Not even a nice looking fake. Hopefully eBay act promptly now Geo has reported it.  Sadly eBay tend to drag their feet & someone will for sure be conned & the seller will just disappear into the sunset. To add the seeds of doubt I have asked the seller many questions.
I'd venture another opinion that the photos are of the real thing but that this is some other scam.
The dial and case look to be an accurate copy of this http://www.watches.co.uk/archived-watch/9046/omega-speedmaster-automatic/
Usually fakes have the odd dial marker offset or poor quality printing. Also the inclusion of the half link in the bracelet seems like an extreme measure for a fake (but I'm not an expert).
My guess is that you'd recieve something else or nothing at all if you tried to buy.
Just my 2 cents, but definitely not my £60!
S
The problem I have with blatant fakes is it is a straight forward con. In many cases being supported by organised crime. There are thousands of these to be found in holiday resorts Spain/Greece etc. If it is a copy & sold as is then we'll ok.
They sell these things in Europe?  I thought the EU customs people were all over the fakes.  Down here in Australia customs will allow you to get through customs with a fake on your arm and maybe three or four watches in your bags for friends and family but anything more than that they confiscate.
You can find fakes at the fleamarkets but it's a furtive business and everything is under the table.  You have to ask.  Personally I think that they are a no-no.  The money goes to finance crime and other appalling stuff.
Edited by stroppy
Customs of EU countries cannot check every shipment that comes in, and pretty much gave up on checking on people too.
Also many people nowadays buys counterfeits on the Internet because it's cheaper and there is much more choice. You can guess  the seller is not declaring "fake watch" and not even replica or "original Rolex value $100".
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hairdrier) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
    • How long had it been without any wind before you first put it on the timegrapher?  Perhaps there was some debris / old lubricant that loosened up while you were waiting to do the 24 hour reading? I recently serviced a Seiko 6319 that immediately after service was absolutely horrible on the timegrapher - 24 hours later (without me doing anything) it was rock solid!  I was a little surprised by this (as I have seen improvements in amplitude after letting it run in but never a watch going from useless to great!). I was suspicious that some dirt must still be in there so I took it apart and cleaned and lubcricated it again and had exactly the same experience - snow storm that after some hours turned into a nice straigh line with good amplitude 🤷‍♂️
    • Yes, I know it was able to run before just enough that everything supposed to be affixed with shellac could fall out. I won't get back to work on this watch for several days at least, but one thing you mentioned about the banking pin adjustments being intended for fork horn clearance got me wondering.... The last adjustment I made to the entry stone yesterday did not solve the problem when the balance is installed. The escape teeth can't quite clear the stone when the balance swings. But I thought it was going to work because manually snapping the fork back and forth did allow the escape wheel to advance almost all the time. I wonder if there's another issue with the impulse jewel, that I have to shellac again anyway. I am going to measure the fork slot and the jewel because I am curious if it is the right size or possibly narrower than it should be. My thinking is if the horn clearance is too great maybe it is not getting enough impulse to clear the escape tooth. But pushing the fork with a tool can move it far enough to clear the escape wheel tooth.  I'll see later in the week. I didn't expect a big challenge from this watch because it ticked for 5 minutes before stopping without shellac. As always I was way wrong.
    • I had one success (and one failure) dissolving a broken stem out of a crown with Alum. The successes was a stainless steel crown and a milder steel stem. A Tag Heuer 2000 Automatic - here with the solution at around 60ºC I could see small bubbles coming up from the stump of the stem and it took maybe 6 hours to disolve I tried to repeat this with another watch and it did nothing.....  This was A Bulova Ambassador with what again looked like a stainless steel crown.
    • That good to know in one way.
