orient 46941 regulating
nickpeh
Hi,
I tried to regulate the movement from orient 46941, it seems how slow i tried to adjust the reading still the same and time shown average 3 mins faster in just few minutes. Is it the problem lies on the beat error ? By using this software, beat error showed zero, so I eliminate the idea of that...any advice from u guys?
I am kinda new to watch disassemble, in this pic config will I able to remove the balance bridge assy ? I tried to remove but seems something not releasing from lower area , I am afraid to pull due to the hairspring. Do I need to remove any parts frm dial side to release this balance bridge?
High rate / low amplitude suggests that the h/s coils are fouling up on something.
You said that you have cleaned the h/s; when you reinstalled the balance did the h/s coils sit nice and concentric or were they still bunched up as in your earlier photo?
How did you clean the h/s?
Is the h/s sitting parallel to the balance with proper clearance to the balance arms and the cock?
Have you tried demagnetising it?
53 minutes ago, nickpeh said:
After several hours of regulating , seems cant get the gained rate lowered...wondering what could be the issue.
Something is fowling the hairspring at a guess. Your original post showed a good amplitude and the beat was within tolerance so something has gone wrong since your adjustments.
Is there an easier way to demagnetise?  I soaked in kerosene and leaving it to dry , repositioned it and anchored down.
Clockboy is right.  Raw kerosine is distilled from crude oil can also contain a lot of sulphur and other undesirables so is not suited for cleaning any parts of a watch unless very very dirty with old caked oil (then need to ensure you clean off all the kerosine).  It can though be used as a penetrating oil to ease tight fitted parts.  Rather than use raw kerosine use BBQ lighter liquid fuel as this is basically de-odorised, de-sulphurised and cleaned up kerosine.
Edited by canthus
fact
I did degreased it after soaking in kerosene using solvent, but after detailed inspection, realized hairspring end was slight bent causing the balance wheel unable to stay center. I will get new one to replace.
orient 46941 movement seems no banking pins, so now is it align the balance wheel impulse pin between pallet fork?
  • Similar Content
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
    • Pallet fork was in. I’d had the movement running ok, and only removed the balance to flip it over and install the keyless works and date mechanism. The pallet fork wasn’t locking the gear train when hand setting - it was oscillating as the escape wheel rotated. This may have been in one direction only - can’t remember.
