The Joy Of Watch Repair
Which of the following gives you the most ecstatic feeling? [emoji23]
o "One more turn and it's all in!" - winding the mainspring into the barrel by hand
o "Fourth wheel in... Third wheel in... Escapement wheel in... And they are all turning freely! Wee!" - aligning the train gears into their jewels
o "swing please... Swing please... Yes!" - installing and seeing the balance assembly swing into action
o "0s/day...0.0ms...270 degrees... Straight line... Not bad!" - after regulating the watch
o "Such a pretty watch!" - admiring the assembled watch head without strap on wrist while still wearing finger cots
o "You know what? I fixed this myself!" - telling your wife/children/friend your new hobby
o "I can watch all these videos all day!" - gets popcorn and sit in front of the computer to watch Mark's videos
Best feeling...
'the click as the last pivot falls into place'
Worst feeling...
'the click as you tighten down the train bridge screw (means you've broken a pivot)'
'the 'oooHH sh!t' feeling when the watch you're working on hits your lap on the way to the floor'
Anil
Balance in and instant start for me! :)
Same for me !
Nothing is more depressing than doing all the dis-assembly, getting the parts fixed and cleaned, putting it all together and when the balance goes in, nothing happens...
I would have to go with when you drop that balance in and it comes to life on its own..
the worst is finishing up a restored watch and as you rubbing off something on the train bridge with some rodico and your thumb hits the balance and you here a click and realized you just broke your balance staff... I walked away from my shop for a few days after that one..
Id have to agree with Geo, that is always a guilty pleasure for me.
Personally for me its discipline of patience, patience , and more patience. Perfecting each stage and giving my very best efforts & concentration into each part. Hand polishing alone can take days or even weeks, but results are worth it.
I agree! And I should have added that aspect of watch repair. At this stage of acquiring skills, I tend to focus on servicing the movement. But I guess knowing how to handle crystals, watch cases are just as important... And satisfying!
First swing of the balance has to be right up there, but what about that feeling when you finally track down that elusive part after 3 hours on the Internet?
S
I know the feeling! I once had a need for several parts of a movement but had a hard time finding all of them, not to mention the cost has between piling up. But when I saw someone selling the same movement albeit not working and for repair, I gambled and grabbed the item. With my fingers crossed I waited for the movement to arrive, hoping at least the parts I needed are in good condition. Fortunately, the gamble paid off! Happiness!
For me finding the reason for a fault & fixing that fault.  A real sense of achievement :woohoo-jumping-smiley-emoticon:
When a customer would say I've had this watch or clock repaired, I've taken it back many times and it still doesn't work. When you repair the fault and knowing it is going to be satisfactory. That would be one of my best feelings, because you know next time the person wants something repaired there more likely to bring it to you then to take it elsewhere.
That's me too. And when the reading on the timegrapher is perfect after fine tuning the hairspring.
    • I read that same article last night  H.  I think epilame is too much headache for me, sources aren't always accurate, some conflicting. Such is the GRAVITY of this situation, Is it ok if i just STICK  to a thixotropic oil 🤣
    • Not sure I follow along. As I stated in one of my previous posts, the epilame will remain intact between rubbing parts as long as the surface is lubricated by oil or grease. Maybe it's just a coincidence, but note how the epilame-treated surface is illustrated in @Waggy's post. It looks like the oil is exposed to a binder (epilame!) so that it can't move sideways.
    • The epilame under the oil will also be removed  Unless the oil makes a barrier between the epilame and the escape teeth 😅 I think i need two strong coffees now 🤣
    • If we use the rub-off epilame method of pallet stones (run dry for a few minutes before applying the epilame) where will the oil go/be transported when it is pushed away from the impulse surface by the escape wheel teeth? Onto the epilame-treated sections of the pallet! Once the oil has been applied/transported to the epilame-treated sections of the pallet where will it then go? Nowhere as the oil will remain on the epilame. So, perhaps the run-dry method defeats its intended purpose leaving the pallet impulse surfaces dry!? If, on the other hand, we do not remove the epilame from the pallet stones where the escape wheel teeth come in contact with them I'd expect more oil to remain where we want it and need it. Yes, I agree, that is the question, and my gut feeling tells me that is exactly the case. Epilame was created to have an adhesive trait and the oleophobic property is just a side effect.
    • Might that be the viscous nature of oil resisting gravity H  ,  we have been comparing water and hydrophobic surfaces which are similar in principle but water is much less viscous than oil. I guess what we trying to discover is if epilame also has an adhesive trait as well as being oleophobic. Plus the oil dropet has very little mass for gravity to work on, like watching tiny water beads that can grip onto vertical glass until they are connected together to increase their mass then run down. Gravity isn't the only factor at play when oil is placed on pallet stones. The oil receives a lot of bashing that may push it out of position ? Thinking about it if the oil stays in position for 10 minutes enough time for the escape wheel to scrape off the epilame , then  a walled in lubrication has been achieved,  the epilame is no longer beneath the oil ( possibly mixed into the oil )
