The heat is so intense and sudden that it can harden the spot. -
I have an ancre ligne droite 15 rubis pocket watch with serial number 345613. Does anyone know age, origin etc of that watch? It also say balancer comprise an spiral breguet
By LittleWatchShop · Posted
Yup, that is the same as mine. Use a watch mainspring. Find one the correct width and cut it to length! This is why you NEVER throw anything away. -
Perhaps he means this is wear between the pivot tip and the pivot, as though the jewel hole has worn though a section of pivot above the tip. This I've seen on one or two that i have restored, it makes the tip look vaguely mushroom shaped. -
Thank you Knebo, I will not hesitate to do so. And thanks for the other service tips. How to service the reversing wheels is fortunately well known and documented but the other tips were new to me so much appreciated! Well, I tried it. I even washed the ball before I tried it but even though I pulled so hard I almost turned blue in the face, the case back wouldn't budge. I can't understand why case-backs have to be screwed on so tightly. I had an Enicar where the only solution was to attach a nut to the case back with super glue and then unscrew it with a large wrench and even that was sluggish. Anyway, I don't want to superglue a nut to a Rolex case back! It just wouldn't feel right 🫤 Well, @JohnR725, after reading your comments, there is no doubt that a service is in order. Unfortunately, I have no history but I guess that an overhaul (or several) should have been done long ago, especially as the rotor shaft is worn out. Thanks also to both of you for all the PDF documents that I have now saved on my OneDrive. It will be very interesting to read them. I am now compiling a list of everything I need to carry out a proper service and repair. At least everything that can be reasonably foreseen. Obviously, all the gaskets need to be replaced and fortunately, Cousins has everything in stock. As I have not yet been able to remove the movement from the case, I have not been able to take a closer look at the crown, so I wonder how the gasket is replaced in the crown. Maybe it's in one of the PDF documents but I thought it wouldn't hurt to ask anyway!
