure that this would be a low dome as OldHippy says. That would be a Sternkreuz type N rather than M. Low dome type N will project more out of the case than a slightly domed type M. If you remove the old one and post a picture of the edge then we can advise.
Here's those pics I promised, better late than never. Top and bottom plate are taken before service (yes, it was a dirty one) and the last pic is post service.
IMG_1604.thumb.JPG.eb4ad7af7d8d5111753b6fef9972bb10.JPGIMG_1608.thumb.JPG.a911b085016013cc7a54000968efda15.JPGIMG_2259.thumb.JPG.76bb21adcc28b67747c86920468d789f.JPG
I made a mistake before as it's not a Breguet overcoil hairspring. The rest is quite nice though- lots of perlage.  No identifiable markings on the top or bottom plates so it's a guess as to who made the movement. I think FHF is probably the best guess.
I haven't found a service guide, but I dropped all my service pics into my Public Dropbox folder if you want to grab them. I'll keep them there for a month or so.
Hello all and apologies for the delay in getting the photos back to you as promised. I removed the acrylic crystal and it was sadly held on by something like araldite and also a grey resin like compound - see photo. My camera equipment is not high tech yet so please forgive the quality in comparison to some of the better images I see on here. There definitely is no ridge, just a plain bore in the case. Maybe this is why the crystal was held in with resin?
Here are those images:
b82523bfa14134129c2999d8284ad86d.jpg14fed3bd5a81970997288d0e06667582.jpgc78f04e517beab963d1916dc529f15ed.jpg0a9bfb8c2ac2c775b61a998a13f9a97d.jpg6ea0e9074ecb371609b3d95da1fcf4b7.jpgc111b8db3c590cc5a4198e08a30ef176.jpg
I'm struggling to see the detail of the top of the case on these pictures. Here is a similar case where you can see the expected groove on picture 6
http://www.ebay.co.uk/itm/RARE-1931s-ANTIQUE-LADIES-9CT-GOLD-375-HAND-WIND-SWISS-MADE-WATCH-CACHECASE-/232258360767
If there is no groove, then the only option I can see is one of these, although I've never seen a case like that with a stepped crystal... https://www.cousinsuk.com/product/domed-underlayed-sternkreuz-u
You will need a type of crystal for that called a underlayed crystal they are available from cousins and have a extended flat lip around the edge they are pushed in place from underneath, you have probably looked the hallmark up but it appears to be 1930 the patent number refers to the case "Cachecase" and was first patented in 1926.
Hello. For clarity, here is another photo of the outside of the case with the movement installed 09cd79b7b159348960a57814f533e682.jpg
I can see the groove you mention ref photo 4 in the auction, but the case I have just has a plain bore as in my last photos. Maybe bodged in the past due to damage?
That first case would have what is known as a low dome acrylic glass. The same with me the picture is not clear to my sight to me its blurred.
    • I used to just remove the stem pop the movement in its case then put the stem back in check everything then back on the timer.
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean. Something like this, but tbh its better to just learn to do with your fingers.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
