Clothing
MWNAWR
I would love to design a workman's full-front apron (like a barbecue apron) that is magnetic.  The reason being that if you are working on a watch and something flies off (as often happens when I change a lug pin...damned annoying!) it will stick to the apron and not go into the guts of the carpet under your workbench never to be seen again.
Not good at all. Anything that is magnetic near any watch will get magnetized.
Hmm.  I hear you, OldHippy.  I guess the risk of magnetisation is too great.
Perhaps someone could design a "workbox" made out of plexiglass with one section fitted with a Fresnel lens to magnify what you are working on.  The box would be lidded and fully enclosed and you would have to put your hands and forearms into fitted cotton gloves to do your work.  Kind of like this:
Obviously this is a modified image of a humidicrib but it's the same general idea.
Edited by stroppy
I try to avoid wearing something which can 'catch' parts and hide them.
Cargo pants/shorts, for example, have a lot of pleats which can hide parts.
Anil
If I have a work bench in my bedroom, I'll just wear the finger cots. Good idea Geo, ;)
Stroppy, sometimes I do my work in this box.
Sent from my Lenovo S650 using Tapatalk
Yep...that's it.  Just the thing.  Oh well...someone done thought of it first.  No patent rights for me then!  (much lamentation and crying!)
    • Usually the coiled spring contacts the piezo sounder and the finger spring is the ground.
    • So I checked with my friendly local lab supplier and they can supply the following in 2.5 lt bottles: Tetrachloroethylene (B-Dip) - approx £65 Trichloroethylene (one-dip) - approx £43 n-Heptane 99% (Essence of Renata) - approx £35 Hexane - approx £45 I can't import or buy locally the 'real' products, hence the raw chemicals above. What do you think would be my best option? I'm edging towards Trichloroethylene - I know there are greater health risks, but given the very small quantities used for each treatment and 99.99% of the time it will be sealed in a jar, I think any risk is vanishingly small? This is mainly due to its assumed superior cleaning properties, or from the experience of this group, is the extra cleaning noticeable compared to its safer alternatives?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
    • Here are the pics of the bridge. Looks correct, but as soon as I screw on the rotor, the watch stops. Video here: https://1drv.ms/v/s!ArG5E62RGctxjokY5ws85BzuJLVakA   Pics. Might have figured it out. I have been working on this watch for a while and since I got it as a non runner in a terrible shape, there was no guarantee that parts were proper. I think the main screw that was used on the rotor was too long, so it was stopping the main train. As soon as I fished out a much shorter and larger headed screw, things were good again. Please celebrate with me.
