you might see a theme developing here.
the blue dial is already here, but the front office at my apartment complex has been closed from last thursday because of the storm. i'll get it tomorrow.
the other two should be here this week.
God!  I can recall looking at the Bulova watch display that had Accutrons on it back when I was a kid.  I was always peering into the local jeweller's display window while my mum went supermarket shopping.
My favourite displays were for the Omega moon watch and the many LANCO and Tissot watches.  Also, there was an Australian company that imported Swiss movements and sometimes cased watches here called "Felicia".  Felicia watches were very good... toughly-made and not all that expensive.  Not much more that the ubiquitous Timex watches that were in all the department stores back then.  Here are two locally-made Felicias I lusted after as a kid:
Edited by stroppy
I've got this one coming -
post-1200-0-45372600-1453994682_thumb.jp
And this one too!
post-1200-0-82392300-1453994732_thumb.jp
I've wanted an example of each type, chrono and GMT, for quite a while.
Cheers!
And this one too!
Cheers!
Is the first watch a Seagull or Tianjin?  And what brand is the second one???
Edited by stroppy
Both of these watches are project watches from the Chinese Mechanical forum on watchuseek. The GMT is a limited edition, and I don't know what factory either one is made in. I believe the 1963 is generally available right from Ed in Hong Kong. The movement in the 1963 is Seagull, as far as I know. The watch is labeled ST1901.  Ed is very approachable, and I'm sure can answer any questions you have.
Have fun!
Have this one coming in.  My thought is  trying to service it. :pulling-hair-out:  Have an other movement that i should put in it . Ugly ohhh yes sir :)
Edited by rogart63
I have this Chinese beauty flying to me from my favourite Ebay supplier as I type:
HK-post-Jaragar-Men-Gent-Black-Tourbillo
A nice looking watch stroppy, some of the cheap Chinese watches really look the part and for the price you can't go wrong, I have 6 or 7 mechanical & quartz , most of the quartz have Miyota  movements, and as far as I am concerned the movement is the heart of a watch.
If I had the dough I would spring this little looker.  272103922181
Max
so where does the green come from on the rotor
Not sure, some sort of tropical fungus that oozes out of the Filipino rain forest I think, get a lot like that seems to cleanup Ok most times, I hope!
I no longer have a watch. I haven't worn one in years. My first watch of my own was an Ingersoll, then it was my grandfathers Vertex which was left to me and finally a Seiko auto which I got from work that no one collected.
i can tell the watches that the indians sell. they have a....how can i put this?......special way with refurbishing the dials. in many cases, if they were just left alone, the watch would be much more desireable.
I have my doubts about that Tim, they throw nothing away and the dials they refurbish we would just scrap they would be that bad.
It is not all bad that you can pick their dials, we have several sellers on eBay out here who seem to specialize in re-marketing them, all seem to list them for auction, starting at $85.00 or BIN at $118.00, you or I go on their sites we pick them up no trouble, but check out their feedback and they seem to move plenty of them to happy customers.
I put a decent Seiko on ebay at auction and get about $35/40 go figure!
Max
    • I tried pushing to dome the washer in and had no success, but stuffing it full of o-ring gaskets worked much better than I expected. It takes some pressure but not as much as you might imagine, but it does take patience ... and a couple of dozen small gaskets. I used the pendant tube of a watch case to stuff the gaskets in as I didn't have a way to machine a tool to suit.
    • I can't answer your question, sorry, but you probably don't what to transfer the spring to a new wheel. Springs and wheels are paired ("vibrated" together) to get the right timing and transferring the spring to a new wheel is quite likely to see you minutes per day out with no way to correct it. Some may tell you to replace the balance staff, but if you're a beginner you're probably better off sourcing a replacement "balance complete" if you can: staff, roller, wheel and spring already assembled as a unit.
    • I'm sure it's the ancien. My measurements: A = 342. The slight bend in the pivot would make much less than a thousandth of a mm difference to this so I don't think 348 is plausible unless there has been significant wear on the pivots. B is hard to measure without first removing the balance wheel. I measured to the other side of the balance wheel as best I could (263) then subtracted the thickness of the wheel (69) to get 194. This could easily be three or four hundredths out, so 195 looks right. (196 could also be right.) J couldn't be measured. I did my best to measure where the balance wheel has been riveted on and got about 95, so 85 before riveting is plausible. (60 is not.) G again couldn't be measured without first removing the roller. I get 37 where the staff emerges from the roller so 41 at the other end of the taper seems plausible. (43 is also plausible to me.) K = 60. (Definitely larger than 55.)   I've never replaced a balance staff; it'll be a new adventure for me. I'll have to read up on how to maximise my chance of removing the old one without damaging the balance wheel without having access to a lathe. I also need to explore how to remove the roller without damaging it. I won't actually place an order until I've gone through the rest of the movement. With the number of issues I've already found, I'll be amazed if I don't have more surprises in store. There are some watch part suppliers in Australia but nothing like Cousins or Otto Frei or Jules Borel. AllTimeCo is fine for basic parts for modern watches: batteries, bands, some crowns, stems, seals, movements, some tools, etc., but not really anything for vintage watches. Australian Jewellers Supplies is similar. Cousins charges about £9 for shipping to Australia which is about AU$19 and not too bad (considering Australian parcel post is $11) but I still want to minimise the number of times I'm paying it. I need to explore other options closer to home. There may be something in Singapore or China that would have what I want and ship it faster/more economically.
    • Hi, I just finished the service of a Rolex 3135. Amplitude is great, 295 degrees horizontal after 2 hours and 280 after 12 hours. Vertical positions are 25 degrees down on those. I am however seeing a rate variation with temperature. I have 0 SPD on wrist, say 38 degrees and +7 SPD at 18 degrees room temperature. That equates to +0.35 SPD which is within spec I believe (+-0.5 SPD/ Deg C max). It just seems more than I would expect from such a high quality movement. To put that in context, I see similar rate variation with temperature for a Seiko 7S26. Just wondering what you guys see. Thanks, Steve.
    • For years I've done it the el-cheapo way (read: cleaning by hand). Bought a 2nd Elma S15(H) ultra-sonic, including proper cleaning-fluids (Elma WF Pro (cleaning) & Elma Suprol Pro (rinse)) and entered a complete different cleaning world. These cleaning fluids are none-water based and not that easy to obtain. Initially I bought these fluids in Germany "SKSONIC" (www.sksonic.de) but last year they stopped shipping international. Perhaps they resumed international shipping? You can always ask them. You could also ask @VWatchie, he lives "next-door". As for the fumes; I use the ultra-sonic in my garage, partly for the fumes, but more for our dog ...... he goes "bananas" when I switch on the ultra-sonic. Oh, next on your list (if you consider watch-repair as a long-time hobby), a Microscope (up to 50x is enough).  Pegwood leaves, observed under the microscope that is, whole tree-trunks behind 🫣 Ultra-sonic, in combination with proper cleaning fluids, takes care of the cleaning.
