12 hours ago, nrm said:
I've got a couple watches lined up in addition to the one I posted about in the Newbie repairer category
The Poljot looks pretty good. Its probably a Poljot 2614.2H, and parts are relatively easy to come by. Quite a few USSR era Sekondas share this mechanism.  I'm looking forward to seeing the Gruen too. I presume the button on the Ricoh is a date quick set. I'm not that familiar with Ricohs, so it will be interesting to see how that one is put together too. Watch out for flying springs on the Poljot date mechanism.  Don't ask me how I know. 🤨
13 hours ago, nrm said:
I've got a couple watches lined up in addition to the one I posted about in the Newbie repairer category -- waiting for my confidence to arrive. Not a huge investment, but I'd like to give them the attention they deserve, and hopefully once I get inside, they deserve the attention I give them!
Something about having a small queue makes me feel a bit more urgency in getting stuck in.
IMG_0095.thumb.jpeg.42a9ef3416f96af6538ccc6a6ea35265.jpegIMG_0058.thumb.jpeg.3a7fb97732221f6443d74790c7d4eaeb.jpegIMG_0100.thumb.jpeg.02c107dd4f334b9d9b23002e96995f6c.jpeg
The Ricoh is interesting, plenty going on with that dial, i like it. The Gruen much more reserved but should be a good watch. Grunen for a time shared movements with Rolex, also dial names as seen here. Its not a Rolex but it is a Gruen nice watches matey 👍
Another Accutron 214 found its way into my shopping cart. Not sure how that keeps happening...😇
I've always liked the railroad dials, and I'm a sucker for the blued hands.
This one was sold as running, for a nice change of pace.
You've been bitten by the Accutron bug!
9 minutes ago, Neverenoughwatches said:
Nice, I've been looking at these since i bought a Cortebert. It has a nice big dial like yours .
The printing has worn off but the dial should clean up nicely.  £60, I didn't expect to win. Any guesses on the movement?
It's here, and not only does it look great, but it's running out of the box! It's such a weird experience after all the busted watches I've been buying 🙂
Seriously, I'm such a sucker for the blued hands.
4 minutes ago, JohnR725 said:
As it's running out of the box can I assume that you're not going to service it?
Let's not get ahead of ourselves here. I'm not one to leave well enough alone.
That said, if it looks nice inside and keeps good time, it'll go down on the list and I'll just enjoy wearing it for a while.
May I make a suggestion? Why don't you just enjoy your watch and not worry about servicing it. Then if you lose your mind to decide the service make sure you invite me to the discussion as there's something you don't have.
Interesting timing for this somewhere else in the group I'm still composing a response that part of it has to do with updates to documentation which never find themselves down to the original documentation. Or basically technical documentation is generated at the time the watch came into existence. Technical documentation does not cover all of the variations changes updates etc. although that documentation may exist it doesn't necessarily find its way back to the original documentation.
For instance as this is a railroad grade watch did you notice when you're setting the watch it has a hacking feature? Typically in the railroad grade watch 214 version the hack is they are so that you can set the watch to the exact second. As this watch I believe would've been a railroad grade certified and hacking would be a must.
I did know that RR grade watches generally hack, but the seconds hand continues to sweep while setting on this watch. Come to think of it, I did notice the second hand jumps a bit when you start to set it, so maybe it's trying to hack but something is missing/out of alignment/broken.
I just opened it to check, and it is the correct 214H hacking movement, and has the same M5 date as the case, so I'm guessing it's right.
Also interesting that the movement plates are silver (steel?) and not the brass color of the other movements I have. I'll have to do some more reading on the history.
There was a lot of organic matter, so at the very least I'll be de-casing the movement and cleaning the case.
Anyway, I don't want to hijack this thread, so once I get things apart and cleaned up I'll start my own.
Yes I'm trying not the hijacked the discussion we can look at pretty watches technical can be somewhere else
the date codes as far as the case goes isn't always clear because sometimes I think the factory used whatever cases they had versus movements but yes if they're the same that is a good indication versus dramatic differences.
As far as the colors the plates go I've seen both of them I don't know why they change the colors.
Probably not broken and no you can't see the hack it's on the other side.
Tactical I'll give you is remember the case back as the crown and if there's a lot of dirt and grime under their it's spacing conceivably could change a little bit but the biggest changes spacing would be those back gaskets the original ones that we can't get anymore. So for the hack to work the back gaskets and exact location of the stem is extremely critical. Did I mention pain in the? Yes it's a pain the setup and delete something that you don't have any way so I wouldn't worry about it.
A Molnija (Молния) 15 jewel October Revolution (Октябрьская революция) USSR era pocket watch is on its way to the 404 club.
The Molnija 36xx movements are basically a copy of a Cortébert movement used in Swiss watches from around 1940.
In a working condition, these are fairly popular, but this one appears to be missing the top balance jewel, as well as the bow. It was described as "Balance is not working", so the price was a bargain bin £1.99
Almost certainly needs the balance jewel, and may need a balance staff too. I think I have a scrap movement with the jewel, but it too needs the balance staff, so I may have to go hunting for some of those.
Edited by AndyHull
Not a watch, but still pretty exciting. I've been looking for small parts and tools storage solutions, and I found these nifty Bulova "Repair Master" stacking drawers on eBay. I got two of the two-drawer units, and one that's full of parts! The single drawer just showed up and the other two should be next week.
They're a little small to hold larger movements, but will be great for my drawer o' random tools and small parts. I have a bunch of tiny zip-top bags on order for corralling small parts.
    • Hi, this is the first place I found when looking for advice so I hope someone could advise me.  Im completely new to touching watches but I’ve always wondered how they work.  I’ve bought a cheap movement, an ETA replica to take apart and rebuild.  Im thinking I’ll need some screwdrivers, tweezers, movement holder and a loop? My goal is just to have a go first and see if I enjoy it enough before buying more tools.  Do I buy cheap tools for now and get better quality tools later if I enjoy it like I think I will? or will the cheap tools be a pain and take some of the fun out of it?  With quality tools being relatively expensive I’m unsure what to buy.    Any advice would be greatly appreciated!
    • Yeah I have seen 44-56 documented for Elgin 18 size elsewhere. I have the style of gauge that's like a set of feeler gauges and I never noticed before today it is faintly stamped "Elgin". Pictured is the way I have been measuring. I am going to go to a larger jewel than the 42 that had been in there. I recently won an auction on a big set of Fitrite jewels all in the little bottles, to discover that the what's actually in the bottles bears no relation to the chart of sizes printed on the box. In most cases it seems to be all mixed so in fact I have about 24 little bottles and thousands of assorted jewels of all diameters and lengths, which is better than nothing. But since I don't have a micrometer with a table, measuring for the exact diameter will be a big job. Instead I will test a lot of them in the fork slot the same way I measure with the gauge. But this is still the next thing. I have to get the escapement to unlock first.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
