Hi from Hampshire.
Daveb
Hi, my name is Dave and I am a complete novice, I love watches and am fascinated by the little engines that work them so I want to have a go at trying my hand at a service and maybe one day fixing something and breathing new life into it, that would give me such a feeling of achievement. Anyway I have a collection of a few broken pocket watches and wrist watches and a couple of working seiko including a working seiko 5 with a 7s26 movement and was going to try and service that following along Marks wonderful videos. I have a few tools gathered together but I expect I will be pestering your good selves with questions. I am avidly waiting for new videos from the watch repair course. I hope I'm not too much of  a pain. Cheers!
Hi Dave,
Always a pleasure to speak to another Dave :)
I wish you all the best with your endeavour, it's a great hobby to have. I notice that you're looking to start on a 7S26 which is great. I haven't seen Marks videos on this movement but make sure that you have the correct tools to do this one as it does require a special screwdriver for removing the date indicator maintaining plate. Some may argue that you can use a small flat head or as you will see in this guide http://www.clockmaker.com.au/diy_seiko_7s26/chapter7.html he makes his own by grinding a screwdriver. I am a big believer in the saying 'you're only as good as your tools' and the result of using a makeshift screwdriver in this scenario is evident from the pictures that follow in the rest of his article.
You can pick up the correct screwdriver for £7.95 at Cousins https://www.cousinsuk.com/product/seiko-crosshead-af-swiss and it will make all the difference...
Anyway, I'd love to see how you get on with this and the other repairs. Keep us up to date.
All the best Dave,
David
A big welcome to you Dave. Have fun on your first service and remember take photos of each step of the dismantle just as a reference. Remember Marks video wont always be there to help you and its the easiest way of keeping a record to go back to when your scratching your head saying where the hell did that go and which way around. Ask as many questions as you like everyone here is always willing to help with any question no matter how stupid you may think it is we all have to learn I know i still am :D.
Mick
Welcome Dave! A year ago i was servicing my first watch... a chinese cheapest one to ruin it :) After losing and finding many many parts of it surprisingly it worked again :)
Now i can do complicated repairs for example broken balance pivots. Pocket watches are easy way to learn, they have much bigger parts :)
Its a beautifull hobby and here are many helpful and experienced members ready for novice questions :)
Edited by szbalogh
17 minutes ago, Daveb said:
I did previously try to repair a pocket watch a few years ago..........it is still in pieces in my box. Maybe I can resurrect it when I have a bit more knowledge of the workings. I just have to keep something alive first without ruining it.
I expect we can help you with that. Post pictures so we can see what you have.
Welcome Dave,
It is good to hear that you are already on your way to explore this new universe: watchmaking. As outlaw points out, that Seiko may require a Philips tip screwdriver (it is rather not conventional, I think the angles of the tip are different but I can't attest to that). In any case, check the version of your movement: 7S26A or 7S26B will need that screwdriver, version C doesn't...so if you have that one you'll be saving money! :)
I wish you all the luck in your new projects and please ask all the questions you like and post pictures once in a while.
Cheers,
Bob
Hello Dave and Welcome,
As you can see from the responses we are generally a friendly bunch and luckily there are those amongst us that are really well skilled in the art (myself excluded).
i am a happy tinkerer and can claim some success with repairs and service but some failings along the way but whatever I thoroughly enjoy it and the forum provides me with solutions and advice.  I think you have come to the right place if you wish to pursue the hobby.
Cheers,
Vic
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
    • Hi, Is there a spell check function available when you are posting ? Regards CJ
    • Hi John I just did a Seiko Lord-Matic a front loader without a split stem, I used a crystal lift to remove it, although I had to have it that tight I though I was going to break the lift before the crystal would budge. So I decided that the press would be a better option as I think crystals with tension rings resist a lot of compressing. I used a crystal press to repalce it and the bezel with no issues, obviuosly a different watch to the Omega. I just took my time and kept inspecting the installation progress bit by bit Regards CJ
    • Hello All, I’m replacing the crystal in an Omega Dynamic, # 165.039, which houses a cal 552, installed through the front of the case. The replacement Sterncreuz crystal is, like the original, with tension ring. I removed the crystal using a compressed air technique to pop it out.  (I have a crystal lift, but I’m always fearful of marking the crystal edges and so avoid using it as much as possible). Now to the replacement -  any tips on putting the crystal back in?  Am I obliged to using my dreaded crystal lift to complete the task, or how about a crystal press?  I’ve put lots of crystals in using a press, but never with the movement in the watch. The thought of using one with a front-loader makes me very nervous, with the fully assembled watch sitting under the press. How would more experienced folks proceed here? Any advice, gratefully received… John Down Under…
