Good Taste Or Bad?
fjseal
Give it to me straight from the shoulder folks...does this look okay?
This is a watch bought for spares, now I have replaced the parts I used and decided to customise the dial. The brand was "Towne" and the dial was in poor condition. I experimented with dark and light blue, dark and light green, black and white for the number indexes. I settled on dark blue. The dial is sprayed with Revell Satin red SM331. I would have liked the numbers to have been a little less bulky than they are. I just did it for a bit of fun as an exercise. At least I may have the worst looking watch that no-one else has got!
I bought a brown strap to go with it.
The movement is an AS1187 and it is keeping good time so far.
Frank.
What the heck , Try another color scheme...The red IS red....the blue ?..............what can I say ? ...oh wait , I know ,..... "Not my cup of tea "
Use a transfer from one of your model car kits . It doesn't even have to fit neatly in the diameter of the dial ....You Know ,.... Dali-esque   :rolleyes:
Hi guys,
I'd like to know more about how to work the transfers...never even seen one not being much of a model kit person (although always fascinated by the end result). Is there a way it can be illustrated with pictures how to work them as a watch/dial application? Thank you in advance.
Cheers,
Bob
Hi guys,
Cheers,
Bob
+1.....anyone on the transfers? i'd like to see what it's all about.
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
