Hello everyone, i have just created an account today,
when it comes to watchrepairing i am a total newbie and since i own various pre and post - soviet timepieces i will be needing your advice and guidance on how to repair them. I know it will not be easy but i am here to learn!
Other than a tag 1500 series and a couple of casios everything else is russian.
Vassili.
Glad you took the jump Vassili. We just can't have enough "Russians" :D Lots to explore and to learn. There are, next to all the skilled people, also some very helpful, educative "walkthroughs" on this forum, so you are at the right address.
Hello Vassili and welcome from me,
You have found the right place to bring your questions, I have had a lot of help from friends on the forum.
Yasou,
Vic
Thank you all for the warm welcome!!!!
@endeavor:  thank you for suggesting me this great forum!
@parmenion31: Ευχαριστώ πολύ συνονόματε!!!
    • Good to know that Oldhippy is fine.  I wish you a fast recovery, we, the noobs, miss you a lot.
    • Managed to clear the short, cleaned and oiled the movement. Now testing for 24 hours before I case it up. The movement is so small that it's loose in my smallest movement holder.
    • @oldhippy - wishing you all the very best of recoveries
    • Looks like the kind of message that occurs when there are routing issues between your local network and the remote server the site is living on - there can sometimes be 20 or 30 hops and when there are issues some of those hops become unavailable temporarily for some people but for others where there is a different path being used the issues are not manifest. Another explanation, and this used to happen to me a lot with my ISP, is using the ISP DNS servers on your device or router sometimes is not as robust as changing to a public service such as 1.1.1.1 or similar. I was having a terrible time watching Youtube a while back - changed the DNS on my Apple TV to use 1.1.1.1 and problem solved. However, these issues tend to resolve themselves fairly quickly.
    • As mentioned by the other members, it’s a dismantle job clean and inspect the solder joints. It’s an older generation using the paxolin pcb  not the glass fiber ones.
