For those who use One Dip, how do you use it? Do you transfer it to a more practical jar to use it and then back to original container?
I transfer some into a small glass jar with a glass pipette. Easier to work with that way and can be sealed up so it doesn’t flash off as quickly.
On 3/22/2019 at 2:50 PM, tony1212 said:
Is there a risk that the glass fiber brushes leave marks on the metal parts? How to you use them? Liberally or with specific care?
Yes! I use them to remove rust and corrosion from stems, wheel pinions, and wheel pivots (steel). You have to use them with "specific care" as they can produce some pretty ghastly scratches on the wheels themselves (non-steel parts). I hold the wheels as steady as I can with brass tweezers or in a vice, and then I brush the pinion in one direction away from the wheel towards the pivot. Fibreglass scratch brushes are extremely potent, sometimes too potent and that's why I've just ordered a nylon scratch brush which can be used more liberally and on other non-steel parts but still have a very good effect.
I use a small ultrasonic - lighter fluid (naptha)  for cleaning and isopropanol for rinsing.
Worried about shellac dissolving, I tried an old pallet in IPA for 5 mins in the ultrasonic without any noticeable change
Out of materials of your choice, I make several  golves to pull over a flat wooden ice creame cone, to use as brush on pallet jewels, Your one directional strokes of the brush is A okay.
Sorry ice cream sticks not cones
On 3/21/2019 at 1:40 PM, nickelsilver said:
Benzine won't melt the shellac. Alcohol will, but even that needs some time.
I stick pivots into pegwood or cut the tip of a tooth pick with nail clipper to stick the pivot into, rotate the tooth pick " not the pivot"  repeat , best to soak the part in your cleaning solution.  If the shock system lets, remove the jewel ,enter the tooth pick inot the housing, in which case I rotate the wheel. Soak and rinse again.
I forgot about a pallet in IPA for about 20/30 minutes and the pallets stones came loose, that's why I never rinse the pallets and the roller in IPA for more than a few seconds. Five minutes probably wouldn't do much or any harm, but personally, I just don't want to risk it.
I'm afraid I can't picture this in my head, could you please provide a picture? It sounds very interesting!
Do you by chance mean pith wood? I think quite a bit a force would have to be used to penetrate peg wood (a toothpick would be softer) with a pivot and in my mind that could break the pivot. Or, do you make a super tiny hole in the peg wood first? Or, perhaps the pivot is so small that it can actually penetrate peg wood without any problem. When thinking about it some more the answer is probably yes!? Oh well, I guess I could try it but if you have the time to elaborate I'd appreciate it. Thanks!
Last year endevour run out of idea, liked and used my tooth pick technology:lol:
he then posted the pix on some tutorial thread , I thought he done post, no need for me to bother. Here we are.
You can unlock shock springs, pop the jewel assembly out ,into a jar, stick a tooth pick onto pivot, turn the BW, this pegs the hell out of the pivot. Repeat .
Good luck pal.
I actually prefer toothpicks for pegging jewel pivots as they are somewhat softer than peg wood.  You can develop a sharpened tip with sandpaper or a fine file.  I do sometimes use peg wood as well though.
I use naptha as well in the ultrasonic.  I run thru three separate naptha baths and pith the pivots on wheels, the pallet, and the balance into pith wood for cleaning between bath number two and three.
It works for me but use at your own risk.
RMD
Edited by rduckwor
  • 2 months later...
I picked up a movement from Ebay to tinker with, I think it’s Derby 40. I only have experience with incabloc and this one puzzles me. There is a balance jewel and an endstone but no shock spring so why the endstone?
To clean and lubricate the jewel it looks like I’m going to have to remove the hairspring.
Any tips, threads, articles or videos lubricating this?
Open "boot" on index pins. Loosen stud screw. Remove balance. Remove two screws on underside of balance cock to remove cap jewel.
Oil drop should cover around 50% of the cap jewel. Refer to BHI document.
Thank you for your tips and explanations.
I don’t know how you open the boot. My plan was to loosen the stud screw and slide the hair spring through the boot and index pin to remove it but looking at the picture the hairspring doesn’t go as far as the stud. I’ll have to have a good look at it at home, admittedly I never took a balance apart and I’m not sure how it is actually attached and I can’t see it that well from the picture.
Is the BHI document available to view anywhere?
    • This is a screenshot of a video of it running. Not the best quality, though.
    • Depends what sizes of watches you mostly service . If you were to say pocket watches then you might benefit by wholly replacing the 9010 for 9020. As a rough guide hp500 is twice the viscosity of 9020 which is twice the viscosity of 9010 at 20°c.  So hp500 would give you a more mid-range oil between thin 9010 and HP1300, but as it happens hp750 is more mid- range than hp500, but is that more or less useful when oiling a train of wheels. After the barrel arbor the jump down in pivot size is around half, then after the centre wheel maybe more than half until the escapement. And pivot size isn't especially a deciding factor, as the torque and speed of a pivot would be more relevant when thinking about which oil to choose. So 750 might only be useful on a centre wheel and nothing else, and 500 might be better than 1300 for oiling the centre wheel but still comprises the rest of the train, where 9020 would be ok for the train but too thin for the centre wheel, leaving only 1300 for the oiling of it. You see the problem we're having here. What can be ok for one thing is less ok for another in a different way, damping down power compared to oil spread.  Maybe mixing a drop from two opposite range viscosity synthetic oils will give you some approximate thickness of an in-between . You want a short answer now ?  I tnink I'd go with the 9020. Now be prepared for a whole host of different answers. Then to go with this, watch manufacturers change their minds about which oils to use more times than actresses change their knickers.
    • So, working on watches and your karma at the same time: win-win situation!
    • @SteveF ,  Go on to Dr ranfft website,  Enter keywords Omega 26.5T3  ranfft .  There Dr ranfft  has listed all related calibers to this family, all which beat the same frequency,  any balance complete of this family fit your watch. This would only expenad your choice of balance complete.  Recolleting your hairspring is easy, but matching it with a balance of the family is challanging. Regs
