Hi  quite often see them on the balance cock and pallet cock, I assume the tit is to guide the screw into the starting point of the thread keeping the screw upright making it easier to start. .
What WW says. Very handy, especially on smaller screws where there is little to aid guiding the screw into alignment.
Here is a drawing of two screws which are identical except for the little tit at the bottom.
Out of curiosity, is it normal to refer to something like this as tit in the US and UK? The online dictionaries give different meanings.
  • Haha 2
Tits is more often used to describe breasts, so people would often use a different term, like nipple, even though it has similar connotations.
Axels and joints , hubs etc have nipples for the grease gun, the colloquial term was tit,  or projection to give it its correct term.  The name Tit can be equated to the titmouse and the birds of the same ie Blue tits  great tits coal tits, the expression a "right tit" means a complete Idiot so it can be manipulated to mean several different things.  English Language?
9 minutes ago, Klassiker said:
Am I the first in this thread not to mention tits
Quite possibly. I would refer to the said protrusion as either a pip or a spur (or indeed a protrusion) 🙂
2 hours ago, oldhippy said:
Dog screws are used to hold something in place.
Screws in general are used to hold something in place, aren't they? You mean as a set-screw? That's one use. Watchweasol und rodabod are right in saying it's for alignment when fitting.
In the case of watch screws with this feature yes it's to help the screw go in its hole. But dog screws use the tip to hold something in place, like on lathe toolholders.
I feel like tit/nipple has a regionality to it in the US as well. I heard "tit" quite a bit down in Texas, which is its own region (and multiple regions in one), but tends to trend with the American South. I might be able to narrow that down a little further to East Texas, which trends even more closely with the American South. In Colorado, I don't think I've heard something like that referred to in that way, and typically "nipple". I'm located on the border between the US midwest and mountain west regions, and if I had to ascribe that to one or the other, I'd guess midwest for their overly (annoyingly)... puritanical for lack of a better word mannerisms and maybe tit is slightly naughtier than nipple. Though I could be giving the Mormons over in Utah less credit than they're due. Or maybe more...?
My personal vernacular tendencies would have me call it (and this is how I rephrased it in my head as I read it for the first time before learning the direction the thread went) a "feature" with the same relative spacial description as above. But I'm a freaking weirdo living in isolation up on a mountain somewhere, so my vernacular is almost entirely inner monologue anyway, and couldn't correctly be called a manner in which anyone speaks, not even me.
That is a unjustified showoff of vintage machinery part. For this infraction your fine will be 1 pound and 3 shellings, plus 5 pence for each square head screw. Times 2 because isn't even your own.
Please let me know on which YouTube videos you make linguistic comments because I need guidance on that as well on all the funny speeches.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
    • I suppose this will add to the confusion I have a roller jewel assortment. It lists out American pocket watches for Elgin 18 size and even 16 size it's a 50. But not all the various companies used 50-50 does seem to be common one company had a 51 and the smallest is 43. American parts are always interesting? Francis Elgin for mainsprings will tell you the thickness of the spring other companies will not even though the spring for the same number could come in a variety of thicknesses. But if we actually had the model number of your watch we would find it probably makes a reference that the roller jewel came in different dimensions. So overlook the parts book we find that? So it appears to be 18 and 16 size would be the same sort of the arson different catalog numbers and as I said we don't have your Mongol know which Log number were supposed to be using. Variety of materials garnered her sapphire single or double but zero mention about diameters. Then in a section of rollers in this case rollers with jewels we do get this down in the notes section Roller specifications but of course zero reference to the jewel size. I was really hoping the roller jewel assortment would give us sizes it doesn't really. But it does show a picture of how one particular roller jewel gauge is used
    • Seems to still do it through my mobile data, I use an android phone almost exclusively, but I'll double check it. Thanks mark Strange, I'll try my laptop that utilities edge. I've been on site half hour since I got home, it hasn't done it yet. Thanks John
    • At work, I'm on MS Edge, not through chose, on my phone, chrome, no issues with either.
